TFT_eISP noob question about User_Setup.h location
I recently bought the Lilygo T-display and Q-QT boards and wanted to use TFT_eSPI library. As normal, at first it didn’t work.
These boards haven’t got a board definition of their own, so u use esp32-s3-devkitc-1, which hasn’t got a TFT display, so I got thinking how does it know which pins to use for the TFT display? And indeed that was the problem.
After some digging I found a User_Setup.h in the git repository for the boards and copied that at first to the lib folder of my project, and that did nothing, so I moved it to the include folder and that did nothing.
The configuring options.txt file (also in the git repository) said that you can also load settings with a -D prefix in the platformio.ini file, ant, that did work. But I think would rather use the User_Setup.h file.
So the questions are:
What must I do with the User_Setup.h file.
And what are the benefits of loading settings with a -D prefix in the platformio.ini file vs. using the User_Setup.h file.
The code i wrote:
#include <TFT_eSPI.h>
#include “User_Setup.h”
TFT_eSPI lcd = TFT_eSPI();
void setup(void)
lcd.init();
lcd.fillScreen(TFT_BLUE);
lcd.setRotation(1);
void loop()
Kind regards Bert.
I wish someone had the answer to this.
But the answer is right there in the README.md:
PlatformIO users can define these settings on a per project basis within a platformio.ini file, see Docs folder in library.
And here is the corresponding file from the docs folder:
Thanks for this. Also here i found the answer Installing on PlatformIO · Bodmer/TFT_eSPI Wiki · GitHub
