Syntastic plugin for VIM
I wrote a VIM plugin to configure syntastic for pio projects, and I’m using .gcc-flags.json in the project root to do that. I was wondering which part of Pio generates that file, and when it gets updated. Is it part of the core, if so I would expect pio lib install to update it for example. If it’s part of the IDE that I have a problem :smiley:
(The plugin: GitHub - aars/syntastic-platformio: VIM plugin to configure syntastic for platformio projects.)
Thanks a lot! Great work!
I’ve just added project generator for VIM
Please re-test with Redirecting...
Please use in your plugin this command
platformio -f -c vim init --ide vim
It will re-generate all related dot files when platformio.ini is changed or new libraries are added.
I will test that.
I guess that would be necessary after adding platforms to platformio.ini. Does pio lib install update the dot files?
It doesn’t, you need to add PathWatchers for library storages. See
https://github.com/platformio/platformio-atom-ide/blob/develop/lib/project/indexer.js#L185
That commands does rebuild the dot files, right?
(I haven’t had time yet to check out the development Pio)
Yes, you’re right. You need the latest PIO Core 3.4
