Hello, first off…
Love the new mbed integration!!
I am having so much fun with the STM32 and mbed platform…
I have a small query, I would like to add support for different upload_protocols in platformio
While St-link is good enough, I would like to debug my code while running.
I have a Generic STM32F103 board turned into a black magic probe.
Presently, I am using platformio to build the code and manually using the BMP to upload and debug using a terminal. I would like to integrate it into the IDE itself. If @ivankravets can throw a couple of suggestions and pointers how to add a new upload_protocol I would love to work and contribute to the IDE.
Thanks!!
Never mind!!
All it took was some good sleep and rest and some reading of the manual.
It all there…
(Always RTFM !!!)
For those who might have the same requirements later, this is what you should do.
- Specify “upload_protocol=gdb” in the platformio.ini file.
- Create a “upload.gdb” file in your project directory and load the appropriate commands
Sample upload.gdb file
target extended-remote /dev/cu.usbmodemBFDEA5F1
monitor swdp_scan
attach 1
load
quit
yes
The section after the attach command is where you can play around for debugging. Those more knowledgeable than I can pitch in and suggest more appropriate commands, ideas or uses.
Thank you again platformio team.
