I’m using an STM32 Nucleo L031K6 with the mbed framework. The blink example is producing much larger binaries than are necessary for such a small program:
DATA: [= ] 12.3% (used 1008 bytes from 8192 bytes)
PROGRAM: [====== ] 58.9% (used 19292 bytes from 32768 bytes)
.pio/build/nucleo_l031k6/firmware.elf :
section size addr
.text 18892 134217728
.ARM.exidx 8 134236620
.data 392 536871104
.bss 616 536871496
.heap 2896 536872112
.ARM.attributes 40 0
.comment 126 0
.debug_info 16639 0
.debug_abbrev 5969 0
.debug_aranges 4920 0
.debug_ranges 5992 0
.debug_line 25166 0
.debug_str 19602 0
.debug_frame 15972 0
Total 117230
This is with everything set to default values except buildflags = -Os
in platformio.ini
I’ve tried using newlib-nano specs as instructed here but it caused an error while linking. Even with --verbose
there isn’t much of use on the output:
arm-none-eabi-cpp -E -P -T .pio/build/nucleo_l031k6/STM32L031K6.ld.link_script.ld -Wl,--gc-sections -Wl,--wrap,main -Wl,--wrap,_malloc_r -Wl,--wrap,_free_r -Wl,--wrap,_realloc_r -Wl,--wrap,_memalign_r -Wl,--wrap,_calloc_r -Wl,--wrap,exit -Wl,--wrap,atexit -Wl,-n --specs=nano.specs -mcpu=cortex-m0plus -mthumb -DMBED_ROM_START=0x8000000 -DMBED_ROM_SIZE=0x8000 -DMBED_RAM_START=0x20000000 -DMBED_RAM_SIZE=0x2000 -DMBED_BOOT_STACK_SIZE=4096 --specs=nano.specs /Users/richard/.platformio/packages/framework-mbed/targets/TARGET_STM/TARGET_STM32L0/TARGET_NUCLEO_L031K6/device/TOOLCHAIN_GCC_ARM/STM32L031K6.ld -o .pio/build/nucleo_l031k6/STM32L031K6.ld.link_script.ld
========================================================================================================================== [ERROR] Took 47.74 seconds ==========================================================================================================================
For repeatability, the project was created in VS Code with the “Nucleo L031K6” board, then main.cpp
from the example was copy-pasted into src/main.cpp
. buildflags = -Os
was added to platformio.ini
Is there a way get below 19kB for a simple blink program? (I am writing a more complex program but the problems remain).
Looks like part of the problem might be that the PlatformIO Mbed implementation requires you to include the RTOS: Mbed double framework · Issue #819 · platformio/platformio-core · GitHub. Still, it looks like it might also be a general problem with Mbed: Bare-metal profile by theotherjimmy · Pull Request #9800 · ARMmbed/mbed-os · GitHub shows that the bare metal profile still results in 30kB binaries.
Considering that the docs say
By default, project is built without the OS feature.
I’d double-check that. Can you add
#ifdef MBED_CONF_RTOS_PRESENT
#error "RTOS present"
#else
#error "RTOS not present"
to the main.cpp
and check the compiler output?
You’re right, it errors on #error "RTOS not present"
. Looks like the large size is just the standard Mbed libraries.
I’ve tried adding lib_ignore = mbed-rtos, mbed-events, mbed-fs, mbed-net, mbed-rpc, mbed-dsp, mbed-USBHost, mbed-USBDevice
to platformio.ini
, but it didn’t change the binary size.
Can you provide a linker .map file for the correct smal blinky example for this microcontroller when compiled with mbed
? Then we can compare it with the PIO map file (build_flags = -Wl,-Map,output.map
) and amap.
Hi, I am facing a similar issue with a code that is expected to take only 800 bytes, shows upto 14K program size. Could you solve this issue already? See the memory map attached.
We would need to see your full code and platformio.ini
as well as a reference binary and the information with which mbed-os version that was compiled.
Hi
Thanks for the reply.
Here is the original code which my current code is based on:
I configured this code for “stm32l0xx” microcontroller (updated the CMSIS folder and modified accordingly) and built the project using VSCode+PlatformIO.
Please see the platformio.ini and reference binary file attached.
Also, please note that I have disabled the fault handler using the build_flag
-D MBED_FAULT_HANDLER_DISABLED
Current Memory Usage →
DATA: [== ] 17.4% (used 3560 bytes from 20480 bytes)
PROGRAM: [= ] 8.9% (used 17424 bytes from 196608 bytes)
How do I see the current mbed OS version from the project? Any shortcuts?
I can see the version as 5.11.5 looking at the file mbed_version.h, after an explorer search.
I also tried the blinky code for stm32l073rz: The results were as below,
DATA: [== ] 19.8% (used 4056 bytes from 20480 bytes)
PROGRAM: [=== ] 27.7% (used 54368 bytes from 196608 bytes)
platformio.ini contents:
[env:Blinky]
platform = ststm32
framework = mbed
board = nucleo_l073rz
build_flags = ${env.build_flags}
-D STM32_Blinky
with newlib-nano, the size reduced as below,
Memory Usage → Redirecting...
DATA: [= ] 9.6% (used 1968 bytes from 20480 bytes)
PROGRAM: [== ] 19.2% (used 37676 bytes from 196608 bytes)
[env:Blinky]
platform = ststm32
framework = mbed
-D STM32_Blinky
extra_scripts = linker_flags_newlib-nano.py
This 37K for blinky code is too much, isnt it?
How will I share my files here? I can only see an option to attach images.
