millis() HAL_GetTick() functions return zero in minimal function. Same function works fine with Atmel device. Tested both the Bluepill and the Nucleo F103RB with the same result. I am sure it is something I overlooked. Any thoughts … tom
We need to see your full platformio.ini, the code, the expected behaviour and the actual behaviour in order to be remotely able to help you.
