Not sure what exactly happened… it seems I have a knack to kill PIO every so often.
I am getting these errors when compiling:
Linking .pio/build/esp32doit-devkit-v1/firmware.elf
/home/maxg/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: .pio/build/esp32doit-devkit-v1/src/main.cpp.o:(.literal._Z5setupv+0x34): undefined reference to `_Z27determine_lap_bar_positionsv'
/home/maxg/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: .pio/build/esp32doit-devkit-v1/src/main.cpp.o: in function `_Z5setupv':
/home/maxg/Workspaces/PlatformIO/Projects/EGO_Automation/src/main.cpp:232:(.text._Z5setupv+0xb5): undefined reference to `_Z27determine_lap_bar_positionsv'
/home/maxg/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/14.2.0/../../../../xtensa-esp-elf/bin/ld: .pio/build/esp32doit-devkit-v1/src/main.cpp.o: in function `_Z20process_sbus_messagePb':
/home/maxg/Workspaces/PlatformIO/Projects/EGO_Automation/src/main.cpp:382:(.text._Z20process_sbus_messagePb+0xc3): undefined reference to `_Z27determine_lap_bar_positionsv'
*** [.pio/build/esp32doit-devkit-v1/firmware.elf] Error 1
I have deleted the .pio/build
directory, and pio run --target clean
but this did not fix it.
I am not sure where it is picking up the undefined reference
terms.
The main.cpp does not contain these garbled references.
Here the full output:
Processing esp32doit-devkit-v1 (platform: https://github.com/pioarduino/platform-espressif32.git; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (54.3.20+sha.7650157) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 @ 3.2.0
- framework-arduinoespressif32-libs @ 5.4.0+sha.2f7dcd862a
- tool-esptoolpy @ 4.8.9
- tool-mklittlefs @ 3.2.0
- tool-riscv32-esp-elf-gdb @ 14.2.0+20240403
- tool-xtensa-esp-elf-gdb @ 14.2.0+20240403
- toolchain-xtensa-esp-elf @ 14.2.0+20241119
Found 41 compatible libraries
Compiling .pio/build/esp32doit-devkit-v1/src/config.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/src/main.cpp.o
Building .pio/build/esp32doit-devkit-v1/bootloader.bin
Generating partitions .pio/build/esp32doit-devkit-v1/partitions.bin
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/ColorFormat.c.o
esptool.py v4.8.9
Creating esp32 image...
Merged 2 ELF sections
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Esp.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/FirmwareMSC.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/FunctionalInterrupt.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/HEXBuilder.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/HWCDC.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/HardwareSerial.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/IPAddress.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/MD5Builder.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/MacAddress.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Print.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/SHA1Builder.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Stream.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/StreamString.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/Tone.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/USB.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/USBCDC.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/USBMSC.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/WMath.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/WString.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/base64.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/cbuf.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/chip-debug-report.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-adc.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-bt.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-cpu.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-dac.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-gpio.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-i2c-ng.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-i2c-slave.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-i2c.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-ledc.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-matrix.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-misc.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-periman.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-psram.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-rgb-led.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-rmt.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-sigmadelta.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-spi.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-time.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-timer.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-tinyusb.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-touch-ng.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-touch.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/esp32-hal-uart.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/firmware_msc_fat.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/freertos_stats.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/libb64/cdecode.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/libb64/cencode.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/main.cpp.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/stdlib_noniso.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/wiring_pulse.c.o
Compiling .pio/build/esp32doit-devkit-v1/FrameworkArduino/wiring_shift.c.o
Archiving .pio/build/esp32doit-devkit-v1/libFrameworkArduino.a
Indexing .pio/build/esp32doit-devkit-v1/libFrameworkArduino.a
====================================================================================================== [FAILED] Took 7.66 seconds ======================================================================================================
* The terminal process "platformio 'run'" terminated with exit code: 1.
