Hello PIO,
I have been using PIO to upload code to Teensy 3.6s all day long for over a year without a problem. Recently they started to fail, which would leave me with an unrecognized USB device on Windows 10. The only way I can recover from this is by disconnecting the T36 from my computer, restarting my computer, and then plugging the teensy back in.
If I use the teensyloader gui by itself to load the hex file I build with PIO, it works without a problem across 25+ uploads, but starting last night I typically get an unrecognized T36 after ~3-5 back to back uploads using PIO.
I am not doing anything crazy with the USB port. Just using it as a serial port. I have done a bunch of tests using two different teensys and I’m seeing what looks like random reboots (random is an assumption) in the middle of the upload when I upload via PIO, but not when I upload using the teensyloader gui in auto-mode and initiating the upload using the button on the teensy.
I have verbose teensy logs that I can share, but they are pretty big and I don’t see a way to upload text files to posts. I am happy to share them with anyone interested. I am seeing some pretty significant differences between the logs I take when uploading using the teensyloader gui, and the logs created when I log an upload using PIO.
For example, this is a selection from a log taken while uploading using the teensyloader gui:
09:00:11.849 (loader): Teensy Loader 1.51, begin program
09:00:11.933 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:00:11.945 (loader): Listening for remote control on port 3149
09:00:11.946 (loader): initialized, showing main window
09:00:12.195 (loader): HID/win32: vid:046D pid:B01E ver:0005
09:00:12.195 (loader): HID/win32: vid:046D pid:C53D ver:4301
09:00:12.196 (loader): HID/win32: vid:046D pid:C53D ver:4301
09:00:12.197 (loader): HID/win32: vid:046D pid:C53D ver:4301
09:00:12.197 (loader): HID/win32: vid:0000 pid:0000 ver:0000
09:00:12.198 (loader): HID/win32: vid:0000 pid:0000 ver:0000
09:00:20.212 (loader): Open File event
09:00:39.809 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:00:51.684 (loader): Device came online, code_size = 1048576
09:00:51.684 (loader): Board is: Teensy 3.6 (MK66FX1M0), version 1.03
09:00:51.715 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:00:51.718 (loader): set background IMG_ONLINE
09:00:51.932 (loader): HID/win32: HidD_GetPreparsedData ok, device still online
09:01:31.760 (loader): Auto Button event
09:01:31.760 (loader): Auto mode: enabled
09:01:31.790 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:01:31.804 (loader): elf appears to be for Teensy 3.6 (MK66FX1M0) (1048576 bytes)
09:01:31.804 (loader): elf binary data matches hex file
09:01:31.804 (loader): elf file is for Teensy 3.6 (MK66FX1M0)
09:01:31.806 (loader): begin operation
09:01:31.819 (loader): flash, block=0, bs=1024, auto=1
09:01:31.822 (loader): gauge old value = 0
09:01:31.822 (loader): flash, block=1, bs=1024, auto=1
09:01:31.824 (loader): gauge old value = 1
09:01:31.824 (loader): flash, block=2, bs=1024, auto=1
09:01:31.825 (loader): gauge old value = 2
09:01:31.826 (loader): flash, block=3, bs=1024, auto=1
09:01:32.148 (loader): gauge old value = 3
09:01:32.149 (loader): flash, block=4, bs=1024, auto=1
09:01:32.151 (loader): gauge old value = 4
09:01:32.154 (loader): flash, block=5, bs=1024, auto=1
09:01:32.155 (loader): gauge old value = 5
09:01:32.158 (loader): flash, block=6, bs=1024, auto=1
It continues on transferring blocks without issues until it finishes transferring blocks and ends the upload.
End of a teensyloader gui upload:
09:01:34.042 (loader): flash, block=227, bs=1024, auto=1
09:01:34.065 (loader): gauge old value = 227
09:01:34.071 (loader): sending reboot
09:01:34.073 (loader): begin wait_until_offline
09:01:34.190 (loader): offline, waited 2
09:01:34.208 (loader): end operation, total time = 2.401 seconds
09:01:34.225 (loader): set background IMG_REBOOT_OK
09:01:34.226 (loader): redraw timer set, image 14 to show for 1200 ms
09:01:34.268 (loader): HID/win32: vid:046D pid:B01E ver:0005
09:01:34.269 (loader): HID/win32: vid:046D pid:C53D ver:4301
09:01:34.270 (loader): HID/win32: vid:046D pid:C53D ver:4301
09:01:34.270 (loader): HID/win32: vid:0000 pid:0000 ver:0000
09:01:35.425 (loader): redraw, image 9
If I upload using PIO I get a log that looks like this:
09:12:59.410 (post_compile 4): Begin, version=1.51, high-res time
09:12:59.411 (loader): remote connection 1316 opened
09:12:59.413 (loader): remote cmd from 1316: “comment: Teensyduino 1.51 - WINDOWS (teensy_post_compile)”
09:12:59.413 (post_compile 4): Sending command: comment: Teensyduino 1.51 - WINDOWS (teensy_post_compile)
09:12:59.414 (loader): remote cmd from 1316: “status”
09:12:59.415 (loader): file changed
09:12:59.448 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:12:59.454 (post_compile 4): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.454 (post_compile 4): Sending command: dir:C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36
09:12:59.455 (loader): remote cmd from 1316: "dir:C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36"
09:12:59.456 (loader): remote cmd from 1316: “file:firmware.hex”
09:12:59.457 (post_compile 4): Sending command: file:firmware.hex
09:12:59.489 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:12:59.492 (loader): remote cmd from 1316: “status”
09:12:59.498 (post_compile 4): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.498 (post_compile 4): Disconnect
09:12:59.512 (loader): remote connection 1316 closed
09:12:59.512 (loader): remote connection 1316 opened
09:12:59.512 (post_compile 5): Running teensy_reboot: “C:\Users\email.platformio\packages\tool-teensy\teensy_reboot.exe” teensy_reboot.exe “-board=TEENSY36”
09:12:59.523 (reboot 6): Begin, version=1.51, high-res time
09:12:59.523 (reboot 6): LoadLibrary cfgmgr32 ok
09:12:59.523 (reboot 6): LoadLibrary ntdll ok
09:12:59.523 (reboot 6): found_usb_device, id=\?\usb#vid_16c0&pid_0483#6283920#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
09:12:59.523 (reboot 6): found_usb_device, loc=usb:1C0000/0/0/4/1/1 Port_#0001.Hub_#0013
09:12:59.523 (reboot 6): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0277
09:12:59.523 (reboot 6): found_usb_device, devinst=00000004
09:12:59.523 (reboot 6): add: loc=usb:1C0000/0/0/4/1/1, class=Ports, vid=16C0, pid=0483, ver=0277, serial=6283920, dev=\?\usb#vid_16c0&pid_0483#6283920#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
09:12:59.523 (reboot 6): comport_from_devinst_list attempt
09:12:59.523 (reboot 6): found Ports in classguid_list at index=0
09:12:59.523 (reboot 6): port COM11 found from devnode
09:12:59.523 (reboot 6): found_usb_device complete
09:12:59.525 (loader): remote connection 1512 opened
09:12:59.526 (loader): remote cmd from 1512: “show:arduino_attempt_reboot”
09:12:59.527 (reboot 6): found Teensy Loader, version 1.51
09:12:59.527 (reboot 6): Sending command: show:arduino_attempt_reboot
09:12:59.528 (loader): got request to show arduino rebooting message
09:12:59.528 (loader): remote cmd from 1512: “comment: Teensyduino 1.51 - WINDOWS (teensy_reboot)”
09:12:59.528 (loader): remote cmd from 1512: “status”
09:12:59.531 (reboot 6): Sending command: comment: Teensyduino 1.51 - WINDOWS (teensy_reboot)
09:12:59.535 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.535 (reboot 6): do_reset (serial) COM11
09:12:59.538 (loader): remote cmd from 1512: “status”
09:12:59.543 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.543 (reboot 6): status read, retry 0
09:12:59.652 (loader): remote cmd from 1512: “status”
09:12:59.656 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.656 (reboot 6): status read, retry 1
09:12:59.762 (loader): remote cmd from 1512: “status”
09:12:59.764 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.764 (reboot 6): status read, retry 2
09:12:59.869 (loader): remote cmd from 1512: “status”
09:12:59.871 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.871 (reboot 6): status read, retry 3
09:12:59.972 (loader): remote cmd from 1512: “status”
09:12:59.975 (reboot 6): Status: 1, 1, 0, 1, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:12:59.975 (reboot 6): status read, retry 4
09:13:00.082 (loader): remote cmd from 1512: “status”
09:13:00.082 (loader): Device came online, code_size = 1048576
09:13:00.082 (loader): Board is: Teensy 3.6 (MK66FX1M0), version 1.03
09:13:00.112 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:13:00.122 (loader): set background IMG_ONLINE
09:13:00.152 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:13:00.152 (loader): elf appears to be for Teensy 3.6 (MK66FX1M0) (1048576 bytes)
09:13:00.152 (loader): elf binary data matches hex file
09:13:00.162 (loader): elf file is for Teensy 3.6 (MK66FX1M0)
09:13:00.162 (loader): begin operation
09:13:00.174 (reboot 6): Status: 1, 1, 1, 2, 0, 1, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:00.175 (loader): flash, block=0, bs=1024, auto=1
09:13:00.175 (loader): gauge old value = 0
09:13:00.175 (loader): flash, block=1, bs=1024, auto=1
09:13:00.185 (loader): gauge old value = 1
09:13:00.185 (loader): flash, block=2, bs=1024, auto=1
09:13:00.185 (loader): gauge old value = 2
09:13:00.185 (loader): flash, block=3, bs=1024, auto=1
09:13:00.491 (loader): gauge old value = 3
09:13:00.493 (loader): remote cmd from 1512: “status”
09:13:00.494 (loader): flash, block=4, bs=1024, auto=1
09:13:00.494 (reboot 6): Status: 1, 1, 1, 2, 0, 1, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:00.520 (loader): gauge old value = 4
09:13:00.521 (loader): flash, block=5, bs=1024, auto=1
09:13:00.529 (loader): gauge old value = 5
09:13:00.530 (loader): flash, block=6, bs=1024, auto=1
09:13:00.530 (loader): gauge old value = 6
09:13:00.540 (loader): flash, block=7, bs=1024, auto=1
09:13:00.540 (loader): gauge old value = 7
09:13:00.540 (loader): flash, block=8, bs=1024, auto=1
09:13:00.550 (loader): gauge old value = 8
09:13:00.550 (loader): remote cmd from 1512: “status”
09:13:00.560 (loader): flash, block=9, bs=1024, auto=1
09:13:00.560 (loader): gauge old value = 9
09:13:00.560 (loader): flash, block=10, bs=1024, auto=1
09:13:00.561 (reboot 6): Status: 1, 1, 1, 2, 0, 1, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
The upload has reboots sprinkled throughout the transfer. Eventually after a few uploads I end up with a log that looks like this:
09:13:31.647 (post_compile 10): Begin, version=1.51, high-res time
09:13:31.647 (loader): remote connection 1488 opened
09:13:31.649 (loader): remote cmd from 1488: “comment: Teensyduino 1.51 - WINDOWS (teensy_post_compile)”
09:13:31.650 (post_compile 10): Sending command: comment: Teensyduino 1.51 - WINDOWS (teensy_post_compile)
09:13:31.650 (loader): remote cmd from 1488: “status”
09:13:31.651 (loader): file changed
09:13:31.684 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:13:31.690 (post_compile 10): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:31.690 (post_compile 10): Sending command: dir:C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36
09:13:31.691 (loader): remote cmd from 1488: "dir:C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36"
09:13:31.693 (post_compile 10): Sending command: file:firmware.hex
09:13:31.693 (loader): remote cmd from 1488: “file:firmware.hex”
09:13:31.725 (loader): File “firmware.hex”. 233428 bytes, 22% used
09:13:31.731 (loader): remote cmd from 1488: “status”
09:13:31.735 (post_compile 10): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:31.735 (post_compile 10): Disconnect
09:13:31.751 (loader): remote connection 1488 closed
09:13:31.751 (loader): remote connection 1488 opened
09:13:31.751 (post_compile 11): Running teensy_reboot: “C:\Users\email.platformio\packages\tool-teensy\teensy_reboot.exe” teensy_reboot.exe “-board=TEENSY36”
09:13:31.769 (reboot 12): Begin, version=1.51, high-res time
09:13:31.769 (reboot 12): LoadLibrary cfgmgr32 ok
09:13:31.769 (reboot 12): LoadLibrary ntdll ok
09:13:31.770 (reboot 12): found_usb_device, id=\?\usb#vid_16c0&pid_0483#6283920#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
09:13:31.770 (reboot 12): found_usb_device, loc=usb:1C0000/0/0/4/1/1 Port_#0001.Hub_#0013
09:13:31.770 (reboot 12): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0277
09:13:31.770 (reboot 12): found_usb_device, devinst=00000004
09:13:31.770 (reboot 12): add: loc=usb:1C0000/0/0/4/1/1, class=Ports, vid=16C0, pid=0483, ver=0277, serial=6283920, dev=\?\usb#vid_16c0&pid_0483#6283920#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
09:13:31.770 (reboot 12): comport_from_devinst_list attempt
09:13:31.770 (reboot 12): found Ports in classguid_list at index=0
09:13:31.770 (reboot 12): port COM11 found from devnode
09:13:31.770 (reboot 12): found_usb_device complete
09:13:31.771 (loader): remote connection 1596 opened
09:13:31.771 (loader): remote cmd from 1596: “show:arduino_attempt_reboot”
09:13:31.774 (reboot 12): found Teensy Loader, version 1.51
09:13:31.774 (reboot 12): Sending command: show:arduino_attempt_reboot
09:13:31.775 (loader): got request to show arduino rebooting message
09:13:31.776 (loader): remote cmd from 1596: “comment: Teensyduino 1.51 - WINDOWS (teensy_reboot)”
09:13:31.776 (loader): remote cmd from 1596: “status”
09:13:31.778 (reboot 12): Sending command: comment: Teensyduino 1.51 - WINDOWS (teensy_reboot)
09:13:31.782 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:31.782 (reboot 12): do_reset (serial) COM11
09:13:31.860 (loader): remote cmd from 1596: “status”
09:13:31.871 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:31.871 (reboot 12): status read, retry 0
09:13:31.973 (loader): remote cmd from 1596: “status”
09:13:31.977 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:31.977 (reboot 12): status read, retry 1
09:13:32.090 (loader): remote cmd from 1596: “status”
09:13:32.093 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.093 (reboot 12): status read, retry 2
09:13:32.199 (loader): remote cmd from 1596: “status”
09:13:32.201 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.201 (reboot 12): status read, retry 3
09:13:32.304 (loader): remote cmd from 1596: “status”
09:13:32.307 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.307 (reboot 12): status read, retry 4
09:13:32.424 (loader): remote cmd from 1596: “status”
09:13:32.428 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.428 (reboot 12): status read, retry 5
09:13:32.534 (loader): remote cmd from 1596: “status”
09:13:32.537 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.537 (reboot 12): status read, retry 6
09:13:32.644 (loader): remote cmd from 1596: “status”
09:13:32.647 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.647 (reboot 12): status read, retry 7
09:13:32.750 (loader): remote cmd from 1596: “status”
09:13:32.753 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.753 (reboot 12): status read, retry 8
09:13:32.860 (loader): remote cmd from 1596: “status”
09:13:32.863 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.863 (reboot 12): status read, retry 9
09:13:32.970 (loader): remote cmd from 1596: “status”
09:13:32.974 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:32.974 (reboot 12): status read, retry 10
09:13:33.077 (loader): remote cmd from 1596: “status”
09:13:33.080 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.080 (reboot 12): status read, retry 11
09:13:33.187 (loader): remote cmd from 1596: “status”
09:13:33.189 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.189 (reboot 12): status read, retry 12
09:13:33.304 (loader): remote cmd from 1596: “status”
09:13:33.307 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.307 (reboot 12): status read, retry 13
09:13:33.413 (loader): remote cmd from 1596: “status”
09:13:33.416 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.416 (reboot 12): status read, retry 14
09:13:33.524 (loader): remote cmd from 1596: “status”
09:13:33.527 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.527 (reboot 12): status read, retry 15
09:13:33.641 (loader): remote cmd from 1596: “status”
09:13:33.644 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.644 (reboot 12): status read, retry 16
09:13:33.750 (loader): remote cmd from 1596: “status”
09:13:33.753 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.753 (reboot 12): status read, retry 17
09:13:33.859 (loader): remote cmd from 1596: “status”
09:13:33.862 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.862 (reboot 12): status read, retry 18
09:13:33.968 (loader): remote cmd from 1596: “status”
09:13:33.971 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:33.971 (reboot 12): status read, retry 19
09:13:34.077 (loader): remote cmd from 1596: “status”
09:13:34.079 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.079 (reboot 12): status read, retry 20
09:13:34.182 (loader): remote cmd from 1596: “status”
09:13:34.185 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.185 (reboot 12): status read, retry 21
09:13:34.287 (loader): remote cmd from 1596: “status”
09:13:34.289 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.289 (reboot 12): status read, retry 22
09:13:34.391 (loader): remote cmd from 1596: “status”
09:13:34.394 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.394 (reboot 12): status read, retry 23
09:13:34.496 (loader): remote cmd from 1596: “status”
09:13:34.498 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.498 (reboot 12): status read, retry 24
09:13:34.600 (loader): remote cmd from 1596: “status”
09:13:34.603 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.603 (reboot 12): status read, retry 25
09:13:34.705 (loader): remote cmd from 1596: “status”
09:13:34.707 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.707 (reboot 12): status read, retry 26
09:13:34.809 (loader): remote cmd from 1596: “status”
09:13:34.812 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.812 (reboot 12): status read, retry 27
09:13:34.914 (loader): remote cmd from 1596: “status”
09:13:34.916 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:34.916 (reboot 12): status read, retry 28
09:13:35.028 (loader): remote cmd from 1596: “status”
09:13:35.031 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.031 (reboot 12): status read, retry 29
09:13:35.133 (loader): remote cmd from 1596: “status”
09:13:35.136 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.136 (reboot 12): status read, retry 30
09:13:35.238 (loader): remote cmd from 1596: “status”
09:13:35.240 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.240 (reboot 12): status read, retry 31
09:13:35.342 (loader): remote cmd from 1596: “status”
09:13:35.345 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.345 (reboot 12): status read, retry 32
09:13:35.447 (loader): remote cmd from 1596: “status”
09:13:35.449 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.449 (reboot 12): status read, retry 33
09:13:35.551 (loader): remote cmd from 1596: “status”
09:13:35.554 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.554 (reboot 12): status read, retry 34
09:13:35.666 (loader): remote cmd from 1596: “status”
09:13:35.670 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.670 (reboot 12): status read, retry 35
09:13:35.781 (loader): remote cmd from 1596: “status”
09:13:35.783 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.783 (reboot 12): status read, retry 36
09:13:35.885 (loader): remote cmd from 1596: “status”
09:13:35.888 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.888 (reboot 12): status read, retry 37
09:13:35.990 (loader): remote cmd from 1596: “status”
09:13:35.993 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:35.993 (reboot 12): status read, retry 38
09:13:36.095 (loader): remote cmd from 1596: “status”
09:13:36.097 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.097 (reboot 12): status read, retry 39
09:13:36.199 (loader): remote cmd from 1596: “status”
09:13:36.202 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.202 (reboot 12): status read, retry 40
09:13:36.304 (loader): remote cmd from 1596: “status”
09:13:36.306 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.306 (reboot 12): status read, retry 41
09:13:36.408 (loader): remote cmd from 1596: “status”
09:13:36.411 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.411 (reboot 12): status read, retry 42
09:13:36.523 (loader): remote cmd from 1596: “status”
09:13:36.525 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.525 (reboot 12): status read, retry 43
09:13:36.627 (loader): remote cmd from 1596: “status”
09:13:36.630 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.630 (reboot 12): status read, retry 44
09:13:36.732 (loader): remote cmd from 1596: “status”
09:13:36.734 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.734 (reboot 12): status read, retry 45
09:13:36.847 (loader): remote cmd from 1596: “status”
09:13:36.849 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.849 (reboot 12): status read, retry 46
09:13:36.951 (loader): remote cmd from 1596: “status”
09:13:36.954 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:36.954 (reboot 12): status read, retry 47
09:13:37.066 (loader): remote cmd from 1596: “status”
09:13:37.068 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:37.068 (reboot 12): status read, retry 48
09:13:37.170 (loader): remote cmd from 1596: “status”
09:13:37.173 (reboot 12): Status: 1, 1, 0, 3, 0, 0, C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36, firmware.hex
09:13:37.173 (reboot 12): status read, retry 49
09:13:37.275 (reboot 12): Teensy did not respond to a USB-based request to automatically reboot.
09:13:37.305 (loader): remote connection 1596 closed
09:13:37.308 (loader): remote connection 1488 closed
This will result in the problem I described. A teensy that is not recognized by Windows 10.
Device Manager:
Device USB\VID_0000&PID_0002\8&16d84b90&0&1 was not migrated due to partial or ambiguous match.
Last Device Instance Id: USB\VID_0000&PID_0002\7&11816842&0&4
Class Guid: {36fc9e60-c465-11cf-8056-444553540000}
Location Path:
Migration Rank: 0xF00000000000F100
Present: false
Status: 0xC0000451
Windows Event Viewer:
Error:
Info:
Warning:
I wanted to note that the timestamp on those messages are from last night, around the time I first saw the error. I have been recreating the problem all morning today, but that event log isn’t being updated. Perhaps that is expected, I don’t look at a lot of windows event logs.
platformio.ini:
[env:teensy36]
platform = teensy
board = teensy36
upload_protocol = teensy-gui
board_build.f_cpu = 72000000L
This is my verbose upload output for the last upload that caused the problem:
MethodWrapper([“checkprogsize”], [“.pio\build\teensy36\firmware.elf”])
arm-none-eabi-objcopy -O ihex -R .eeprom .pio\build\teensy36\firmware.elf .pio\build\teensy36\firmware.hex
RAM: [= ] 10.4% (used 27152 bytes from 262144 bytes)
Flash: [== ] 22.3% (used 233416 bytes from 1048576 bytes)
.pio\build\teensy36\firmware.elf :section size addr
.text 226272 0
.fini 4 226272
.ARM.exidx 8 226276
.usbdescriptortable 160 536805376
.dmabuffers 464 536805888
.usbbuffers 864 536806352
.data 7144 536807216
.bss 18520 536814360
.ARM.attributes 48 0
.comment 110 0
.debug_frame 4432 0
Total 258026
([“upload”], [“.pio\build\teensy36\firmware.hex”])
AVAILABLE: jlink, teensy-cli, teensy-gui
CURRENT: upload_protocol = teensy-gui
teensy_post_compile -file=firmware -path=“C:\Workspace\3_24_21_Gen3\Gen3_Source_Code\T36_Gen3_Sampler.pio\build\teensy36” -tools=C:\Users\email.platformio\packages\tool-teensy -board=TEENSY36 -reboot
Teensy did not respond to a USB-based request to enter program mode.
Please press the PROGRAM MODE BUTTON on your Teensy to upload your sketch.
From Troubleshooting common problems with the Teensy USB development board
Windows 7: Unknown Device (Code 43)
Windows “Code 43” is a mystery. Other devices, even Apple iPod, have experienced this problem. The solution seem to be be completely powering down, and if a latop, remove the battery for a few minutes. This same solution has been reported multiple times with success.
This code 43 error is a mystery. It might be related to laptops entering suspend mode? If you have any insight, please contact us!Pieter Rautenbach found a case where programming the wrong HEX file (compiled for a different chip) causes error 43.
Seems like code 43 is a mystery, so I wanted to share my information and see if anyone had any advice.
