The debugger crashed after the last update. a month ago everything worked fine. Out of about 30 attempts to start debugging, it worked 2 times (for reasons not clear to me). Previously, the debugger also broke down, but after dancing with tambourines, it started, but now I just spent 4 days trying to restore the debugger after the update. I didn’t make any progress in 4 days, the debugger just fell off out of the blue…
I would be grateful for your help, the platform is very cool, I would like to work on this platform, thanks!
PlatformIO Core, version 5.1.1
Python 3.9.2
Mac OS Catalina 10.15.6 (19G2021)
Platformio ini
[platformio]
lib_extra_dirs = /Users/ilsurahmetanov/Projects/PlatformIO/esp/esp-idf-lib/components
#platform = espressif32
platform = https://github.com/platformio/platform-espressif32 #feature/openocd-update
board=esp32dev
board_build.partitions = partitions_custom.csv
framework = espidf
debug_speed = 5000
debug_tool = esp-prog
upload_protocol = esp-prog
debug_init_break = thb app_main
lib_deps = ds18x20
[DEBUG CONSOLE]
undefinedWarning! `lib_extra_dirs` configuration option is deprecated in section [platformio]! Please move it to global `env` section
Preparing firmware for debugging...
Processing esp32dev (platform: (The link was removed by me); board: esp32dev; framework: espidf)
CONFIGURATION: (The link was removed by me)
PLATFORM: Espressif 32 (3.2.0+sha.b9530d3) > Espressif ESP32 Dev Module
- framework-espidf 3.40200.210118 (4.2.0)
- tool-cmake 3.16.4
- tool-esptoolpy 1.30000.201119 (3.0.0)
- tool-ninja 1.9.0
- tool-openocd-esp32 2.1000.20201202 (10.0)
- toolchain-esp32ulp 1.22851.191205 (2.28.51)
- toolchain-xtensa32 2.80400.210211 (8.4.0)
LDF: Library Dependency Finder -> (The link was removed by me)
Found 43 compatible libraries
|-- <ds18x20>
| |-- <onewire>
| | |-- <esp_idf_lib_helpers>
|-- <bmp180>
| |-- <i2cdev>
Building in debug mode
Retrieving maximum program size .pio/build/esp32dev/firmware.elf
Checking size .pio/build/esp32dev/firmware.elf
RAM: [ ] 4.0% (used 13188 bytes from 327680 bytes)
Flash: [= ] 11.2% (used 235652 bytes from 2097152 bytes)
========================= [SUCCESS] Took 18.59 seconds =========================
Reading symbols from /Users/ilsurahmetanov/Projects/PlatformIO/AUTOMATIC_DIST/.pio/build/esp32dev/firmware.elf...
done.
PlatformIO Unified Debugger -> (The link was removed by me)
PlatformIO: debug_tool = esp-prog
Open On-Chip Debugger v0.10.0-esp32-20201202 (2020-12-02-17:38)
Licensed under GNU GPL v2
For bug reports, read
adapter speed: 20000 kHz
WARNING: boards/esp-wroom-32.cfg is deprecated, and may be removed in a future release.
Info : FreeRTOS creation
adapter speed: 5000 kHz
Info : tcl server disabled
Info : telnet server disabled
Info : clock speed 5000 kHz
Info : esp32.cpu0: Debug controller was reset.
Info : esp32.cpu0: Core was reset.
Info : esp32.cpu1: Debug controller was reset.
Info : esp32.cpu1: Core was reset.
Warn : No symbols for FreeRTOS!
Info : esp32.cpu0: Target halted, PC=0x400F0D9A, debug_reason=00000000
Info : Set GDB target to 'esp32.cpu0'
Info : esp32.cpu1: Target halted, PC=0x400F0D9A, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40091856, debug_reason=00000001
Info : Flash mapping 0: 0x10020 -> 0x3f400020, 40 KB
Info : Flash mapping 1: 0x20020 -> 0x400d0020, 134 KB
Info : Auto-detected flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.flash' size 4096 KB
Info : Using flash bank 'esp32.cpu0.irom' size 136 KB
Info : Using flash bank 'esp32.cpu0.drom' size 44 KB
Info : New GDB Connection: 1, Target esp32.cpu0, state: halted
0x400f0d9a in esp_pm_impl_waiti () at /Users/ilsurahmetanov/.platformio/packages/framework-espidf/components/esp32/pm_esp32.c:484
484 asm("waiti 0");
Info : esp32.cpu0: Target halted, PC=0x500000CF, debug_reason=00000000
Info : esp32.cpu0: Target halted, PC=0x40000400, debug_reason=00000000
Info : esp32.cpu1: Target halted, PC=0x40000400, debug_reason=00000000
** Programming Started **
** Programming Finished **
** Verify Started **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
** Verified OK **
Hardware assisted breakpoint 1 at 0x400d562b: file src/main.c, line 29.
Note: automatically using hardware breakpoints for read-only addresses.
PlatformIO: Resume the execution to `debug_init_break = thb app_main`
PlatformIO: More configuration options -> (The link was removed by me)
