Hi all,
I have been looking through the forum and google trying to find a solution but so far it’s not working for me. I want to use the usbMIDI
that is shown in the docs with my Teensy 3.2
. Any help is highly appreciated and welcomed!
I’ve added build_flags = -D USB_MIDI
to the platformio.ini
and it works. That is, the build succeeds. However, in my main.cpp
it’s still giving me error messages:
identifier "usbMIDI" is undefinedC/C++(20)
I’ve tried each of the following includes in main.cpp
#include <MIDIUSB.h>
#include <MIDI.h>
#include <MIDI.hpp>
I’ve tried each of the following configurations in platformio.ini
lib_extra_dirs = ~/Arduino/libraries
lib_ignore = MIDIUSB, Audio
; current platformio.ini -- lib configs are trials (didn't seem to work)
[env:teensy31]
platform = teensy
board = teensy31
build_flags = -D USB_MIDI -D TEENSY_OPT_FASTEST
Full platformio.ini
? What Teensy is this even for?
Thank you @maxgerhardt. Updated OP.
tl;dr: Teensy 3.2 with default .ini
plus build flags -D USB_MIDI -D TEENSY_OPT_FASTEST
and mentioned lib flags.
Compiles for me with your platformio.ini
and a basic sketch
usbMIDI.begin();
Checking size .pio\build\teensy31\firmware.elf
Building .pio\build\teensy31\firmware.hex
RAM: [= ] 5.2% (used 3408 bytes from 65536 bytes)
Flash: [ ] 3.1% (used 8224 bytes from 262144 bytes)
============================= [SUCCESS] Took 1.94 seconds =============================
What’s the full error log when executing a “Build”?
@maxgerhardt Build succeeds,
Checking size .pio/build/teensy31/firmware.elf
RAM: [= ] 6.9% (used 4552 bytes from 65536 bytes)
Flash: [= ] 5.2% (used 13504 bytes from 262144 bytes)
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-gui
Uploading .pio/build/teensy31/firmware.hex
=============================================================== [SUCCESS] Took 29.48 seconds ===============================================================
and midi logger shows activity for code usbMIDI.sendNoteOn(1,1,1);
which means it’s technically building and uploading okay.
However, the intellisense doesn’t work and it’s showing me errors like this:
Try a Ctrl(Or, command)+Shift+P → Rebuild IntelliSense.
As if by magic, that’s done the job! Thank you greatly. Any pointers as to why this was needed? What did I do that required it? Was it the build flag?
