Thanks for hanging in there! ![]()
I dunno what more to try… I started de-constructing the PlatformIO and Arduino IDE compile and linker commands, and whilst there were some minor variations, that didn’t seem to be altering anything… but there some parts I don’t know how to compare/pull apart.
If you don’t mind humouring me on one final possible point of difference, can you compare the file generated by this command (gets placed in the sketch folder)
with this one (fc /b for a binary comparison or some other tool)
This was the code I compiled - the same as above, with the RXLED1/TXLED1 macros commented out.
/* HID Joystick Mouse Example
by: Jim Lindblom
date: 1/12/2012
license: MIT License - Feel free to use this code for any purpose.
No restrictions. Just keep this license if you go on to use this
code in your future endeavors! Reuse and share.
This is very simplistic code that allows you to turn the
SparkFun Thumb Joystick (http://www.sparkfun.com/products/9032)
into an HID Mouse. The select button on the joystick is set up
as the mouse left click.
#include "Mouse.h"
int horzPin = A0; // Analog output of horizontal joystick pin
int vertPin = A1; // Analog output of vertical joystick pin
int selPin = 9; // select button pin of joystick
int vertZero, horzZero; // Stores the initial value of each axis, usually around 512
int vertValue, horzValue; // Stores current analog output of each axis
const int sensitivity = 200; // Higher sensitivity value = slower mouse, should be <= about 500
int mouseClickFlag = 0;
void setup()
//Serial.begin(9600);
pinMode(horzPin, INPUT); // Set both analog pins as inputs
pinMode(vertPin, INPUT);
pinMode(selPin, INPUT); // set button select pin as input
digitalWrite(selPin, HIGH); // Pull button select pin high
delay(1000); // short delay to let outputs settle
vertZero = analogRead(vertPin); // get the initial values
horzZero = analogRead(horzPin); // Joystick should be in neutral position when reading these
void loop()
vertValue = analogRead(vertPin) - vertZero; // read vertical offset
horzValue = analogRead(horzPin) - horzZero; // read horizontal offset
if (vertValue != 0)
Mouse.move(0, vertValue/sensitivity, 0); // move mouse on y axis
if (horzValue != 0)
Mouse.move((horzValue/sensitivity) *-1, 0, 0); // move mouse on x axis
if ((digitalRead(selPin) == 0) && (!mouseClickFlag)) // if the joystick button is pressed
mouseClickFlag = 1;
Mouse.press(MOUSE_LEFT); // click the left button down
else if ((digitalRead(selPin))&&(mouseClickFlag)) // if the joystick button is not pressed
mouseClickFlag = 0;
Mouse.release(MOUSE_LEFT); // release the left button
// RXLED1;
// TXLED1;
@ivankravets Is there anything more we can do to try and get to the bottom of this? Judging from the binary file compare in my post above, there is only a very difference between the PlatformIO compile output and the Arduino IDE… it’s just trying to pin down what is causing it.
