So I am trying to use the TFT_eSPI library, I created a new project added the library via platformio to it, made my changes to the UserSetup.h(required for pin definition). I then copied the Meter example into my main.cpp and it compiled fine, I then uploaded it to my esp32 dev board , and after upload I got a random flickering but mostly white screen. After making sure I had the screen wired correctly I double checked the pin definition, all was well. I then just tried to reupload the sketch and had same results.
I then added the library to my arduino ide , opened the same example sketch, uploaded it to the board, and it worked meters displayed instantly.
I then tried and manually put the folder into my platformio project under the lib folder and then pointed to that header file instead of loading the one from platformio. Compiled and uploaded fine, but same white flickering screen. there is literally no difference in the sketches only difference is the IDE and idk how that is causing this issue.
I would like this to work in platformio as i have a template sketch I use for all my esp devices, and whether I have to manually add the library or can use platformio, I dont really care, I just need it to work, and I have been fighting it all morning.
Any help or ideas would be appreciated.
Thanks
bacon
