Hi all!
Loving PlatformIO, but recently ran into two problems that both return back a [“No module named ‘termios’”] error message.
First noticed this about a month ago, whenever I would click on a PlatformIO Home - Recent News link, the resulting error message would be:
OS_OPEN_URL
Server error: {"type":"ModuleNotFoundError","args":["No module named 'termios'"],"message":"No module named 'termios'"}
.Now, most recently, I am getting the same error message on a specific project when I try to compile it. It is an arduino UNO project with a touchscreen display. When I try to build this project, I get this error message in the terminal:
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/uno.html
PLATFORM: Atmel AVR (3.3.0) > Arduino Uno
- framework-arduino-avr 5.1.0
Library Manager: Installing adafruit/Adafruit BusIO @ ^1.9.6
Library Manager: Warning! Package Mirror: No module named 'termios'
Library Manager: Looking for another mirror...
PackageException: Could not install package 'adafruit/Adafruit BusIO @ ^1.9.6' for 'windows_amd64' system:
File "C:\Program Files\Inkscape\lib\python3.8\site-packages\platformio\builder\main.py", line 181:
There are additional errors after those listed above, all pointing to errors in .py files which I assume is a result of the error posted above.
Here is my platformio.ini:
[env:uno]
board = uno
lib_extra_dirs = ~/Documents/Arduino/libraries
lib_deps = adafruit/Adafruit BusIO@^1.9.6
The lib_extra_dirs and lib_deps are the same as used in other project’s platformio.ini that build fine.
Some of my system info:
- win10
- Visual Studio Code v1.66 - just updated itself before writing this, but the problem occurred before this update
- PlatformIO core 5.2.5
Thanks for any help,
Randy
PS - the project builds in the arduino IDE
