I am using PlatformIO VSCode in Windows 10 professional.
And my configuration as follows:
Software:
Arduino framework
self defined board .json file which modified from the official nucleo_f030r8.json;
self defined variants files which also modified from above;
Hardware:
self designed board with STM32F030K6T6 mounted;
J-Link v10 PRO with SWD port connected to board;
The problem is upload success but when I trying to debug the blinky demo, the breakpoint never hit, and board LED on PA1 not blinking, but led on J-LINK blinking seems that it working.
The researching I have done:
Running a blinky demo in KEIL MDK 5 env, it works. hardware design problem and/or J-LINK hardware or connection problem excluded;
Trying replace J-LINK with ST-LINK/V2, modified related config in platformio.ini, also upload success but not working.
Debug trace:
Processing custom_f030k6 (framework: arduino; platform: ststm32; board: custom_f030k6)
Verbose mode can be enabled via
-v, --verboseoption
CONFIGURATION: //docs.platformio.org/page/boards/ststm32/custom_f030k6.html
PLATFORM: ST STM32 > Self defined F030K6
HARDWARE: STM32F030K6T6 48MHz 4KB RAM (32KB Flash)
DEBUG: CURRENT(jlink) EXTERNAL(blackmagic, jlink, stlink)
Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
Collected 13 compatible libraries
Scanning dependencies…
Checking size .pioenvscustom_f030k6/firmware.elf
Memory Usage → bit.ly/pio-memory-usage
DATA: [= ] 7.9% (used 324 bytes from 4096 bytes)
PROGRAM: [== ] 18.9% (used 6180 bytes from 32768 bytes)
[SUCCESS] Took 7.08 seconds
Reading symbols from f:/MyProj/Ardu/Firm/.pioenvs/custom_f030k6/firmware.elf…
done.
PlatformIO Unified Debugger > ht/bit.ly/pio-debug
SEGGER J-Link GDB Server V6.32h Command Line Version
JLinkARM.dll V6.32h (DLL compiled Jul 5 2018 18:11:19)
Command line: -singlerun -if SWD -select USB -device STM32F030K6 -port 2331
-----GDB Server start settings-----
GDBInit file: none
GDB Server Listening port: 2331
SWO raw output listening port: 2332
Terminal I/O port: 2333
Accept remote connection: localhost only
Generate logfile: off
Verify download: off
Init regs on start: off
Silent mode: off
Single run mode: on
Target connection timeout: 0 ms
------J-Link related settings------
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
------Target related settings------
Target device: STM32F030K6
Target interface: SWD
Target interface speed: 4000kHz
Target endian: littleConnecting to J-Link…
J-Link is connected.
Firmware: J-Link V10 compiled Jun 27 2018 10:57:29
Hardware: V10.10
S/N: *******
Feature(s): FlashBP, GDB, FlashDL, JFlash, RDI
Checking target voltage…
Target voltage: 3.33 V
Listening on TCP/IP port 2331
Connecting to target…Connected to target
Waiting for GDB connection…Connected to 127.0.0.1
Reading all registers
Received monitor command: halt
Halting target CPU…
…Target halted (PC = 0x080002CC)
Received monitor command: resetWWDG_IRQHandler () at C:\users\ahe.platformio\packages\framework-arduinoststm32\STM32\system\Drivers\CMSIS\Device\ST\STM32F0xx\Source\Templates\gcc\startup_stm32f030x6.s:123
123 b Infinite_Loop
Temporary breakpoint 1 at 0x800025e: file C:\users\ahe.platformio\packages\framework-arduinoststm32\STM32\cores\arduino\main.cpp, line 55.
Resetting targetLoading section .isr_vector, size 0xc0 lma 0x8000000
Loading section .text, size 0x17a4 lma 0x80000c0
Loading section .rodata, size 0x7c lma 0x8001864
Loading section .init_array, size 0x8 lma 0x80018e0
Loading section .fini_array, size 0x4 lma 0x80018e8
Loading section .data, size 0x4 lma 0x80018ec
Start address 0x800027c, load size 6384
Resetting targetWriting register (PC = 0x0800027C)
Halting target CPU…
…Target halted (PC = 0x0800027C)
Transfer rate: 1246 KB/sec, 1064 bytes/write.
Resetting targetPlatformIO: Initialization completed
Resetting target
PlatformIO: Resume the execution todebug_init_break = tbreak main
Starting target CPU…
Related files
main.cpp
#ifdef LED_BUILTIN
#undef LED_BUILTIN
#define LED_BUILTIN PA1
void setup()
// initialize LED digital pin as an output.
pinMode(LED_BUILTIN, OUTPUT);
void loop()
// turn the LED on (HIGH is the voltage level)
// wait for a second
delay(1000);
// turn the LED off by making the voltage LOW
delay(1000);
Platformio.ini
[env:custom_f030k6]
platform = ststm32
board = custom_f030k6
;nucleo_f030r8
; change microcontroller
board_build.mcu = stm32f030k6t6
board_build.variant = custom_030k6
debug_tool = jlink
; SWD interface
upload_protocol = jlink
custom_f030k6.json
"build": {
"cpu": "cortex-m0",
"extra_flags": "-DSTM32F030x6",
"f_cpu": "48000000L",
"mcu": "stm32f030k6t6",
"variant": "custom_f030k6"
"debug": {
"default_tools": [
"stlink"
"jlink_device": "STM32F030K6",
"openocd_board": "st_nucleo_f0",
"openocd_target": "stm32f0x",
"svd_path": "STM32F030.svd"
"frameworks": [
"arduino",
"mbed",
"stm32cube"
"name": "Self defined F030K6",
"upload": {
"maximum_ram_size": 4096,
"maximum_size": 32768,
"protocol": "stlink",
"protocols": [
"jlink",
"stlink",
"blackmagic",
"mbed"
"url": "developer.mbed.org/platforms/ST-Nucleo-F030R8/",
"vendor": "ST"
