Good afternoon all
hopefully this is a very simple problem, I’m using a ESP 32 what I’m trying to achieve is send a command (192.168.1.210/slider1?value=29) to my fan controlle also another (ESP32)
if I use a web browser and just type the command in this works fine.
But if I try and use the program nothing appears to happen it doesn’t appear to be sending anything?
Here is the loop part of the code that is sending the data.
ts.execute();
watchdog();
// Read Joystick values and map to values of 0 - 255
joystick[0] = map(analogRead(JoyStick_X_PIN), 0, 4095, 0, 64);
joystick[1] = map(analogRead(JoyStick_Y_PIN), 0, 4095, 0, 64);
joystick[2] = digitalRead(Button_Switch) ;
//Display the joystick values in the serial monitor.
/* Serial.println("-----------");
Serial.print("x:");
Serial.print(joystick[0]);
Serial.print(" : y:");
Serial.print(joystick[1]);
Serial.print(" : s:");
Serial.println(joystick[2]);
delay(500);
if(x<=10){
x++;
else {
x=0;
/*UploadData="";
UploadData= String("/slider1?value=");
UploadData+=String(joystick[0]);
SendHttpPOST();
UploadData="";
UploadData= String("192.168.1.210");
UploadData+= String("/slider1?value=");
Serial.println(UploadData);
if (client.connect(ServerHost1,80)){
client.println("GET /"+UploadData+" HTTP/1.1\r\nConnection: close\r\n\r\n");
client.println("Host: "+String("192.168.1.210"));
delay(500); // Essential delay for ESP32
client.println F("Connection: close");
Serial.println F("Connection: close");
client.stop();
Any suggestions would be much appreciated
if you would like to look at the full code please see below
Thank you
#include "soc/timer_group_struct.h"
#include "soc/timer_group_reg.h"
#define _TASK_INLINE
#include <TaskScheduler.h>
#include <WiFi.h>
#include "WebServer.h"
#include <Preferences.h>
#include <esp_task_wdt.h>
// Connect to the server with http://fanserver.local/ e.g. name = "myserver" then use address http://myserver.local/
IPAddress local_IP(192, 168, 1, 205);
IPAddress gateway(192, 168, 1, 254); // Set your network Gateway usually your Router base address
IPAddress subnet(255, 255, 255, 0);
IPAddress dns1(192,168,1,254); // Set your network DNS usually your Router base address
IPAddress dns2(8,8,8,8);
WebServer server(80);
WiFiClient client;
Scheduler ts;
Preferences preferences;
const char* hostname = "Joystick";
const char* ServerHost1 = "192.168.1.210";
const char* ServerHost2 = "192.168.1.118";
#define WDT_TIMEOUT 4
// Define Joystick Connections
#define JoyStick_X_PIN 36
#define JoyStick_Y_PIN 39
#define Button_Switch 17
// Declare unsigned 8-bit joystick array
uint16_t joystick[3];
const char* ssid = "BTHub6-******";
const char* password = "JL488888888888";
int Rssi=0;
String UploadData;
unsigned int x=0;
//################# Voids
void WiFiStationConnected(WiFiEvent_t event, WiFiEventInfo_t info);
void WiFiStationDisconnected(WiFiEvent_t event, WiFiEventInfo_t info);
void WiFiGotIP(WiFiEvent_t event, WiFiEventInfo_t info);
void motor_print();
uint8_t StartWiFi();
void watchdog_setup();
void watchdog();
void Web_Listen();
void Rssi_Update();
void SendHttpPOST();
Task Web_Listen1(305,TASK_FOREVER , &Web_Listen,&ts,true);
Task watchdog1(220, TASK_FOREVER, &watchdog,&ts,true);
Serial.println();
TIMERG0.wdt_wprotect=TIMG_WDT_WKEY_VALUE;
TIMERG0.wdt_feed=1; TIMERG0.wdt_wprotect=0;
preferences.begin("credentials", false);
pinMode(Button_Switch,INPUT_PULLUP );
if (StartWiFi() == WL_CONNECTED) { // Start the WiFi service
Serial.println("WiFi Started...");
watchdog_setup(); //Setup watchdog
ts.execute();
watchdog();
Serial.print("x:");
delay(500);
if(x<=10){
x++;
else {
x=0;
/*UploadData="";
SendHttpPOST();
UploadData="";
client.stop();
void WiFiGotIP(WiFiEvent_t event, WiFiEventInfo_t info){
Serial.println("WiFi connected");
Serial.println("IP address: ");
void WiFiStationDisconnected(WiFiEvent_t event, WiFiEventInfo_t info){
Serial.println("Disconnected from WiFi access point");
Serial.print("WiFi lost connection. Reason: ");
Serial.println(info.disconnected.reason);
Serial.println("Trying to Reconnect");
WiFi.begin(ssid, password);
void WiFiStationConnected(WiFiEvent_t event, WiFiEventInfo_t info){
Serial.println("Connected to AP successfully!");
uint8_t StartWiFi() {
Serial.print("\r\nConnecting to: "); Serial.println(String(ssid));
WiFi.disconnect();
delay(1200);
WiFi.mode(WIFI_STA); // switch off AP
WiFi.setAutoConnect(true);
WiFi.setAutoReconnect(true);
WiFi.config(INADDR_NONE, INADDR_NONE, INADDR_NONE, INADDR_NONE);
WiFi.config(local_IP, gateway, subnet, dns1 ,dns2);
WiFi.setHostname(hostname); //define hostname
unsigned long start = millis();
uint8_t connectionStatus;
bool AttemptConnection = true;
while (AttemptConnection) {
connectionStatus = WiFi.status();
if (millis() > start + 15000) { // Wait 15-secs maximum
AttemptConnection = false;
if (connectionStatus == WL_CONNECTED || connectionStatus == WL_CONNECT_FAILED) {
delay(50);
if (connectionStatus == WL_CONNECTED) {
Serial.println("WiFi connected at: " + WiFi.localIP().toString());
WiFi.onEvent(WiFiStationConnected, SYSTEM_EVENT_STA_CONNECTED);
WiFi.onEvent(WiFiGotIP, SYSTEM_EVENT_STA_GOT_IP);
WiFi.onEvent(WiFiStationDisconnected, SYSTEM_EVENT_STA_DISCONNECTED);
server.on("/test", []() {server.send(200, "text/plain", "Server status is OK"); }); // Simple server test by providing a status response
server.begin();
return connectionStatus;
void Web_Listen(){
server.handleClient();
//###################################### Watchdog ###########################################
void watchdog(){
esp_task_wdt_reset(); //Feed the watchdog
void watchdog_setup(){
Serial.print("Configuring Watchdog Timeout for ");
Serial.print(WDT_TIMEOUT);
Serial.println(" Seconds");
esp_task_wdt_init(WDT_TIMEOUT, true); //enable panic so ESP32 restarts
esp_task_wdt_add(NULL); //add current thread to WDT watch
void Rssi_Update(){
int xx=0;
Rssi = WiFi.RSSI();
Rssi = 90 / 40.0 * Rssi + 212.5;
if (Rssi > 100) Rssi = 100;
//RssiS= Rssi + String(Rssi, 0) + " %";
Serial.print("RSSI:");
Serial.println(Rssi);
//ThingSpeak.setField(2,Rssi );
//xx=ThingSpeak.writeFields(myChannelNumber1, myWriteAPIKey1);
if(xx == 200){
Serial.println("Channel update successful.");
else{
Serial.println("Problem updating channel. HTTP error code " + String(xx));
//Rssi_Fail();
void CollectUploadData() {
Serial.println("...Submitting Upload request");
UploadData = "sensor?Sensor="+String(SensorNumber);
UploadData += "&temperature="+String(Temperature);
UploadData += "&humidity="+String(Humidity);
UploadData += "&BMP-temperature="+String(Temperature);
UploadData += "&pressure="+String(Humidity);
UploadData += "&spare="+String(Lightv);
UploadData += "&sensortype="+String("SHTC3");
Serial.println("...Information to be uploaded: "+UploadData);
SendHttpPOST();
//Thingspeak_Send();
void SendHttpPOST() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print F("Attempting connection...");
Serial.println F("connected");
client.println("PUT /"+UploadData+" HTTP/1.1\r\nConnection: close\r\n\r\n");
client.stop();
return;
else {
Serial.println F("try again in 2 Seconds");
//Thingspeak_Send_Fail();
