When I try to run the platformio project check, it fails, complaining about some standard library file. Any suggestions?
The error message (full log here https://controlc.com/630b3fcc):
Error: Found a breaking defect 'syntax error' in C:\Users\user\.platformio\packages\toolchain-gccarmnoneeabi@1.70201.0\arm-none-eabi\include\c++\7.2.1\bits\exception_ptr.h:150
Please note: check results might not be valid!
platformio.ini:
[env:my_env]
platform = ststm32
extra_scripts = extra_script.py
board = weact_mini_h750vbtx
build_type = debug
debug_tool = stlink
upload_protocol = stlink
debug_build_flags = -O0 -ggdb3 -g3
board_build.ldscript = STM32H750VBTX_FLASH.ld
monitor_port = COM6
lib_archive = no
cube_ide
serial_packets
-fmax-errors=5
-mfpu=fpv5-sp-d16
-mfloat-abi=hard
-Wl,-Map,${BUILD_DIR}/firmware.map
-mthumb
-D DEBUG
-D USE_HAL_DRIVER
-DSTM32_THREAD_SAFE_STRATEGY=4
-fstack-usage
-std=gnu11
-Ilib/cube_ide/Core/Inc
-Ilib/cube_ide/Core/ThreadSafe
-Ilib/cube_ide/Drivers/CMSIS/Device/ST/STM32H7xx/Include
-Ilib/cube_ide/Drivers/CMSIS/Include
-Ilib/cube_ide/Drivers/STM32H7xx_HAL_Driver/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Class/CDC/Inc
-Ilib/cube_ide/Middlewares/ST/STM32_USB_Device_Library/Core/Inc
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2/Include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/include
-Ilib/cube_ide/Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F
-Ilib/cube_ide/USB_DEVICE/App
-Ilib/cube_ide/USB_DEVICE/Target
-D CONFIG_MAX_PACKET_DATA_LEN=100
-D CONFIG_MAX_PENDING_COMMANDS=5
