This is probably simple but I’m banging my head against the wall for sometime now. I’m trying to split a simple program into multiple files so I can add to it. I’m trying to logically split it into parts. If anyone can give me some pointers as to my mistakes that’d be awesome.
Main.cpp
#include "measure.h"
#include "LoRa.h"
void setup()
Serial.begin(9600); // STart serial for monitoring/debugging
Serial2.begin(9600); // Start 2nd serial interface for use with EBYTE module
Serial.println("Starting Reader");
Serial.println(Transceiver.init()); // This init will set the pinModes for you
Transceiver.PrintParameters(); // Display parameters of EBYTE (Can be changed. See example sketches)
//======LOOP=======================================================
void loop()
measure(); // Take measurements
delay(1000); // For testing. Will not exist in final
measure.cpp
// Takes various measurements, updates struct and sends to receiver
#include "MyData.h"
#include "LoRa.h"
unsigned long Last;
void measure()
// measure some data and save to the structure
MyData.Count++;
MyData.Bits = analogRead(A0);
MyData.Volts = MyData.Bits * (5.0 / 1024.0);
// Send struct
Transceiver.SendStruct(&MyData, sizeof(MyData));
// Let us know something was sent
Serial.print("Sending: ");
Serial.println(MyData.Count);
measure.h
#ifndef MEASURE_H
#define MEASURE_H
#include "LoRa.h"
void measure();
LoRa.cpp
// Somewhere to define/declare everything to do with the Ebyte E32 LoRa module
#include "EBYTE.h"
#include "LoRa.h"
#define PIN_RX 16 // Serial2 RX (connect this to the EBYTE Tx pin)
#define PIN_TX 17 // Serial2 TX pin (connect this to the EBYTE Rx pin)
#define PIN_M0 4 // D4 on the board (possibly pin 24)
#define PIN_M1 22 // D2 on the board (possibly called pin 22)
#define PIN_AX 21 // D15 on the board (possibly called pin 21)
// create the transceiver object, passing in the serial and pins
EBYTE Transceiver(&Serial2, PIN_M0, PIN_M1, PIN_AX);
LoRa.h
#ifndef LORA_H
#define LORA_H
#include "Arduino.h"
MyData.h
#ifndef MYDATA_H
#define MYDATA_H
struct DATA
unsigned long Count;
int Bits;
float Volts;
float Temp;
} MyData;
ERRORS
src\main.cpp: In function 'void setup()':
src\main.cpp:45:20: error: 'Transceiver' was not declared in this scope
src\measure.cpp: In function 'void measure()':
src\measure.cpp:18:5: error: 'Transceiver' was not declared in this scope
*** [.pio\build\esp32doit-devkit-v1\src\measure.cpp.o] Error 1
*** [.pio\build\esp32doit-devkit-v1\src\main.cpp.o] Error 1
Thanks!!
