Hi all, A VScode noob here trying to understand why my marlin in not compiling.
I bought myself an ender 3 a while ago, and recently upgraded to a skr mini e3 V1.2, and a bltouch. to make it all work i needed to update the firmware, so that is what i am doing right now.
I followed this turtorial, and no problems, till i wanted to compile the whole thing.
i have also tried reinstalling platformIO and VSCode but without succes.
this is my error code:
> Executing task: C:\Users\Henri\.platformio\penv\Scripts\pio.exe run <
Processing STM32F103RC_btt_512K (platform: ststm32@~6.1; board: genericSTM32F103RC; framework: arduino)
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
'CC' is not recognized as an internal or external command,
operable program or batch file.
CalledProcessError: Command 'CC -DTARGET_STM32F1 -D__MARLIN_FIRMWARE__ -DHAVE_SW_SERIAL -DDEBUG_LEVEL=0 -DSS_TIMER=4 -DSTM32_FLASH_SIZE=512 -D__MARLIN_DEPS__ -w -dM -E -x c++ buildroot/share/PlatformIO/scripts/common-dependencies.h' returned non-zero exit status 1.:
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 168:
env.SConscript(item, exports="env")
File "C:\Users\Henri\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 598:
File "C:\Users\Henri\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Script\SConscript.py", line 287:
File "C:\AAA\Marlin\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 286:
apply_features_config()
File "C:\AAA\Marlin\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 118:
if not env.MarlinFeatureIsEnabled(feature):
File "C:\Users\Henri\.platformio\packages\tool-scons\scons-local-4.0.1\SCons\Environment.py", line 219:
File "C:\AAA\Marlin\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 262:
load_marlin_features()
File "C:\AAA\Marlin\buildroot\share\PlatformIO\scripts\common-dependencies.py", line 250:
define_list = subprocess.check_output(cmd, shell=True).splitlines()
File "C:\Users\Henri\.platformio\python3\lib\subprocess.py", line 411:
**kwargs).stdout
File "C:\Users\Henri\.platformio\python3\lib\subprocess.py", line 512:
output=stdout, stderr=stderr)
======================================================================================================== [FAILED] Took 0.57 seconds ========================================================================================================
Environment Status Duration
STM32F103RC_btt_512K FAILED 00:00:00.568
=================================================================================================== 1 failed, 0 succeeded in 00:00:00.568 ===================================================================================================The terminal process "C:\Users\Henri\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
Compiling Marlin apparently has the apparently non-documented requirement that you need to have a compiler (gcc) installed in your system a quirk in Windows related to finding the compiler executable correctly, which may be related to the PlatformIO core, but can still be solved by installing GCC globally.
This was already covered in PlatformIO cannot compile Marlin for the LPC1769 environment - #2 by maxgerhardt.
I have downloaded and added this to the PATH and restarted my pc:
C:\Program Files (x86)\mingw-w64\
still does not work. did i fill it in correctly?
You must add the folder which contains the gcc executable.
In my case that would be C:\Program Files\mingw-w64\x86_64-8.1.0-posix-seh-rt_v6-rev0\mingw64\bin but it varies from user to user depending which installation options were chosen.
Check that by adding that to the path, then opening a terminal window (Windows+R -> cmd.exe) and typing gcc --version. It the command is found, it worked.
Then restart VSCode and retry.
Ah! that makes sense. i have changed it and now it says this:
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/genericSTM32F103RC.html
PLATFORM: ST STM32 (6.1.1) > STM32F103RC (48k RAM. 256k Flash)
HARDWARE: STM32F103RCT6 72MHz, 48KB RAM, 512KB Flash
DEBUG: Current (blackmagic) External (blackmagic, jlink, stlink)
- framework-arduinoststm32-maple 2.10000.200103 (1.0.0)
- tool-stm32duino 1.0.2
Converting Marlin.ino
'arm-none-eabi-g++' is not recognized as an internal or external command,
*** Error 1
AssertionError: :
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\main.py", line 170:
File "C:\users\henri\.platformio\platforms\ststm32@6.1.1\builder\main.py", line 98:
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 61:
env.ProcessProgramDeps()
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 127:
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\platformio.py", line 339:
env.ConvertInoToCpp()
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\piomisc.py", line 239:
out_file = c.convert(ino_nodes)
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\piomisc.py", line 91:
return self.process(contents)
File "C:\users\henri\.platformio\penv\lib\site-packages\platformio\builder\tools\piomisc.py", line 112:
assert self._gcc_preprocess(contents, out_file)
======================================================================================================== [FAILED] Took 0.81 seconds ========================================================================================================
STM32F103RC_btt_512K FAILED 00:00:00.809
=================================================================================================== 1 failed, 0 succeeded in 00:00:00.809 ===================================================================================================The terminal process "C:\Users\Henri\.platformio\penv\Scripts\pio.exe 'run'" terminated with exit code: 1.
On a sidenote, are you using the latest Marlin from GitHub - MarlinFirmware/Marlin: Marlin is an optimized firmware for RepRap 3D printers based on the Arduino platform. Many commercial 3D printers come with Marlin installed. Check with your vendor if you need source code for your specific machine. or are you using some other repository?
Hm that’s weird. Please remove the folder C:\Users\Henri\.platformio\pacakges\toolchain-gccarmnoneeabi and retry the build. I suspect the binary in there got somehow corrupted (in bin\arm-none-eabi-g++.exe.
i used this guide to clone it from github: To clone Marlin in VSCode via PlatformIO follow these steps:
- click the alien icon on the left
- click Clone Git Project
- paste “GitHub - MarlinFirmware/Marlin: Marlin is an optimized firmware for RepRap 3D printers based on the Arduino platform. | Many commercial 3D printers come with Marlin installed. Check with your vendor if you need source code for your specific machine.”
- hit enter
- save it
- after it is done downloading, click open on the popup (bottom right)
it is now working after deleting the folder!
thanks for your help and time!
