I used this project
Converted from https://github.com/espressif/esp-protocols/blob/websocket-v1.2.3/components/esp_websocket_client/examples/target
Here src/websocket_example.c I add the URL of the server I uploaded to RNDER
#include <stdio.h>
#include "esp_wifi.h"
#include "esp_system.h"
#include "nvs_flash.h"
#include "esp_event.h"
#include "protocol_examples_common.h"
#include "freertos/task.h"
#include "freertos/semphr.h"
#include "freertos/event_groups.h"
#include "esp_log.h"
#include "esp_websocket_client.h"
#include <cJSON.h>
#define NO_DATA_TIMEOUT_SEC 5
static const char *TAG = "websocket";
// Updated SSID and WebSocket URI
#define WIFI_SSID "Wokwi-GUEST"
#define WIFI_PASS ""
#define WEBSOCKET_URI "https://websocket-server-o6kg.onrender.com"
static TimerHandle_t shutdown_signal_timer;
static SemaphoreHandle_t shutdown_sema;
static void log_error_if_nonzero(const char *message, int error_code)
if (error_code != 0) {
ESP_LOGE(TAG, "Last error %s: 0x%x", message, error_code);
static void shutdown_signaler(TimerHandle_t xTimer)
ESP_LOGI(TAG, "No data received for %d seconds, signaling shutdown", NO_DATA_TIMEOUT_SEC);
xSemaphoreGive(shutdown_sema);
static void websocket_event_handler(void *handler_args, esp_event_base_t base, int32_t event_id, void *event_data)
esp_websocket_event_data_t *data = (esp_websocket_event_data_t *)event_data;
switch (event_id) {
case WEBSOCKET_EVENT_CONNECTED:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_CONNECTED");
break;
case WEBSOCKET_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_DISCONNECTED");
log_error_if_nonzero("HTTP status code", data->error_handle.esp_ws_handshake_status_code);
if (data->error_handle.error_type == WEBSOCKET_ERROR_TYPE_TCP_TRANSPORT) {
log_error_if_nonzero("reported from esp-tls", data->error_handle.esp_tls_last_esp_err);
log_error_if_nonzero("reported from tls stack", data->error_handle.esp_tls_stack_err);
log_error_if_nonzero("captured as transport's socket errno", data->error_handle.esp_transport_sock_errno);
break;
case WEBSOCKET_EVENT_DATA:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_DATA");
ESP_LOGI(TAG, "Received opcode=%d", data->op_code);
if (data->op_code == 0x08 && data->data_len == 2) {
ESP_LOGW(TAG, "Received closed message with code=%d", 256 * data->data_ptr[0] + data->data_ptr[1]);
} else {
ESP_LOGW(TAG, "Received=%.*s\n\n", data->data_len, (char *)data->data_ptr);
// If received data contains json structure it succeed to parse
cJSON *root = cJSON_Parse(data->data_ptr);
if (root) {
for (int i = 0 ; i < cJSON_GetArraySize(root) ; i++) {
cJSON *elem = cJSON_GetArrayItem(root, i);
cJSON *id = cJSON_GetObjectItem(elem, "id");
cJSON *name = cJSON_GetObjectItem(elem, "name");
ESP_LOGW(TAG, "Json={'id': '%s', 'name': '%s'}", id->valuestring, name->valuestring);
cJSON_Delete(root);
ESP_LOGW(TAG, "Total payload length=%d, data_len=%d, current payload offset=%d\r\n", data->payload_len, data->data_len, data->payload_offset);
xTimerReset(shutdown_signal_timer, portMAX_DELAY);
break;
case WEBSOCKET_EVENT_ERROR:
ESP_LOGI(TAG, "WEBSOCKET_EVENT_ERROR");
break;
static void websocket_app_start(void)
esp_websocket_client_config_t websocket_cfg = {
.uri = WEBSOCKET_URI,
shutdown_signal_timer = xTimerCreate("Websocket shutdown timer", NO_DATA_TIMEOUT_SEC * 1000 / portTICK_PERIOD_MS,
pdFALSE, NULL, shutdown_signaler);
shutdown_sema = xSemaphoreCreateBinary();
ESP_LOGI(TAG, "Connecting to %s...", websocket_cfg.uri);
esp_websocket_client_handle_t client = esp_websocket_client_init(&websocket_cfg);
esp_websocket_register_events(client, WEBSOCKET_EVENT_ANY, websocket_event_handler, (void *)client);
esp_websocket_client_start(client);
xTimerStart(shutdown_signal_timer, portMAX_DELAY);
char data[32];
int i = 0;
while (i < 5) {
if (esp_websocket_client_is_connected(client)) {
int len = sprintf(data, "hello %04d", i++);
ESP_LOGI(TAG, "Sending %s", data);
esp_websocket_client_send_text(client, data, len, portMAX_DELAY);
vTaskDelay(1000 / portTICK_PERIOD_MS);
ESP_LOGI(TAG, "Sending fragmented message");
memset(data, 'a', sizeof(data));
esp_websocket_client_send_text_partial(client, data, sizeof(data), portMAX_DELAY);
memset(data, 'b', sizeof(data));
esp_websocket_client_send_cont_msg(client, data, sizeof(data), portMAX_DELAY);
esp_websocket_client_send_fin(client, portMAX_DELAY);
xSemaphoreTake(shutdown_sema, portMAX_DELAY);
esp_websocket_client_close(client, portMAX_DELAY);
ESP_LOGI(TAG, "Websocket Stopped");
esp_websocket_client_destroy(client);
static void wifi_event_handler(void* arg, esp_event_base_t event_base,
int32_t event_id, void* event_data)
if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_START) {
esp_wifi_connect();
} else if (event_base == WIFI_EVENT && event_id == WIFI_EVENT_STA_DISCONNECTED) {
ESP_LOGI(TAG, "Retrying WiFi connection...");
esp_wifi_connect();
} else if (event_base == IP_EVENT && event_id == IP_EVENT_STA_GOT_IP) {
ip_event_got_ip_t* event = (ip_event_got_ip_t*) event_data;
ESP_LOGI(TAG, "Got IP address: " IPSTR, IP2STR(&event->ip_info.ip));
static void wifi_init(void)
ESP_ERROR_CHECK(esp_netif_init());
ESP_ERROR_CHECK(esp_event_loop_create_default());
esp_netif_create_default_wifi_sta();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
esp_event_handler_instance_t instance_any_id;
esp_event_handler_instance_t instance_got_ip;
ESP_ERROR_CHECK(esp_event_handler_instance_register(WIFI_EVENT,
ESP_EVENT_ANY_ID,
&wifi_event_handler,
NULL,
&instance_any_id));
ESP_ERROR_CHECK(esp_event_handler_instance_register(IP_EVENT,
IP_EVENT_STA_GOT_IP,
NULL,
&instance_got_ip));
wifi_config_t wifi_config = {
.sta = {
.ssid = WIFI_SSID,
.password = WIFI_PASS,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
ESP_LOGI(TAG, "wifi_init finished.");
void app_main(void)
ESP_LOGI(TAG, "[APP] Startup..");
ESP_LOGI(TAG, "[APP] Free memory: %" PRIu32 " bytes", esp_get_free_heap_size());
ESP_LOGI(TAG, "[APP] IDF version: %s", esp_get_idf_version());
esp_log_level_set("*", ESP_LOG_INFO);
esp_log_level_set("websocket_client", ESP_LOG_DEBUG);
esp_log_level_set("transport_ws", ESP_LOG_DEBUG);
esp_log_level_set("trans_tcp", ESP_LOG_DEBUG);
ESP_ERROR_CHECK(nvs_flash_init());
wifi_init();
websocket_app_start();
My server only supports WS
