I’m using a STM32F405 Adafruit Feather Board and I ran the Free_Font_Demo.ini program from the TFT_eSPI examples. The code appears to run correctly but all the text is the same small font but it should be changing to different fonts.
My platform.ini has this:
[env:adafruit_feather_f405]
platform = ststm32
board = adafruit_feather_f405
upload_protocol = dfu
Wire
SPI
TFT_eSPI
Adafruit BME280 Library
Adafruit DS3502
; TFT_eSPI library setting here (no need to edit library files):
-D USER_SETUP_LOADED=1 ; Set this settings as valid
-D ILI9341_DRIVER=1 ; Select ILI9341 driver
-D TFT_WIDTH=240 ; Set TFT size
-D TFT_HEIGHT=320
-D TFT_MISO=24 ; Define SPI pins
-D TFT_MOSI=25
-D TFT_SCLK=23
-D TFT_CS=10
-D TFT_DC=9 ; Data/Comand pin
-D TFT_RST=-1 ; Reset pin
-D LOAD_GLCD=1 ; Load Fonts
-D SPI_FREQUENCY=36000000 ; Set SPI frequency
; -D USER_SETUP_LOADED=1
; -include $PROJECT_LIBDEPS_DIR/$PIOENV/TFT_eSPI_ID1559/User_Setups/Setup1_ILI9341.h
; -D TFT_DC = 9
; -D TFT_CS = 10
and the beginning of the code starts with this:
#include <TFT_eSPI.h>
//#include <Fonts/FreeSerifBold18pt7b.h> // Font for TFT
#include "Free_Fonts.h"
// Use hardware SPI
TFT_eSPI tft = TFT_eSPI();
When I run the Run_User_Setup.ino example code it outputs this:
TFT_eSPI ver = 2.2.8
Transactions = Yes
Font GLCD loaded
Font 2 loaded
Font 4 loaded
Font 6 loaded
Font 7 loaded
Font 8 loaded
Smooth font enabled
So I believe I have everything configured correctly but it’s not displaying the different fonts
