Support for SEEED XIAO RP2040
I was wondering if it is possible to add support for the board SEEED XIAO RP2040, or if it is techincally already fully supported through some other board
JP
Already supported in Arduino-Pico (Earlephilhower) support, PicoProbe Debugging by maxgerhardt · Pull Request #36 · platformio/platform-raspberrypi · GitHub.
[env]
platform = https://github.com/maxgerhardt/platform-raspberrypi.git
board_build.core = earlephilhower
board_build.filesystem_size = 0.5m
[env:seeed_xiao_rp2040]
board = seeed_xiao_rp2040
; if using picoprobe SWD upload / debugging
;upload_protocol = picoprobe
;debug_tool = picoprobe
But I was under the understanding that the Pico does not have Bluetooth and Wifi but the Xiao RP2040 does? So it would still be nice if the board was supported properly or will it be able to work with one of the standard wifi and bluetooth libraries?
The Xiao RP2040 does not have WiFi + BT. That would be the Pico W. And the Xiao RP2040 is supported per docs and board definition.
Has support for this board been dropped?
results in
Resolving seeed_xiao_rp2040 dependencies…
UnknownBoard: Unknown board ID ‘seeed_xiao_rp2040’
at the time that I am typing this using PlatformIO 3.3.3 and specifying
platform = raspberrypi
Complete platformio.ini follows:
[env]
framework = Arduino
You’re not using the modified platform. Enable longpaths in Windows and git, then use platform = https://github.com/maxgerhardt/platform-raspberrypi.git. All of that is documented
https://arduino-pico.readthedocs.io/en/latest/platformio.html
ah, thank you. I had hoped that your previously cited PR #36 had finally made it into the stable platformio release by now…
