Hi Guys,
if I have the following code:
#include <ILI9341_t3n.h>
#define TFT_RST 8
#define TFT_DC 9
#define TFT_CS 10
#define TFT_MOSI 11
#define TFT_MISO 12
#define TFT_SCK 13
#define TOUCH_CS 6
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
void setup()
pinMode(13, OUTPUT); // LED pin
digitalWrite(13, 1);
Serial.printf("Started\n");
tft.begin(100'000'000);
tft.fillScreen(ILI9341_BLACK);
tft.fillScreen(ILI9341_YELLOW);
void loop()
Serial.printf("running\n");
delay(1000);
unsigned long start = micros();
Serial.printf("took %lu\n", micros() - start);
delay(1000);
And the following ini file:
[env:teensy41]
platform = teensy
board = teensy41
build_type = debug
upload_protocol = teensy-cli
monitor_port = /dev/cu.usbmodem79500901
lib_deps = kurte/ILI9341_t3n @ 0.0.0-alpha+sha.f1bfb81825
Then when flashed the teensy fails to startup, the led is not lit and the serial ports are not available. It is dead and requires the button to be used to flash it.
If I change the ini file to
[env:teensy41]
platform = teensy
board = teensy41
build_type = debug
build_unflags = -Og
build_flags = -O1
debug_build_flags = -O1
Now the teensy starts fine.
Anyone any idea why using -Og would cause the teensy not to startup?
