Platformio updated to the latest platform-ststm32 from a few days ago and now it does not work with RTC library (see error output bellow). What’s the problem and how should I solve it?
Thanks in advance
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:77:17: error: 'HOUR_FORMAT_12' was not declared in this scope
77 | HOUR_12 = HOUR_FORMAT_12,
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:78:17: error: 'HOUR_FORMAT_24' was not declared in this scope
78 | HOUR_24 = HOUR_FORMAT_24
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:82:12: error: 'HOUR_AM' was not declared in this scope; did you mean 'HOUR_24'?
82 | AM = HOUR_AM,
| HOUR_24
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:83:12: error: 'HOUR_PM' was not declared in this scope; did you mean 'HOUR_24'?
83 | PM = HOUR_PM
| HOUR_24
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:87:28: error: 'OFF_MSK' was not declared in this scope
87 | MATCH_OFF = OFF_MSK, // Never
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:88:28: error: 'SS_MSK' was not declared in this scope
88 | MATCH_SS = SS_MSK, // Every Minute
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:89:28: error: 'SS_MSK' was not declared in this scope
89 | MATCH_MMSS = SS_MSK | MM_MSK, // Every Hour
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:89:37: error: 'MM_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:90:28: error: 'SS_MSK' was not declared in this scope
90 | MATCH_HHMMSS = SS_MSK | MM_MSK | HH_MSK, // Every Day
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:90:37: error: 'MM_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:90:46: error: 'HH_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:91:28: error: 'SS_MSK' was not declared in this scope
91 | MATCH_DHHMMSS = SS_MSK | MM_MSK | HH_MSK | D_MSK, // Every Month
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:91:37: error: 'MM_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:91:46: error: 'HH_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:91:55: error: 'D_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:94:28: error: 'SS_MSK' was not declared in this scope
94 | MATCH_MMDDHHMMSS = SS_MSK | MM_MSK | HH_MSK | D_MSK | M_MSK,
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:94:37: error: 'MM_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:94:46: error: 'HH_MSK' was not declared in this scope
.pio\libdeps\genericSTM32F103RE\STM32duino RTC\src/STM32RTC.h:94:55: error: 'D_MSK' was not declared in this scope
What’s the platformio.ini
and example code?
Before updating to v14, I could program STM32 board without any problem, today I made a change in one of my codes and I got this error, after that I checked the other codes and I found out that it has a problem with RTC library. I created an empty project and I just added STM32RTC library and I got the same error.
This is the platformio.ini code. Without any code just added RTC library in main.cpp.
[env:genericSTM32F103RE]
platform = ststm32
board_build.mcu = stm32f103ret6
upload_protocol = serial
upload_speed = 115200
khoih.prog/TimerInterrupt_Generic@^1.5.0
fmalpartida/LiquidCrystal@^1.5.0
stm32duino/STM32duino RTC@^1.1.0
I downgraded ststm platform to version 13 and it works fine, but with version 14 I got this problem again.
platform = ststm32@13.0.0
How is it possible that this is working at all when you don’t have a board = ...
line specified? You cannot just specify a mcu
, there needs to be a board. Is this the full platformio..ini
Yeah I found the problem. The version that is uploaded in the PlatformIO registry library is over 1 year old
whereas the real 1.1.0 was released 2 months ago, not last year. The version you’re getting with
is too old.
I will open an issue for this.
If you use
platform = ststm32
board = genericSTM32F103RE
https://github.com/stm32duino/STM32RTC/archive/refs/tags/1.1.0.zip
with the example STM32RTC sketch code
SimpleRTC
This sketch shows how to configure the RTC and to display
the date and time periodically
Creation 12 Dec 2017
by Wi6Labs
Modified 03 Jul 2020
by Frederic Pillon for STMicroelectronics
This example code is in the public domain.
#include <LiquidCrystal_I2C.h>
#include <STM32RTC.h>
/* Get the rtc object */
STM32RTC& rtc = STM32RTC::getInstance();
/* Change these values to set the current initial time */
const byte seconds = 0;
const byte minutes = 0;
const byte hours = 16;
/* Change these values to set the current initial date */
/* Monday 15th June 2015 */
const byte weekDay = 1;
const byte day = 15;
const byte month = 6;
const byte year = 15;
void setup()
Serial.begin(9600);
// Select RTC clock source: LSI_CLOCK, LSE_CLOCK or HSE_CLOCK.
// By default the LSI is selected as source.
//rtc.setClockSource(STM32RTC::LSE_CLOCK);
rtc.begin(); // initialize RTC 24H format
// Set the time
rtc.setHours(hours);
rtc.setMinutes(minutes);
rtc.setSeconds(seconds);
// Set the date
rtc.setWeekDay(weekDay);
rtc.setDay(day);
rtc.setMonth(month);
rtc.setYear(year);
// you can use also
//rtc.setTime(hours, minutes, seconds);
//rtc.setDate(weekDay, day, month, year);
void loop()
// Print date...
Serial.printf("%02d/%02d/%02d ", rtc.getDay(), rtc.getMonth(), rtc.getYear());
// ...and time
Serial.printf("%02d:%02d:%02d.%03d\n", rtc.getHours(), rtc.getMinutes(), rtc.getSeconds(), rtc.getSubSeconds());
delay(1000);
you should get a successful compilation.
RAM: [ ] 1.5% (used 988 bytes from 65536 bytes)
Flash: [ ] 3.5% (used 18104 bytes from 524288 bytes)
Building .pio\build\genericSTM32F103RE\firmware.bin
============= [SUCCESS] Took 6.16 seconds =============
Thanks for your reply, you’re right. As far as I know in github you can delete a tag for a repository and add a new tag with the same ID. STM32Duino updated RTC library with the same tag as it was in the last year so that I suppose in this case we have to delete the library and download it manually or add repository URL just as you mentioned in order to see changes. Another thing that platformIO needs to check is the date of uploading library even if the tag is the same as it was, cause as you can see this tag updated multiple times but platformIO is downloading an old repository.
It’s better to open an issue in platformIO in github.
Well they nonchalantly said they wouldn’t re-publish the correct version, which is done by executing one command, so I asked @ivankravets to fix-up the wrong version from the PlatformIO library registry side ^-^.
Please remove .pio
folder from a project, run pio system prune -f
command, and try to build project again.
Does it work now?
I removed .pio folder and used this command as you mentioned but I still got the same error with v14.0 of platform-ststm32. I can still use v13.0 without any problem.
Not reproducable. Using
platform = ststm32
stm32duino/STM32duino RTC @ ^1.1.0
and
void setup()
Serial.begin(9600);
// Set the time
// Set the date
rtc.setDay(day);
rtc.setYear(year);
// you can use also
void loop()
// Print date...
// ...and time
delay(1000);
the result is
PLATFORM: ST STM32 (14.0.0) > STM32F103RE (64k RAM. 512k Flash)
HARDWARE: STM32F103RET6 72MHz, 64KB RAM, 512KB Flash
DEBUG: Current (blackmagic) External (blackmagic, cmsis-dap, jlink, stlink)
- framework-arduinoststm32 4.20000.210603 (2.0.0)
- framework-cmsis 2.50700.210515 (5.7.0)
- toolchain-gccarmnoneeabi 1.90201.191206 (9.2.1)
Found 13 compatible libraries
|-- <TimerInterrupt_Generic> 1.6.0
|-- <LiquidCrystal> 1.5.0
| |-- <Wire> 1.0
|-- <STM32duino RTC> 1.1.0
Compiling .pio\build\genericSTM32F103RE\FrameworkArduinoVariant\PeripheralPins.c.o
Linking .pio\build\genericSTM32F103RE\firmware.elf
Checking size .pio\build\genericSTM32F103RE\firmware.elf
============= [SUCCESS] Took 11.17 seconds =============
Make sure the platform, framework and library version match what’s in my build log above.
I have checked my projects in which I’ve used RTC
library and as Ivan mentioned I used pio system prune -f
command in terminal, I removed .pio
folder of each projects and rebuilt them again, all of them except one were fixed.
In this project I’ve used multiple cpp
files and this project had Clock.cpp
, Clock.h
files and all of RTC functions were in Clock.cpp
. Whenever I rebuilt this project I got the same error.
I removed RTC library and deleted Clock.cpp
and Clock.h
files from the project and the error disappeared. I created another cpp file for RTC functions with this name (RTC_Clock.cpp), added RTC library and rebuilt the project. I found out there was a confliction in names of files and I suppose Clock.cpp
is a part of RTC library.
I don’t know how ststm v13
could build this project.
