I am having general struggles with PlatformIO. I’ll have something working for awhile, then, inexplicably, something trivial that should work (e.g., a build of a simple program) fails.
Here’s my latest struggle.
I have a simple light flash with BLE program that runs on an ESP32-DevKitC-32E board. My platformio.ini has this:
framework = espdif
lib_extra_dirs = ~/Documents/Arduino/libraries
The source just includes these headers at the top:
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
When I attempt to build, I get the following error almost immediately:
rocessing esp32dev (platform: espressif32; board: esp32dev; framework: espdif)
-----------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
PLATFORM: Espressif 32 (3.2.0) > Espressif ESP32 Dev Module
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Error: This board doesn't support espdif framework!
========================================================= [FAILED] Took 0.74 seconds =========================================================
The terminal process "C:\Users\mdbra\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'esp32dev'" terminated with exit code: 1.
I tried completely removing and re-installing PlatformIO but that did not get rid of the problem.
What I really want to use for framweork is ‘arduino’, but this is what I was getting when I set framwork to ‘arduino’. What I need to use is the ESP32 library for BLE but Arduino framework. This was previously working for me.
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
Found 50 compatible libraries
|-- <ArduinoBLE> 1.2.0
|-- <ESP32 BLE Arduino> 1.0.1
|-- <TaskJockey> 0.1.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLEAdvertisingData.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLECharacteristic.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLEDescriptor.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLEDevice.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLEService.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLEStringCharacteristic.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\BLETypedCharacteristics.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\local\BLELocalAttribute.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\local\BLELocalCharacteristic.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\local\BLELocalDescriptor.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\local\BLELocalDevice.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\local\BLELocalService.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\remote\BLERemoteAttribute.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\remote\BLERemoteCharacteristic.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\remote\BLERemoteDescriptor.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\remote\BLERemoteDevice.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\remote\BLERemoteService.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\ATT.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\BLEUuid.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\GAP.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\GATT.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\HCI.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\HCICordioTransport.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\HCIUartTransport.cpp.o
Compiling .pio\build\esp32dev\lib7e4\ArduinoBLE\utility\L2CAPSignaling.cpp.o
Compiling .pio\build\esp32dev\lib070\BLE\BLE2902.cpp.o
Compiling .pio\build\esp32dev\lib070\BLE\BLE2904.cpp.o
C:\Users\mdbra\Documents\Arduino\libraries\ArduinoBLE\src\utility\HCIUartTransport.cpp:33:2: error: #error "Unsupported board selected!"
C:\Users\mdbra\Documents\Arduino\libraries\ArduinoBLE\src\utility\HCIUartTransport.cpp:99:40: error: 'SerialHCI' was not declared in this scope HCIUartTransportClass HCIUartTransport(SerialHCI, 912600);
*** [.pio\build\esp32dev\lib7e4\ArduinoBLE\utility\HCIUartTransport.cpp.o] Error 1
========================================================= [FAILED] Took 24.03 seconds =========================================================The terminal process "C:\Users\mdbra\.platformio\penv\Scripts\platformio.exe 'run', '--environment', 'esp32dev'" terminated with exit code: 1.
This program was building for me using the arduiino framework previously. I’m not sure what changed which would cause this error.
