I have found an old board with an ATmega128 and some nice driver ICs on it, so I would like to use the board for a current project. But: a simple test (using two onboard LEDs) drives me crazy ![]()
platformio.ini:
[env:ATmega128_test]
board = ATmega128
lib_compat_mode = strict
lib_archive = no
Code:
const uint8_t ledPin1 = 8; // LED 1 on PB0
const uint8_t ledPin2 = 10; // LED 2 on PB2
void setup( void)
DDRB |= (1<<PB0);
DDRB |= (1<<PB2);
pinMode( ledPin1, OUTPUT); // LEDs are active low
pinMode( ledPin2, OUTPUT);
void loop ( void) {}
Result:
Which LED will be switched on/off by the pinMode()-function calls varies by
- whether the DDRB register has been set before by bit manipulation,
- in which order the pinMode() calls are executed,
- whether another pinMode() call for another port pin follows.
Examples (the code given is the complete contents of setup()):
β only LED1 is on (error: LED2 should be on too)
β only LED2 is on (error: LED1 should be on too)
pinMode( ledPin1, INPUT);
β only LED2 is on (okay)
With one more code line
β no LED is on
The same with DDR register manipulation before:
DDRB |= (1<<PB2);
And so on⦠I have no clue what does happen here.
Is the
board = ATmega128
statement sufficient to let the Arduino core/libs to know what to do???
By the way, a piece of plain C++ code does work like expected:
#include <avr/io.h>
#include <util/delay.h>
int main( void)
DDRB |= _BV(0);
DDRB |= _BV(2);
while ( 1 )
PORTB &= ~_BV(0);
PORTB |= _BV(2);
_delay_ms( 500);
PORTB |= _BV(0);
PORTB &= ~_BV(2);
_delay_ms( 500);
Appreciate your help ![]()
Ralph
