As I have trouble using Arduino Wire library for slave;
How do people solve I2C communications without Arduino?
are there some libraries or examples that works without Arduino framework, that are easy to implement?
Whenever I have i2c problems to solve, my first port of call is to shove a logic analyser into the circuit.
You can then decide the communications and see exactly what is being communicated.
AZ Delivery have a cheap, eight channel one on Amazon, but similar models are all over the place. The AZ one is the one I have, they are a reliable company to deal with.Also, most items have free EU delivery, sadly the UK is no longer in the EU. ![]()
Obviously, you have a scope so this reply is probably not all that helpful. Sorry!
Once you see and decide the Comms, it’s a lot easier to work out what the code might be doing!
HTH
Cheers,
Norm.
I have the scope and Saleae Logic pro 16 but once the chip/I2C library goes bananas and gets stuck pulling the pin low permanently - that does not help.
Luckily I have the issue confirmed, and ST is working on it.
