I have a project. Things are working fine. I want to add an I2C device, so I include <Wire.h> and write code that references that. As soon as I load that hex, the loader LED on the board blinks 7 times, which according to docs here, happens either due to HW error or “processor reboots due to fault or other error handling”.
Happened the first time a few weeks ago, I thought it was just some problem with the particular hardware I was using, so I moved on to something else.
Now I’m back at that point with a different piece of I2C hardware entirely, and it’s the same story. If my project includes code that references Wire, even if that code is never called, the hex will not boot and I’ll get the 7 blink error.
I know that you’re going to tell me “run Scanner.ino” so I installed Arduino IDE / Teensyduino, and did just that. Boots and runs fine, no issue.
Thinking it’s something weird with my project specifically, I create a new PlatformIO project and copy the Scanner.ino code into it. This causes the “7 blinks of crashing” problem.
Here’s the code, it’s copied directly from I2CScanner Sketch page, the only change I made was to use Serial5 to send the console over a hardware UART instead of the USB UART because I prefer to use a dedicated console instead of playing the “re-open Serial Monitor every time” game.
#include <Wire.h>
void setup()
Wire.begin();
Serial5.begin(9600);
// while (!Serial);
Serial5.println("\nI2C Scanner");
void loop()
byte error, address;
int nDevices;
Serial5.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
Serial5.print("I2C device found at address 0x");
if (address<16)
Serial5.print("0");
Serial5.print(address,HEX);
Serial5.println(" !");
nDevices++;
else if (error==4)
Serial5.print("Unknown error at address 0x");
if (address<16)
Serial5.print("0");
Serial5.println(address,HEX);
if (nDevices == 0)
Serial5.println("No I2C devices found\n");
else
Serial5.println("done\n");
delay(5000);
Any ideas would be appreciated. It’s got to be something particular that PIO is doing; the same code on the same hardware works when compiled in Teensyduino.
Compiling in Arduino gets me the following: note this hex WORKS
Memory Usage on Teensy 4.1:
FLASH: code:13172, data:5304, headers:9168 free for files:8098820
RAM1: variables:5952, code:10096, padding:22672 free for local variables:485568
RAM2: variables:12416 free for malloc/new:511872
Here’s the PIO compilation output for version info and the like; note this hex does NOT work:
Processing teensy41 (platform: teensy; board: teensy41; framework: arduino)
--------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy41.html
PLATFORM: Teensy (5.0.0) > Teensy 4.1
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 7.75MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy @ 1.159.0 (1.59)
- tool-teensy @ 1.159.0 (1.59)
- toolchain-gccarmnoneeabi-teensy @ 1.110301.0 (11.3.1)
Found 92 compatible libraries
|-- Wire @ 1.0
Building in debug mode
Compiling .pio\build\teensy41\src\main.cpp.o
Linking .pio\build\teensy41\firmware.elf
Calculating size .pio\build\teensy41\firmware.elf
Checking size .pio\build\teensy41\firmware.elf
Building .pio\build\teensy41\firmware.hex
teensy_size: Memory Usage on Teensy 4.1:
teensy_size: FLASH: code:12532, data:5304, headers:8784 free for files:8099844
teensy_size: RAM1: variables:5952, code:9584, padding:23184 free for local variables:485568
teensy_size: RAM2: variables:12416 free for malloc/new:511872
===================================== [SUCCESS] Took 2.25 seconds =====================================
Looks like the PlatformIO output file is a bit smaller, could it be missing something? (I know .hex format is ASCII so size difference is not 1:1 with the firmware, but the PIO hex file is 2,880 bytes smaller. I’m not sure if I can upload these but I’d be glad to if anyone needs them.
Any suggestions would be greatly appreciated!
