The hex file generated by the same code in keil can be used normally, but the bin or hex file generated in platformIO cannot be used normally.
Not enough information to say anything about the problem. Post code and platformio.ini
for PIO project and any additional settings used in Keil.
我选择了STM32Cube开发STM32f103zet6单片机程序,platformio.ini设置如下:
[env:genericSTM32F103ZE]
platform = ststm32
board = genericSTM32F103ZE
framework = stm32cube
在VScode中build之后生成二进制bin文件,烧录到芯片中没有任何反应,但是用keil编译相同的代码生成hex文件烧录到芯片中有想要的效果,是为什么???:冷汗:
现在我知道可能是flash id的问题,在
C:\Users\Taylor\.platformio\packages\framework-stm32cube\platformio\ldscripts\STM32F103ZE_DEFAULT.ld
这个文件里找到
_estack = 0x20010000;
并且改为
_estack = 0x200010000;
编译后的结果可能就是能用的
还是不可以啊,而且我的platformio.ini不能修改,如果修改之后就编译不成功
Can you try a minimal example first. For example, just blink an LED. Does that work with platformio? What changes did you do to your platformio.ini that made it not compile anymore?
我试过这个了
默认的.ini配置如下:
platform = ststm32
程序如下:
#include<stm32f1xx_hal.h>
void SystemClock_Config(void);
void MX_GPIO_Init(void);
int main(void)
/* 复位所有外设,初始化Flash接口和系统滴答定时器 */
HAL_Init();
/* 配置系统时钟 */
SystemClock_Config();
MX_GPIO_Init();
while (1)
HAL_Delay(200);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_0,GPIO_PIN_RESET);
HAL_Delay(200);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_1,GPIO_PIN_RESET);
HAL_Delay(200);
HAL_GPIO_WritePin(GPIOC,GPIO_PIN_2,GPIO_PIN_RESET);
RCC_OscInitTypeDef RCC_OscInitStruct;
RCC_ClkInitTypeDef RCC_ClkInitStruct;
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; // 外部晶振,8MHz
RCC_OscInitStruct.HSEState = RCC_HSE_ON;
RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9; // 9倍频,得到72MHz主时钟
HAL_RCC_OscConfig(&RCC_OscInitStruct);
RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
|RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; // 系统时钟:72MHz
RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; // AHB时钟:72MHz
RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2; // APB1时钟:36MHz
RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; // APB2时钟:72MHz
HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2);
// HAL_RCC_GetHCLKFreq()/1000 1ms中断一次
// HAL_RCC_GetHCLKFreq()/100000 10us中断一次
// HAL_RCC_GetHCLKFreq()/1000000 1us中断一次
HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000); // 配置并启动系统滴答定时器
/* 系统滴答定时器时钟源 */
HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
/* 系统滴答定时器中断优先级配置 */
HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
GPIO_InitTypeDef GPIO_InitStruct;
/* GPIO 端口时钟使能 */
__HAL_RCC_GPIOC_CLK_ENABLE();
/* 配置GPIO输出电平 */
HAL_GPIO_WritePin(GPIOC, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
/*配置GPIO引脚 : PG6 PG7 */
GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
HAL_GPIO_Init(GPIOC, &GPIO_InitStruct);
也可以正常编译,
Processing genericSTM32F103ZE (platform: ststm32; board: genericSTM32F103ZE; framework: stm32cube)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103ZE.html
PLATFORM: ST STM32 5.5.0 > STM32F103ZE (64k RAM. 512k Flash)
HARDWARE: STM32F103ZET6 72MHz, 64KB RAM, 512KB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
PACKAGES: toolchain-gccarmnoneeabi 1.70201.0 (7.2.1), framework-stm32cube 2.0.181130
Found 11 compatible libraries
Compiling .pio\build\genericSTM32F103ZE\src\main.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_adc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_adc_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_can.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_cec.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_cortex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_crc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_dac.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_dac_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_dma.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_eth.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_flash.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_flash_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_gpio.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_gpio_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_hcd.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_i2c.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_i2s.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_irda.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_iwdg.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_mmc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_nand.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_nor.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_pccard.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_pcd.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_pcd_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_pwr.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_rcc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_rcc_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_rtc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_rtc_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_sd.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_smartcard.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_spi.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_spi_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_sram.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_tim.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_tim_ex.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_uart.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_usart.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_hal_wwdg.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_adc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_crc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_dac.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_dma.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_exti.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_fsmc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_gpio.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_i2c.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_pwr.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_rcc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_rtc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_sdmmc.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_spi.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_tim.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_usart.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_usb.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkHALDriver\Src\stm32f1xx_ll_utils.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkCMSISDevice\gcc\startup_stm32f103xe.o
Compiling .pio\build\genericSTM32F103ZE\FrameworkCMSISDevice\system_stm32f1xx.o
Archiving .pio\build\genericSTM32F103ZE\libFrameworkHALDriver.a
Archiving .pio\build\genericSTM32F103ZE\libFrameworkCMSISDevice.a
Indexing .pio\build\genericSTM32F103ZE\libFrameworkCMSISDevice.a
Indexing .pio\build\genericSTM32F103ZE\libFrameworkHALDriver.a
Linking .pio\build\genericSTM32F103ZE\firmware.elf
Checking size .pio\build\genericSTM32F103ZE\firmware.elf
Building .pio\build\genericSTM32F103ZE\firmware.hex
DATA: [ ] 0.1% (used 44 bytes from 65536 bytes)
PROGRAM: [ ] 0.5% (used 2720 bytes from 524288 bytes)
============================================ [SUCCESS] Took 15.36 seconds ============================================
但是把hex文件烧录到单片机没有任何反应
而相同的程序在keil中编译后的hex文件单片机能够正常运行
还有一个问题就是,我只要一修改“platformio.ini”,之后就不能成功编译了
修改后的.ini文件如下:
platform = ststm32
build_flags = -DF1
错误信息如下:
*** [.pio\build\genericSTM32F103ZE] C:\Users\Taylor\Documents\PlatformIO\Projects\32led\.pio\build\genericSTM32F103ZE:
============================================= [ERROR] Took 0.89 seconds =============================================
官方例程https://github.com/platformio/platform-ststm32/tree/master/examples/stm32cube-hal-blink和这个一样,但就是烧录到单片机内没有任何反应
Your example cannot work without the interrupt handlers.
void SysTick_Handler(void)
HAL_IncTick();
void NMI_Handler(void)
void HardFault_Handler(void)
while (1) {}
void MemManage_Handler(void)
while (1) {}
void BusFault_Handler(void)
while (1) {}
void UsageFault_Handler(void)
while (1) {}
void SVC_Handler(void)
void DebugMon_Handler(void)
void PendSV_Handler(void)
SysTick is never incremented so your firmware always hangs up in HAL_Delay()
. See platform-ststm32/main.c at a792e9705848629e6a5e24d66a7b2bed63b1f667 · platformio/platform-ststm32 · GitHub
Adding -DF1
is done in the official example’s platformio.ini
: platform-ststm32/platformio.ini at master · platformio/platform-ststm32 · GitHub
You did check this at the pin
right?
