Stuck on how to use external .ini files in platformio.ini
Hi, I’m new to platformio.
I am trying to figure out how to add some extra flags to my platformio.ini file by importing them from an external file, similar to how #include works in c.
I’ve spent a while searching the docs and forum, but just getting myself confused about sections and envs etc
so far I have this platformio.ini file:.
  -D MY_TEST_LOCAL_DEF=22
[MySection]
extra_configs =
  D:/Projects/PlatformIO/Board_Configs/test_extras.ini
and this external test_extras.ini file:
[MySection]
  -D MY_TEST_EXTERN_DEF=33
and this is my Arduino code:
int x = MY_TEST_LOCAL_DEF;
int y = MY_TEST_EXTERN_DEF;
void setup() {}
void loop() {}
When I compile it says MY_TEST_EXTERN_DEF is undefined, so it’s not seeing the included file. Obviously I have a lot to learn, but was hoping someone would point me in the right direction.
Referring to the documentation, extra_configs must be placed into the [platformio] section. So the issue is placing it into the [MySection] section.
See extra_configs — PlatformIO latest documentation
Thanks sivar. I read through the docs again and came up with this:
platformio.ini:
[platformio]
extra_configs =
test_extras.ini:
Now, the compiler finds the external def, but not the one in platformio.ini.
The docs indeed say that if the group name matches they will be overwritten, although I assumed that just meant any flags of the same name, not that it would erase all of the flags and only use the external ones.
But it seems I have to use the same group name in the external file or my code doesn’t see the entries anyway.
Is there a way to have both sets of flags visible to my code?
I don’t know if interpolation and “extends” works with extra-config files. Give it a try…
Please see Interpolation of Values — PlatformIO latest documentation
and extends — PlatformIO latest documentation
Thanks Sivar for the hints. After quite some trial and error, Interpotation indeed turned out to be the solution:
platformio.ini
[platformio]
extra_configs =
  ${my_extras.build_flags}
test_extras.ini
[my_extras]
Arduino code:
void setup()
  Serial.printf("Vals = %d, %d\r\n", x, y);
void loop() {}
Result:
Vals = 22, 33
I don’t know if this is the only / best solution, but it’s doing what I want.
This allows me to compile for a variety of custom boards with different pinouts by only changing one ot two lines in the platformio.ini file.
