If I understand correctly, according to this answer it should be possible to copy the library from e.g. .pio\libdeps\uno
to lib
and then modify the source code.
For example, I have this:
[env:uno]
board = uno
adafruit/Adafruit GFX Library@^1.11.9
adafruit/Adafruit ST7735 and ST7789 Library@^1.10.3
in platformio.ini
and the libraries downloaded into .pio\libdeps\uno
are:
Adafruit BusIO
Adafruit seesaw Library
I copied those folders into lib
and made some modifications but I don’t see the lib
folder being mentioned during build process.
Do I have to remove those libraries from platformio.ini
to use the local libraries with my edits?
I thought the code in lib
would have a higher priority over .pio\libdeps
And how to handle multiple environments? I have uno
and megaatmega2560
environments and there are two copies of the libraries - one in .pio\libdeps\uno
and the other one in .pio\libdeps\megaatmega2560
How can the local libraries be edited for each environment separately to have different modifications for every environment?
EDIT:
The modified local copy of the library does have a higher priority over the the code in .pio\libdeps
and the modifications do work despite I didn’t remove the libraries from platformio.ini
The only question that still remains is how to have a different local copy of certain libraries for each environment.
Can I just copy some libraries from .pio\libdeps\uno
to lib\uno
and some libraries from .pio\libdeps\megaatmega2560
to lib\megaatmega2560
and then make edits? Will the compiler and linker in that case use the right local libraries depending on currently active environment?
“The right way of using modified local copy of library” is not modifying a local copy of the library.
What is the use case for this?
Usually there should be no use case for this.
I am afraid that your project architecture may fundamentally wrong ?!
I am working on a firmware for driving motors with ATmega328 and ATmega2560 boards and I am using 240x320 ST7789 display for displaying some data during field testing.
The problem is that display has slightly nonstandard communication so I had to change the source code in some of the library files.
In the same time, I am using another library for reading the incoming data from the receiver over iBUS and I’d like to have two versions of that library - one version for using with ATmega328 which has only one hardware serial port and another version for using with ATmega2560 which has 4 UART ports.
But anyway - I’d like to know if it is possible to have a separate modified local libraries for each environment.
Because, there must be a reason why is the same library which is added automatically through lib_deps
in platformio.ini
installed twice - once for each environment.
Compiler and linker are obviously using the library corresponding to the active environment - despite both copies of the library in .pio\libdeps\uno
and .pio\libdeps\megaatmega2560
are exactly the same.
Now that I copied those libraries into lib
and made modifications, my code really has precedence over the code in .pio\libdeps\*
and that works exactly as expected and as was described in the accepted answer that I linked. However, now both environments are using the very same local (modified) copy of the library.
My question is now if there is a way of telling: "When the active environment is uno
then use lib\uno\*
and when the active environment is megaatmega2560
then use lib\megaatmega2560\*
In other words, is there a way to specify the lib
path for each environment separately.
