I have been using PlatformIO with the Teensy 4.0 extensively with framework-arduinoteensy 1.56 and tool-teensy 1.55, but after updating to framework-arduinoteensy 1.57 and tool-teensy 1.57, I get an error when I try to do a build. On the earlier version, it would build the firmware.hex file and then it would display the memory usage. On the new version, it builds the firmware.hex file, but then it says “Access is denied. *** [size] Error 1”.
Here is the terminal output with v1.56. It has no errors. I’ve edited out the long list of files being compiled.
* Executing task: C:\Users\myname\.platformio\penv\Scripts\platformio.exe run
Processing teensy40 (platform: teensy; board: teensy40; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/teensy/teensy40.html
PLATFORM: Teensy (4.16.0) > Teensy 4.0
HARDWARE: IMXRT1062 600MHz, 512KB RAM, 1.94MB Flash
DEBUG: Current (jlink) External (jlink)
- framework-arduinoteensy @ 1.156.0 (1.56)
- tool-teensy @ 1.155.0 (1.55)
- toolchain-gccarmnoneeabi @ 1.50401.190816 (5.4.1)
Found 104 compatible libraries
Archiving .pio\build\teensy40\libFrameworkArduino.a
Indexing .pio\build\teensy40\libFrameworkArduino.a
Linking .pio\build\teensy40\firmware.elf
Checking size .pio\build\teensy40\firmware.elf
Calculating size .pio\build\teensy40\firmware.elf
Building .pio\build\teensy40\firmware.hex
teensy_size: Memory Usage on Teensy 4.0:
teensy_size: FLASH: code:38156, data:8316, headers:8820 free for files:1976324
teensy_size: RAM1: variables:12704, code:36024, padding:29512 free for local variables:446048
teensy_size: RAM2: variables:44640 free for malloc/new:479648
=================================================================== [SUCCESS] Took 85.62 seconds ===================================================================
Here is the terminal output with v1.57. It ends with an “Access is denied” error.
-------------------------------------------------------------------------------------------------------------------------Tool Manager: Installing platformio/framework-arduinoteensy @ ~1.157.0
Tool Manager: Error: Please read https://bit.ly/package-manager-ioerror
Tool Manager: Warning! Package Mirror: HTTPSConnectionPool(host='usc1.contabostorage.com', port=443): Max retries exceeded with url: /250040e607e8431abaff8727621872f9:pioregmirrorus/tools/8f/89/39b622d9fe2c679a048abbd8fe2cecb07f623bfaa74fbe8ad7e746b8919c/framework-arduinoteensy-1.157.220801.tar.gz (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1129)')))
Tool Manager: Looking for another mirror...
Tool Manager: framework-arduinoteensy@1.157.220801 has been installed!
PLATFORM: Teensy (4.17.0) > Teensy 4.0
- framework-arduinoteensy @ 1.157.220801 (1.57)
- tool-teensy @ 1.157.0 (1.57)
Access is denied.
*** [size] Error 1
============================================= [FAILED] Took 356.92 seconds =============================================
* The terminal process "C:\Users\myname\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
Note that if I do an upload instead of a build, it does not have any errors. Here’s the terminal output from that:
* Executing task: C:\Users\myname\.platformio\penv\Scripts\platformio.exe run --target upload
Found 107 compatible libraries
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-gui
Uploading .pio\build\teensy40\firmware.hex
=============================================================================== [SUCCESS] Took 5.62 seconds ===============================================================================
What does this build error mean?
