Suppress warnings from library code?
I’m wondering if there’s a way to suppress warnings only from library source code. I know it’s possible to set build flags such as -w to ignore all warnings, but I want to see warnings from my own code while ignoring the spam I get from lib_deps.
Is there a way to do this without forking all my libraries and fixing their warnings?
I’d love to know if there is also, but I suspect the answer is fix the libraries. :frowning: The root issue being the Arduino IDE used to hide most of these warnings, so the library writers never saw them, so didn’t fix them (or make them! :laughing:) in the first place.
Oh, this looks like it might fit the bill…
Ah, if only library maintainers would respond to my pull requests. I’ve tried this before, with only a few polite folks bothering to respond, and even fewer kind souls taking the time to review and merge my changes.
In an ideal world, I agree this would be the best option.
Any luck with this? .
There are global flags and per project/src. See Redirecting...
@ivankravets I tried to use
src_build_flags =
    -Wall -Wpedantic -Werror
But still, getting warnings from libs, any idea why?
Libs defined via
    https://github.com/MrKalach/ESPAsyncWebServer.git
    https://github.com/bblanchon/ArduinoJson.git
full platformio.ini:
[env:nodemcu]
platform = espressif8266
board = nodemcu
src_build_flags =
    -std=c++11
extra_scripts =
    pre:data/gen_scripts/main.py
PlatformIO, version 4.3.1
When you run a verbose build (pio run -v, previos pio run -t clean of course), with what flags is the GCC/G++ compiler invoked when compiling library source files which throw a warning? Are these not un-settable via build_unflags?
Thank you @maxgerhardt! I’m new in platformio. I checked verbose output and the problem is: libs includes headers also contain warnings. It seems to in that case #pragma GCC diagnostic is the solution. Oooh, Arduino world :frowning:
GCC doesn’t report warnings for headers included as “system headers”.
To achieve this, you need to force platformio to include header directories with -isystem flag instead of -I. This can be done with a python script.
script.py
Import("projenv")
include_flags = []
for path in projenv["CPPPATH"]:
    if path != projenv["PROJECT_INCLUDE_DIR"]:
        include_flags.append(["-isystem", path])
projenv.Append(
    CXXFLAGS = include_flags
And then include the script in your ini.
platformio.ini
; src_build_flags will be only applied to your src_dir
src_build_flags = -Wall -Wextra -Wpedantic -Wconversion -Werror
extra_scripts = script.py
I tested it and it works, compiler no longer reports warnings for library code
I couldn’t get this to work.; I get “conflicting declarations” errors. I tried several modifications to this script:
  1. Also excluding PROJECT_SRC_DIR.
  2. Removing the paths that get added to CXXFLAGS from CPPPATH, because otherwise the -I flags for those paths are still generated in addition to the custom -isystem flags.
  3. Changing INCPREFIX to -isystem, removing PROJECT_XXX_DIR from CPPATH, and adding -I flags to CXXFLAGS only for PROJECT_XXX_DIR.
It is unhappy unless everything uses -I or everything uses -isystem.
Could you send the verbose output from pio?
pio run --verbose &> logs.txt
