When I try to upload any code, I get this error:
Checking size .pio/build/bluepill_f103c8_128k/firmware.elf
RAM: [ ] 3.8% (used 780 bytes from 20480 bytes)
Flash: [= ] 7.3% (used 9604 bytes from 131072 bytes)
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, serial, stlink
CURRENT: upload_protocol = serial
Looking for upload port...
Using manually specified: /dev/cu.wchusbserial14130
Uploading .pio/build/bluepill_f103c8_128k/firmware.bin
Failed to init device.
stm32flash Arduino_STM32_0.9
http://github.com/rogerclarkmelbourne/arduino_stm32
Using Parser : Raw BINARY
Interface serial_posix: 115200 8E1
*** [upload] Error 1
this is my platformio.ini-file:
[env:bluepill_f103c8_128k]
platform = ststm32
board = bluepill_f103c8_128k
upload_port = /dev/cu.wchusbserial14130
monitor_port = /dev/cu.wchusbserial14130
I already tried:
- several bluepill-boards
- different Serial-USB-adapter
- put the board into serial-mode (Boot0=1, Boot1=0)
I run VScode on OSX Big sur (patched sur tbh). What could be the problem? Did I miss something?
Thank you in advice
