The .pio folder temporary/build files
Hi, can PlatformIO be setup so that the .pio folder is created on a separate location to my main project?
I have a separate drive I used for temporary data, which isn’t backed up and is optimised for lots of read/writes.
Please see the workspace_dir:
https://docs.platformio.org/en/latest/projectconf/sections/platformio/options/directory/workspace_dir.html
Ahh! Fantastic, I’ll try this now :smiley:
Apologies, struggling with this as there are no examples in the Documentation.
This is what I used:
[PlatformIO]
build_dir = /temp/platformIO/$PROJECT_HASH
/temp is where my temporary drive is mounted.
The Error: File contains no section headers
Ok, I moved this:
[PlatformIO]
to the bottom of the platformio.ini file and it has worked perfectly! Not sure why :slight_smile:
You can also set this as a global environment variable PLATFORMIO_WORKSPACE_DIR
