There Any way to configure this board in order to use the 8 mb pls the deluxe 16 MB using platform IO or i need chage to the chineese dev toolking in order to aproach all he funcionality.
At simple eye looks like and amazing board even smaller that the normal dev board.
I wouldn’t see a reason why you couldn’t take a standard ESP32S3 board definition and use it with Arduino. The board is just a ESP32-S3FN8 after all. You could try it with the board “WEMOS LOLIN S3 PRO” (board = lolin_s3_pro). Check Serial output and available PSRAM with https://thingpulse.com/esp32-how-to-use-psram/.
Thanks for the update.
That was the missing flag on my project.
Right now is running fine on the memory check.
Total Heap: 355884
Free Heap: 330396
Total PSRAM: 8386279
Free PSRAM: 8386019
only have and additional doubt my provider sais the board has 512K ram however on hte total heay i can only see something related to 350K there another change to set the previous update to the right Memory and with this can be close the topic.
That ones very likely correct, on even ESP32 the RAM was actually instruction ram (IRAM) and data ram (DRAM), and only the DRAM portion could be used. Plus, all the RAM that the ESP-IDF and Arduino framework needs is substracted from the available heap memory memory too. It only gets “the rest”.
