Hello everyone,
I’m back with some more automated builds issues using PlatformIO for Zephyr on STM32 following the update to PIO 6.1.16 (worked fine in 6.1.15):
Linking .pio/build/nucleo_f767zi/zephyr/firmware-pre0.elf
/home/runner/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.bfd: GNU-style constructors required but STATIC_INIT_GNU not enabled
/home/runner/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.bfd: warning: .pio/build/nucleo_f767zi/zephyr/firmware-pre0.elf has a LOAD segment with RWX permissions
/home/runner/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/12.3.1/../../../../arm-none-eabi/bin/ld.bfd: /home/runner/.platformio/packages/toolchain-gccarmnoneeabi/arm-none-eabi/lib/thumb/v7e-m/nofp/libc.a(libc_a-fini.o): in function `__libc_fini_array':
(.text.__libc_fini_array+0x1c): undefined reference to `_fini'
The config files:
Do you know if something changed on your end regarding this?
