Hi!
- I made a bootloader for stm32 on Cube IDE.
- I made a firmware that blink an LED on Cube IDE.
- I uploaded the firmware using my bootloader. It works well.
- Now I want to make also firmware on Arduino Framework. Here is my code:
main code:
ini:
my ld file:
Bootloader runs code from address 0x08010000.
Build log:
Processing blackpill_f411ce (platform: ststm32; board: blackpill_f411ce; framework: arduino; upload_protocol: stlink; debug_tool: stlink; board_build.f_cpu: 72000000L; board_build.offset:
0x10000; board_upload.offset_address: 0x8010000; board_build.ldscript: “$PROJECT_DIR\linker.ld”; build_unflags: -DVECT_TAB_ADDR; build_flags: -Wl,–defsym=LD_MAX_DATA_SIZE=0x20000 -Wl,–defsym=LD_MAX_SIZE=0x50000 -Wl,–defsym=LD_FLASH_OFFSET=0x10000, -DVECT_TAB_ADDR=0x8010000)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: Redirecting...
PLATFORM: ST STM32 (14.2.0) > WeAct Studio BlackPill V2.0 (STM32F411CE)
HARDWARE: STM32F411CEU6 72MHz, 128KB RAM, 512KB Flash
DEBUG: Current (stlink) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-arduinoststm32 @ 4.20000.210603 (2.0.0)
- framework-cmsis @ 2.50700.210515 (5.7.0)
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Found 10 compatible libraries
Scanning dependencies…
MethodWrapper([“checkprogsize”], [“.pio\build\blackpill_f411ce\firmware.elf”])
RAM: [ ] 0.7% (used 852 bytes from 131072 bytes)
Flash: [ ] 2.2% (used 11444 bytes from 524288 bytes)
.pio\build\blackpill_f411ce\firmware.elf :
section size addr
.isr_vector 408 134283264
.text 9880 134283672
.rodata 1424 134293552
.ARM.extab 0 134294976
.ARM 8 134294976
.preinit_array 0 134294984
.init_array 16 134294984
.fini_array 8 134295000
.data 140 536870912
.bss 712 536871052
._user_heap_stack 1540 536871764
.ARM.attributes 48 0
.comment 102 0
.debug_frame 1320 0
Total 15606
This code doesn’t work. I tried connecting in Debug mode. It seems that HAL_GetTick does not work. Tell me what could be the problem?
