zgoda
July 5, 2016, 7:26am
#1
Since last update to Platformio IDE and terminal I started getting some output to PIO terminal, eg. on platforms update:
export PATH=/home/jazg/.atom/packages/platformio-ide/penv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/bin
platformio update
jazg@JAZG-LENOVO:~/work/stm32_cstation $ export PATH=/home/jazg/.atom/packages/platformio-ide/penv/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/usr/local/bin
jazg@JAZG-LENOVO:~/work/stm32_cstation $ platformio update
Platform atmelavr
This happens always on opening new terminal. Is there any option to turn this off?
This is a feature Export IDE's process `PATH` to the PlatformIO Terminal // Resolve #47 · platformio/platformio-atom-ide@7a2ba4a · GitHub
Sometimes pty.js doesn’t handle process.env.PATH
variable correctly when initializes Terminal session. In this case, pio/platformio
executables files are not available.
If you haven’t had any problems with Terminal before, you can go to Menu: PlatformIO > Settings > platformio-ide-terminal > Core > Auto run command
and set it to echo ""
or similar.
zgoda
July 6, 2016, 7:54am
#3
I just removed the whole autorun command text and it seems to work OK, thank you.
If setting is empty, PlatformIO will restore the value on next IDE restart. Maybe, need to add additional checkbox to the PlatformIO settings page?
zgoda
July 6, 2016, 8:06am
#5
OK, not a big problem, definitely can live with that until any fix is available.
