HI,
I am experimenting with the SD card with Teensy3.6. I am trying to build the example program given here. I copied the contents of the .ino file into src/main.cpp in platformIO project. I get the following error while building.
Code:
#include <SD.h>
#include <SPI.h>
// set up variables using the SD utility library functions:
Sd2Card card;
SdVolume volume;
SdFile root;
// change this to match your SD shield or module;
// Arduino Ethernet shield: pin 4
// Adafruit SD shields and modules: pin 10
// Sparkfun SD shield: pin 8
// Teensy audio board: pin 10
// Teensy 3.5 & 3.6 & 4.1 on-board: BUILTIN_SDCARD
// Wiz820+SD board: pin 4
// Teensy 2.0: pin 0
// Teensy++ 2.0: pin 20
const int chipSelect = BUILTIN_SDCARD;
void setup()
//UNCOMMENT THESE TWO LINES FOR TEENSY AUDIO BOARD:
//SPI.setMOSI(7); // Audio shield has MOSI on pin 7
//SPI.setSCK(14); // Audio shield has SCK on pin 14
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect.
Serial.print("\nInitializing SD card...");
// we'll use the initialization code from the utility libraries
// since we're just testing if the card is working!
if (!card.init(SPI_HALF_SPEED, chipSelect)) {
Serial.println("initialization failed. Things to check:");
Serial.println("* is a card inserted?");
Serial.println("* is your wiring correct?");
Serial.println("* did you change the chipSelect pin to match your shield or module?");
return;
} else {
Serial.println("Wiring is correct and a card is present.");
// print the type of card
Serial.print("\nCard type: ");
switch(card.type()) {
case SD_CARD_TYPE_SD1:
Serial.println("SD1");
break;
case SD_CARD_TYPE_SD2:
Serial.println("SD2");
break;
case SD_CARD_TYPE_SDHC:
Serial.println("SDHC");
break;
default:
Serial.println("Unknown");
// Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32
if (!volume.init(card)) {
Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've formatted the card");
return;
// print the type and size of the first FAT-type volume
uint32_t volumesize;
Serial.print("\nVolume type is FAT");
Serial.println(volume.fatType(), DEC);
Serial.println();
volumesize = volume.blocksPerCluster(); // clusters are collections of blocks
volumesize *= volume.clusterCount(); // we'll have a lot of clusters
if (volumesize < 8388608ul) {
Serial.print("Volume size (bytes): ");
Serial.println(volumesize * 512); // SD card blocks are always 512 bytes
Serial.print("Volume size (Kbytes): ");
volumesize /= 2;
Serial.println(volumesize);
Serial.print("Volume size (Mbytes): ");
volumesize /= 1024;
Serial.println("\nFiles found on the card (name, date and size in bytes): ");
root.openRoot(volume);
// list all files in the card with date and size
root.ls(LS_R | LS_DATE | LS_SIZE);
void loop(void) {
Error:
src/main.cpp: In function 'void setup()':
src/main.cpp:114:23: error: no matching function for call to 'SdFile::openRoot(SdVolume&)'
In file included from /home/cryoschrome/.platformio/packages/framework-arduinoteensy/libraries/SdFat/src/FsLib/FsLib.h:32:0,
from /home/cryoschrome/.platformio/packages/framework-arduinoteensy/libraries/SdFat/src/SdFat.h:35,
from /home/cryoschrome/.platformio/packages/framework-arduinoteensy/libraries/SD/src/SD.h:27,
from src/main.cpp:23:
/home/cryoschrome/.platformio/packages/framework-arduinoteensy/libraries/SdFat/src/FsLib/FsFile.h:458:8: note: candidate: bool FsBaseFile::openRoot(FsVolume*)
bool openRoot(FsVolume* vol);
/home/cryoschrome/.platformio/packages/framework-arduinoteensy/libraries/SdFat/src/FsLib/FsFile.h:458:8: note: no known conversion for argument 1 from 'SdVolume' to 'FsVolume*'
The program build and works fine on Arduino IDE.
Any help is appreciated.
Thank you!
