Successful Build Project Fails to Build on Two Other PlatformIO Installations
Hello, I have an interesting issue involving three different installations of platformIO. Only one of the installations allows me to successfully build a project on a Wemos D1, the other two have library failures despite copying over the entire project directory of the working build. Each of the three installations have identical platform.json files located under .platformio/platforms/espressif8266 (used a file diff utility to verify this) Here are the file contents:
  "name": "espressif8266",
  "title": "Espressif 8266",
  "description": "ESP8266 is a cost-effective and highly integrated Wi-Fi MCU with built-in TCP/IP networking software for IoT applications. ESP8266 integrates an enhanced version of Tensilica’s L106 Diamond series 32-bit processor and on-chip SRAM.",
  "homepage": "https://espressif.com/",
  "license": "Apache-2.0",
  "keywords": [
    "dev-platform",
    "Wi-Fi",
    "Xtensa",
    "106Micro"
  "engines": {
    "platformio": "^6"
  "repository": {
    "type": "git",
    "url": "https://github.com/platformio/platform-espressif8266.git"
  "version": "4.2.1",
  "frameworks": {
    "arduino": {
      "package": "framework-arduinoespressif8266",
      "script": "builder/frameworks/arduino.py"
    "esp8266-rtos-sdk": {
      "package": "framework-esp8266-rtos-sdk",
      "script": "builder/frameworks/esp8266-rtos-sdk.py",
      "description": "ESP8266 SDK based on FreeRTOS, a truly free professional grade RTOS for microcontrollers",
      "homepage": "https://github.com/espressif/ESP8266_RTOS_SDK",
      "title": "ESP8266 RTOS SDK"
    "esp8266-nonos-sdk": {
      "package": "framework-esp8266-nonos-sdk",
      "script": "builder/frameworks/esp8266-nonos-sdk.py",
      "description": "The non-OS SDK provides a set of application programming interfaces (APIs) for core ESP8266 functionalities such as data reception/transmission over Wi-Fi, TCP/IP stack functions, hardware interface functions and basic system management functions",
      "homepage": "https://github.com/espressif/ESP8266_NONOS_SDK",
      "title": "ESP8266 Non-OS SDK"
  "packages": {
    "toolchain-xtensa": {
      "type": "toolchain",
      "owner": "platformio",
      "version": "~2.100300.220621",
      "optionalVersions": ["~1.40802.0"]
    "framework-arduinoespressif8266": {
      "type": "framework",
      "optional": true,
      "version": "~3.30102.0"
    "framework-esp8266-rtos-sdk": {
      "optional": true,
      "version": ">=1.5.0-beta"
    "framework-esp8266-nonos-sdk": {
      "optional": true,
      "version": ">=2.1.0"
    "tool-esptool": {
      "type": "uploader",
      "version": "<2"
    "tool-esptoolpy": {
      "type": "uploader",
      "version": "~1.30000.0"
    "tool-mkspiffs": {
      "type": "uploader",
      "optional": true,
      "version": "~1.200.0"
    "tool-mklittlefs": {
      "type": "uploader",
      "optional": true,
      "version": "~1.203.0"
When building on the second install of platformIO, on another Mac computer, here is what is reported:
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/d1.html
PLATFORM: Espressif 8266 (4.2.1) > WEMOS D1 R1
HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash
 - framework-arduinoespressif8266 @ 3.30102.0 (3.1.2)
 - tool-esptool @ 1.413.0 (4.13)
 - tool-esptoolpy @ 1.30000.201119 (3.0.0)
 - toolchain-xtensa @ 2.100300.220621 (10.3.0)
Library Manager: Installing Adafruit_BME280_Library-master
Warning! Could not find the package with 'Adafruit_BME280_Library-master' requirements for your system 'darwin_x86_64'
Found 54 compatible libraries
|-- EasyDDNS @ 1.8.0
|-- TFT_eSPI @ 2.5.43
|-- avr-fast-shift @ 1.1.0
|-- Firmata @ 2.5.9
|-- PubSubClient @ 2.8.0
|-- Adafruit Unified Sensor @ 1.1.14
|-- ESP8266 and ESP32 OLED driver for SSD1306 displays @ 4.6.1
|-- Adafruit BME280 Library @ 2.2.4
|-- ESP8266WebServer @ 1.0.0+sha.61cc811
|-- Adafruit ILI9341 @ 1.6.1
|-- Time @ 1.6.1+sha.a18e50d
|-- ESP8266HTTPClient @ 1.2
|-- Adafruit GFX Library @ 1.11.11
|-- ArduinoOTA @ 1.0
|-- EEPROM @ 1.0
|-- ESP8266WiFi @ 1.0
|-- Wire @ 1.0
Compiling .pio/build/d1/lib1ff/Firmata/utility/SerialFirmata.cpp.o
Archiving .pio/build/d1/libe0e/libWire.a
Archiving .pio/build/d1/lib588/libESP8266 and ESP32 OLED driver for SSD1306 displays.a
Archiving .pio/build/d1/libe5a/libAdafruit BusIO.a
Archiving .pio/build/d1/lib7b9/libAdafruit BME280 Library.a
Compiling .pio/build/d1/libffc/ESP8266WebServer/ESP8266WebServer.cpp.o
Compiling .pio/build/d1/libffc/ESP8266WebServer/Parsing.cpp.o
Indexing .pio/build/d1/lib588/libESP8266 and ESP32 OLED driver for SSD1306 displays.a
Indexing .pio/build/d1/lib7b9/libAdafruit BME280 Library.a
Indexing .pio/build/d1/libe5a/libAdafruit BusIO.a
Indexing .pio/build/d1/libe0e/libWire.a
Compiling .pio/build/d1/lib08d/Adafruit GFX Library/Adafruit_GFX.cpp.o
Compiling .pio/build/d1/lib08d/Adafruit GFX Library/Adafruit_GrayOLED.cpp.o
Compiling .pio/build/d1/lib08d/Adafruit GFX Library/Adafruit_SPITFT.cpp.o
Compiling .pio/build/d1/lib08d/Adafruit GFX Library/glcdfont.c.o
In file included from .pio/libdeps/d1/Firmata/utility/SerialFirmata.cpp:20:
.pio/libdeps/d1/Firmata/utility/SerialFirmata.h:30:10: fatal error: SoftwareSerial.h: No such file or directory
* Looking for SoftwareSerial.h dependency? Check our library registry!
* CLI  > platformio lib search "header:SoftwareSerial.h"
* Web  > https://registry.platformio.org/search?q=header:SoftwareSerial.h
   30 | #include <SoftwareSerial.h>
compilation terminated.
Compiling .pio/build/d1/lib8d6/Adafruit ILI9341/Adafruit_ILI9341.cpp.o
*** [.pio/build/d1/lib1ff/Firmata/utility/SerialFirmata.cpp.o] Error 1
.pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.cpp: In member function 'void ESP8266WebServer::handleClient()':
.pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.cpp:168:43: warning: 'WiFiClient WiFiServer::available(uint8_t*)' is deprecated: Renamed to accept(). [-Wdeprecated-declarations]
  168 |     WiFiClient client = _server.available();
In file included from .pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.cpp:26:
/Users/rschaller/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiServer.h:85:14: note: declared here
   85 |   WiFiClient available(uint8_t* status = NULL) __attribute__((deprecated("Renamed to accept().")));
In file included from .pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.cpp:28:
.pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.h: In instantiation of 'size_t ESP8266WebServer::streamFile(T&, const String&) [with T = fs::File; size_t = unsigned int]':
.pio/libdeps/d1/ESP8266WebServer/src/detail/RequestHandlersImpl.h:114:41:   required from here
.pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.h:137:30: warning: 'size_t WiFiClient::write(Stream&)' is deprecated: use stream.sendHow(client...) [-Wdeprecated-declarations]
  137 |   return _currentClient.write(file);
In file included from .pio/libdeps/d1/ESP8266WebServer/src/ESP8266WebServer.cpp:27:
/Users/rschaller/.platformio/packages/framework-arduinoespressif8266/libraries/ESP8266WiFi/src/WiFiClient.h:75:10: note: declared here
   75 |   size_t write(Stream& stream);
I was told by an experienced member of the community that SoftwareSerial.h is part of the core and shouldn’t create any problems. There goes that word, shouldn’t :grinning:
On the third installation, Raspberry Pi5, here is what is reported:
Processing d1 (platform: espressif8266; board: d1; framework: arduino)
Library Manager: Installing ayushsharma82/EasyDDNS @ ^1.8.0
Unpacking  [####################################]  100%
Library Manager: EasyDDNS@1.8.0 has been installed!
Library Manager: Installing bodmer/TFT_eSPI @ ^2.5.43
Library Manager: TFT_eSPI@2.5.43 has been installed!
Library Manager: Installing adbancroft/avr-fast-shift @ ^1.1.0
Library Manager: avr-fast-shift@1.1.0 has been installed!
Library Manager: Installing firmata/Firmata @ ^2.5.9
Library Manager: Firmata@2.5.9 has been installed!
Library Manager: Installing knolleary/PubSubClient @ ^2.8
Library Manager: PubSubClient@2.8.0 has been installed!
Library Manager: Installing adafruit/Adafruit Unified Sensor @ ^1.1.14
Library Manager: Adafruit Unified Sensor@1.1.14 has been installed!
Library Manager: Installing thingpulse/ESP8266 and ESP32 OLED driver for SSD1306 displays @ ^4.6.1
Library Manager: ESP8266 and ESP32 OLED driver for SSD1306 displays@4.6.1 has been installed!
Library Manager: Installing adafruit/Adafruit BME280 Library @ ^2.2.4
Library Manager: Adafruit BME280 Library@2.2.4 has been installed!
Library Manager: Resolving dependencies...
Library Manager: Installing Adafruit BusIO
Library Manager: Adafruit BusIO@1.16.2 has been installed!
Library Manager: Installing git+https://github.com/esp8266/ESPWebServer.git
git version 2.39.5
Cloning into '/home/pi/.platformio/.cache/tmp/pkg-installing-6h6_jd56'...
remote: Enumerating objects: 36, done.
remote: Counting objects: 100% (36/36), done.
remote: Compressing objects: 100% (31/31), done.
remote: Total 36 (delta 0), reused 21 (delta 0), pack-reused 0 (from 0)
Receiving objects: 100% (36/36), 210.71 KiB | 784.00 KiB/s, done.
Library Manager: ESP8266WebServer@1.0.0+sha.61cc811 has been installed!
Library Manager: Installing adafruit/Adafruit ILI9341 @ ^1.6.1
Library Manager: Adafruit ILI9341@1.6.1 has been installed!
Library Manager: Installing Adafruit GFX Library
Library Manager: Adafruit GFX Library@1.11.11 has been installed!
Library Manager: Installing Adafruit STMPE610
Library Manager: Adafruit STMPE610@1.1.6 has been installed!
Library Manager: Installing Adafruit TouchScreen
Library Manager: Adafruit TouchScreen@1.1.5 has been installed!
Library Manager: Installing Adafruit TSC2007
Library Manager: Adafruit TSC2007@1.1.2 has been installed!
Library Manager: Installing Adafruit SH110X
Library Manager: Adafruit SH110X@2.1.11 has been installed!
Library Manager: Installing git+https://github.com/PaulStoffregen/Time.git
git version 2.39.5
Cloning into '/home/pi/.platformio/.cache/tmp/pkg-installing-51mr9lod'...
remote: Enumerating objects: 38, done.
remote: Counting objects: 100% (38/38), done.
remote: Compressing objects: 100% (27/27), done.
remote: Total 38 (delta 2), reused 25 (delta 0), pack-reused 0 (from 0)
Receiving objects: 100% (38/38), 26.01 KiB | 887.00 KiB/s, done.
Resolving deltas: 100% (2/2), done.
Library Manager: Time@1.6.1+sha.a18e50d has been installed!
Warning! Could not find the package with 'Adafruit_BME280_Library-master' requirements for your system 'linux_aarch64'
|-- EasyDDNS @ 1.8.0
|-- Firmata @ 2.5.9
|-- ArduinoOTA @ 1.0
|-- EEPROM @ 1.0
|-- Wire @ 1.0
Compiling .pio/build/d1/src/MotionBME280_v11.cpp.o
Generating LD script .pio/build/d1/ld/local.eagle.app.v6.common.ld
src/MotionBME280_v11.cpp:1:10: fatal error: Time.h: No such file or directory
* Looking for Time.h dependency? Check our library registry!
* CLI  > platformio lib search "header:Time.h"
* Web  > https://registry.platformio.org/search?q=header:Time.h
    1 | #include <Time.h>
*** [.pio/build/d1/src/MotionBME280_v11.cpp.o] Error 1
Compiling .pio/build/d1/lib46a/ESP8266WiFi/BearSSLHelpers.cpp.o
Any help on this confusing situation would be greatly appreciated - Rob
When libraries fail to detect their dependencies (such as Firmata does with SoftwareSerial) here, try changing around the lib_ldf_mode.
A difference in PlatformIO core version could also explain some differences if the platform version is the same.
On the two computers that fail to build the project, the plaformIO core ver. is 6.1.16 compare with 6.1.17b on the install with the successful build. Despite these version differences, I did a “pio upgrade” command on the two computers running 6.1.16 and it was reported that I’m running the latest. Perhaps the reason is that 17b is the latest for an Apple silicon platform. The other two are for an older Mac with Intel silicon, other than a quad core SoC, don’t know the specifics of the Pi5 processor.
Taking your suggestion, I changed the first failure I noted previously to “lib_def_mode = deep” and this fixed the issue with SoftwareSerial.h and I got a successful build. Thanks!!!
In the case with Time.h issue running on the PI5, I’m still having the same issue despite trying all the other options associated with the lib_def_mode setting. Not that it makes any difference, I did a full clean on the project before trying the different options. If you have any other ideas to look into, that would be greatly appreciated.
I have two concerns I need to look into:
  1. Why a change in platformio.ini is needed between different hosting platforms of VSC/PlatformIO
  2. I’m fairly new to PlatformIO and the library management has proved to be the most challenging topic for me so far. Rather than just trying a setting change in platformio.ini, I really want to understand these different options. This I can do from the link you originally sent me. - Rob
Time.h working on Mac vs not working on Linux is explainable: A conflict with the C library’s time.h header paired with a case-insensitive filesystem, it can’t distinguish Time.h from time.h (see here.
That’s why all libraries that actually need to use the PaulStoffregen/Time should include it as #include <TimeLib.h>, and not #include <Time.h>. Then it becomes unque again with respect to #include <time.h>.
I understand the conflict you mentioned about case insensitive filesystems. I do have <TimeLib.> being included. So what are your suggestions on the Mac platform, should I also remove <Time.h> ? Based on the differences when building the these two platforms, the Mac filesystem can tell the difference between <Time.h> and <time.h>
I just successfully built the project on the Pi5 by removing the <Time.h> include. I will now test functionality by FLASHING to an 8266
I hate to say this but after incorporating the change:
lib_ldf_mode = deep
to the platformio.ini file, I’m back to having issues again, only after doing one successful build yesterday. I’m very confused. I did a “full clean” before the second build that failed with the same error message I got initially when I posted to the community. Additionally TFT_eSPI is causing issues, this deals with display fonts. Ideas as to why I’m back to build errors? - Thanks
PLATFORM: Espressif 8266 (2024.9.0) > WEMOS D1 R1
 - framework-arduinoespressif8266 @ 2.7.8
 - tool-esptoolpy @ 4.7.6
 - toolchain-xtensa @ 2.40802.200502 (4.8.2)
LDF Modes: Finder ~ deep, Compatibility ~ soft
Found 40 compatible libraries
|-- EasyDDNS @ 1.8.0
|-- Firmata @ 2.5.9
|-- Adafruit Unified Sensor @ 1.1.15
|-- ArduinoOTA @ 1.0
|-- EEPROM @ 1.0
|-- Wire @ 1.0
Compiling .pio/build/d1/lib560/ESP8266WiFi/BearSSLHelpers.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/CertStoreBearSSL.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFi.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiAP.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiGeneric.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiGratuitous.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiMulti.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiSTA-WPS.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiSTA.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/ESP8266WiFiScan.cpp.o
src/MotionBME280_v11.cpp: In function 'void loop()':
src/MotionBME280_v11.cpp:1073:48: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
       if (((utcTime - haMotionDetectedTime) >= haMotionTimeout) && (haMotionDetectedFlag == 1)){
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiClient.cpp.o
src/MotionBME280_v11.cpp: In static member function 'static void UserFN::handleGotTime()':
src/MotionBME280_v11.cpp:2156:58: warning: format '%d' expects argument of type 'int', but argument 2 has type 'time_t {aka long int}' [-Wformat=]
   printf("Test: Local time offset = %d\n",localTimeOffset);
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiClientSecureBearSSL.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiServer.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiServerSecureAxTLS.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiServerSecureBearSSL.cpp.o
Compiling .pio/build/d1/lib560/ESP8266WiFi/WiFiUdp.cpp.o
Compiling .pio/build/d1/libf9a/ESP8266HTTPClient/ESP8266HTTPClient.cpp.o
Compiling .pio/build/d1/lib983/EasyDDNS/EasyDDNS.cpp.o
Compiling .pio/build/d1/lib6d0/SPI/SPI.cpp.o
Compiling .pio/build/d1/libe7a/LittleFS/LittleFS.cpp.o
Compiling .pio/build/d1/libe7a/LittleFS/lfs.c.o
Compiling .pio/build/d1/libe7a/LittleFS/lfs_util.c.o
Compiling .pio/build/d1/lib2e4/TFT_eSPI/TFT_eSPI.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/Firmata.cpp.o
Archiving .pio/build/d1/lib983/libEasyDDNS.a
In file included from .pio/libdeps/d1/TFT_eSPI/TFT_eSPI.cpp:16:0:
.pio/libdeps/d1/TFT_eSPI/TFT_eSPI.h:973:8: warning: #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available! [-Wcpp]
Archiving .pio/build/d1/lib6d0/libSPI.a
Indexing .pio/build/d1/lib983/libEasyDDNS.a
Indexing .pio/build/d1/lib6d0/libSPI.a
Compiling .pio/build/d1/lib1ff/Firmata/FirmataMarshaller.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/FirmataParser.cpp.o
Archiving .pio/build/d1/lib560/libESP8266WiFi.a
Indexing .pio/build/d1/lib560/libESP8266WiFi.a
Compiling .pio/build/d1/lib1ff/Firmata/utility/ArduinoBLE_UART_Stream.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/utility/BLEStream.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/utility/BluefruitLE_SPI_Stream.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/utility/EthernetClientStream.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/utility/EthernetServerStream.cpp.o
Compiling .pio/build/d1/lib1ff/Firmata/utility/WiFiStream.cpp.o
Compiling .pio/build/d1/lib474/PubSubClient/PubSubClient.cpp.o
Archiving .pio/build/d1/libf9a/libESP8266HTTPClient.a
Indexing .pio/build/d1/libf9a/libESP8266HTTPClient.a
Compiling .pio/build/d1/lib8ae/Adafruit Unified Sensor/Adafruit_Sensor.cpp.o
In file included from .pio/libdeps/d1/Firmata/utility/SerialFirmata.cpp:20:0:
.pio/libdeps/d1/Firmata/utility/SerialFirmata.h:30:28: fatal error: SoftwareSerial.h: No such file or directory
Compiling .pio/build/d1/lib588/ESP8266 and ESP32 OLED driver for SSD1306 displays/OLEDDisplay.cpp.o
In file included from .pio/libdeps/d1/TFT_eSPI/TFT_eSPI.h:979:0,
.pio/libdeps/d1/TFT_eSPI/Extensions/Smooth_font.h:47:23: error: 'SPIFFS' was not declared in this scope
   fs::FS   &fontFS  = SPIFFS;
In file included from .pio/libdeps/d1/TFT_eSPI/TFT_eSPI.cpp:6145:0:
.pio/libdeps/d1/TFT_eSPI/Extensions/Smooth_font.cpp: In member function 'void TFT_eSPI::loadFont(String, bool)':
.pio/libdeps/d1/TFT_eSPI/Extensions/Smooth_font.cpp:106:25: error: 'SPIFFS' was not declared in this scope
     if(spiffs) fontFS = SPIFFS;
.pio/libdeps/d1/PubSubClient/src/PubSubClient.cpp: In member function 'boolean PubSubClient::publish_P(const char*, const uint8_t*, unsigned int, boolean)':
.pio/libdeps/d1/PubSubClient/src/PubSubClient.cpp:523:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
     return (rc == expectedLength);
*** [.pio/build/d1/lib2e4/TFT_eSPI/TFT_eSPI.cpp.o] Error 1
