it didnt work with the drag and drop method but with the onboard stlink and stm32cubeprogrammer it worked and blinked like a christmass tree
That’s weird. But the STM32CubeProgrammer also flashed it at address 0x08000000?
Does it still work after doing an erase and a flash? (Idk if you need to reflash the BLE firmware though then)
i think it flashed at 0x08000000 and i think with openocd it will work without a problem
Can you try this firmware? Deleted
It’s the result of
Serial.begin(9600);
pinMode(LED_BUILTIN, OUTPUT);
Serial.println("BLINK");
delay(200);
delay(200);
with your Uart.cpp fixes.
it worked:
i found your github repo and installed it in pio myself and it is compiling
Are you sure, I just pushed the correct files 1 second ago?
It’s in https://github.com/maxgerhardt/pio-grumpyoldpizza-stm32wb-test.
Please download the project + open in VSCode + check if compilation and upload is working.
@maxgerhardt i also relized that now and i corrected it and it made an error:
i cloned the repo you made called pio-grumpyoldpizza-stm32wb-test and opend it tried to compile and got the error
That’s weird, looks like some corrupted platform or package to me. Can you go
rm -rf ~/.platformio/platforms/ststm32*
and retry?
@maxgerhardt nope its the same no chnage
The Github actions CI can compile this just fine from a clean state: Activate CI · maxgerhardt/pio-grumpyoldpizza-stm32wb-test@76db91e · GitHub
If you don’t have custom changes in the PlatformIO packages, please do
rm -rf ~/.platformio/packages/*
rm -rf ~/.platformio/platforms/*
rm -rf ~/.platformio/.cache
and restart VSCode. It should redownload everything cleanly.
If you have time, you can also check if the BLE-UART example is working fine: Deleted
now your example compiles
ble uart works:
@maxgerhardt could you update the readme file for GitHub - maxgerhardt/ArduinoCore-stm32wb: Arduino Core for STM32WB
Well I’d only update the README file once the builder script is complete and maybe when the framework is merged into the official platform-ststm32 repo yet, but not yet. All work-in-progress right now, USB complete untested, temporary fixes still in place.
ok but write maybe in the firt line that it is a variation with pio support
Done in latest commit.
I’ve had to rename the board file to board = grumpyoldpizza_nucleo_wb55rg to be more in line with the existing board definitions. I also added all other board definitions the core supports and fixed-up the storage type and USB selection and macros so that that compiles. Untested on real hardware ofc since I have none of those boards.
You will need to update the platform code with
pio pkg update -g -p "https://github.com/maxgerhardt/platform-ststm32.git#stm32wb"
on the CLI.
