Suddenly issue at upload esp32
Can anybody say what goes wrong? For month, the plattformio with VisualStudioCode works without problems.
Now i have issue to upload the firmware file.
In the Log below, is written that missing the bootloader file. That is right. In the path there are many files like named “bootloader_xxx_40m.bin”. If I change the filename to the searched file it works. But what is happend?
How can I solve the issue?
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM3
Uploading .pio\build\esp32doit-devkit-v1\firmware.bin
usage: esptool write_flash [-h] [--erase-all]
                           [--flash_freq {keep,40m,26m,20m,80m}]
                           [--flash_mode {keep,qio,qout,dio,dout}]
                           [--flash_size FLASH_SIZE]
                           [--spi-connection SPI_CONNECTION] [--no-progress]
                           [--verify] [--encrypt]
                           [--encrypt-files <address> <filename> [<address> <filename> ...]]
                           [--ignore-flash-encryption-efuse-setting]
                           [--compress | --no-compress]
esptool write_flash: error: argument <address> <filename>: [Errno 2] No such file or directory: 'C:\\Users\\Dirk\\.platformio\\packages\\framework-arduinoespressif32\\tools\\sdk\\esp32\\bin\\bootloader__40m.bin'
*** [upload] Error 2
my PlattformIO.ini
board_build.partitions = min_spiffs.csv
extends = esp32
platform = espressif32 ;https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
platform_packages = framework-arduinoespressif32 ; @https://github.com/espressif/arduino-esp32.git#idf-release/v4.4
	michalmonday/CSV Parser@^0.2.1
	bblanchon/ArduinoJson@^6.18.5
	esphome/ESPAsyncWebServer-esphome@^2.1.0
	thomasfredericks/Bounce2@^2.70
	ayushsharma82/WebSerial@^1.3.0
Seems like the computation of the flash mode is screwed up, there should be dio, qio etc in between the two __.
Do you manually modify the board_build.flash_mode, to e.g. an empty string? I can’t verify it because you use extends = esp32 but don’t show the [esp32] section.
As a general countermeasure, remove C:\Users\\Dirk\.platformio\packages\framework-arduinoespressif32 and C:\Users\Dirk\.platformio\platforms\espressif32 and rebuild the project.
Thank you.
My issue is solved.
I just removed C:\Users\Dirk\.platformio\platforms\espressif32 and rebuild the project.
For what it is worth I had this problem but using PIO remote.
You need to log into the remote machine and remove the packages like on the local machine… even though --force-remote worked fine…
Looks like it is forming the upload command incorrectly…
".../bin/python" ".../.platformio/packages/tool-esptoolpy/esptool.py" --chip esp32 --port "/dev/ttyUSB2" --baud 2000000 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 40m --flash_size detect .pio/build/server/firmware.bin
I believe there should be an 0x000000 before the filename…
