Support for Seeeduino XIAO BLE board
Hi, I have this XIAO BLE board with nRF52 processor, and it seems that PlatformIO is not currently supporting it. I tried to follow the instructions of the following link https://medium.com/@alwint3r/working-with-seeed-xiao-ble-sense-and-platformio-ide-5c4da3ab42a3
to add XIAO BLE but after adding the following line to platform.py in .platformio/platforms/nordicnrf52 directory:
if board in (“nano33ble”, “nicla_sense_me”,“xiaoblesense”):
I get the error when starting PlatformIO:
Could not load recent projects
Server error: {“type”:“IndentationError”,“args”:[“unindent does not match any outer indentation level”,[“C:\Users\heikk\.platformio\platforms\nordicnrf52\platform.py”,63,56," if board in ("nano33ble", "nicla_sense_me"):\n"]],“message”:“unindent does not match any outer indentation level (platform.py, line 63)”}
What is wrong here, I am not familiar with python script ?
Would it be possible to officially add support for this BLE board in the next release of PlatformIO ?
You have not correctly indented the code with spaces like the surrounding code. If you look in the source code you see that line 63 is indented with 12 spaces to the left. That has to be conserved.
This is officially tracked in Board Request Seeedstudio XIAO BLE · Issue #142 · platformio/platform-nordicnrf52 · GitHub.
Thanks for help ( I did not know indentation matters in pyton !)
However now when I try compile and download my code I get this “File is not a zip file” message:
Checking size .pio\build\xiaoblesense\firmware.elf
RAM:   [===       ]  28.7% (used 68160 bytes from 237568 bytes)
Flash: [====      ]  40.1% (used 325380 bytes from 811008 bytes)
AVAILABLE: blackmagic, cmsis-dap, jlink, nrfjprog, nrfutil, sam-ba
CURRENT: upload_protocol = nrfutil
Looking for upload port...
Auto-detected: COM10
Forcing reset using 1200bps open/close on port COM10
Waiting for the new upload port...
Uploading .pio\build\xiaoblesense\firmware.hex
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\adafruit-nrfutil.py", line 12, in <module>
    cli()
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\click\core.py", line 1137, in __call__
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\click\core.py", line 1062, in main    rv = self.invoke(ctx)
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\click\core.py", line 1668, in invoke
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\click\core.py", line 1404, in invoke
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\click\core.py", line 763, in invoke
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\__main__.py", line 290, in serial
    dfu = Dfu(package, dfu_transport=serial_backend)
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu.py", line 66, in __init__
    self.manifest = Package.unpack_package(self.zip_file_path, self.unpacked_zip_path)
  File "C:\Users\heikk\.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\package.py", line 361, in unpack_package
    with ZipFile(package_path, 'r') as pkg:
  File "C:\Users\heikk\.platformio\python3\lib\zipfile.py", line 1257, in __init__
    self._RealGetContents()
  File "C:\Users\heikk\.platformio\python3\lib\zipfile.py", line 1324, in _RealGetContents
    raise BadZipFile("File is not a zip file")
zipfile.BadZipFile: File is not a zip file
*** [upload] Error 1
=========================================== [FAILED] Took 8.69 seconds ===========================================The terminal process "C:\Users\heikk\.platformio\penv\Scripts\platformio.exe 'run', '--target', 'upload'" terminated with exit code: 1.
Help ?
That’s weird. Please open a CLI and execute
pio run -t dfu -v
What does it output?
strong textOutput from that command: (If this is issue is not easy to solve, I can wait until we get official support for XIAO BLE (+Sense) boards )
PS C:\Arduino\MassageXIAO> pio run -t dfu -v
Processing xiaoblesense (platform: nordicnrf52; board: xiaoblesense; framework: arduino; lib_deps: arduino-libraries/ArduinoBLE@^1.3.1, pololu/DRV8835MotorShield@^2.1.0)
------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/xiaoblesense.html
PLATFORM: Nordic nRF52 (8.3.0) > Seeed XIAO BLE Sense
HARDWARE: NRF52840 64MHz, 232KB RAM, 792KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink)
  • framework-arduino-mbed @ 2.4.1
  • tool-adafruit-nrfutil @ 1.503.0 (5.3)
  • tool-sreccat @ 1.164.0 (1.64)
  • toolchain-gccarmnoneeabi @ 1.80201.190214 (8.2.1)
    Framework incompatible library C:\Users\heikk.platformio\packages\framework-arduino-mbed\libraries\LittleVGL
    More details about “Library Compatibility Mode”: Redirecting...
    Found 36 compatible libraries
    Scanning dependencies…
    |-- ArduinoBLE @ 1.3.1 (License: Unknown, Path: C:\Arduino\MassageXIAO.pio\libdeps\xiaoblesense\ArduinoBLE)
    |-- DRV8835MotorShield @ 2.1.0 (License: Unknown, Path: C:\Arduino\MassageXIAO.pio\libdeps\xiaoblesense\DRV8835MotorShield)
    |-- SPI (License: Unknown, Path: C:\Users\heikk.platformio\packages\framework-arduino-mbed\libraries\SPI)
    *** Do not know how to make File target `dfu’ (C:\Arduino\MassageXIAO\dfu). Stop.
    =========================================== [FAILED] Took 1.99 seconds ===========================================
Hm I see. I’ll test this personally and adapt as needed.
I’ve added support and created a pull request into the main PlatformIO repo.
Can you remove your
  • C:\Users\heikk\.platformio\packages\framework-arduino-mbed
  • C:\Users\heikk\.platformio\platforms\nordicnrf52
folders and use the platformio.ini in Add Xiao nRF52840 (Sense) board support by maxgerhardt · Pull Request #151 · platformio/platform-nordicnrf52 · GitHub?
Note that Git should be installed for this to work.
Note that if you have the regular Xiao BLE nRF52840 board with no “Sense” attached (so no IMU and microphone on the board), you should use board = xiaoble instead of board = xiaoblesense.
Thanks for your help ! It works perfectly now. Tested with XIAO BLE boad download
Can I conform this is intended to support this module ?
might be good if it showed up when you search for XIAO on supported boards
david
