[STLINK-V3PWR] Debug adapter doesn't support 'hla_swd' transport
So i move few days ago on platformio, and i try to upload my program to a STM32L031K6, custom board with a STLINK-V3PWR.
First i update openocd to the last openocd (dirty way, copying all file inside the tool-openocd, i find no way to use “pio pkg install”). Now i can connect to the STM32L0x :
openocd.exe -f interface\stlink.cfg -f target\stm32l0.cfg
xPack Open On-Chip Debugger 0.12.0+dev-01850-geb6f2745b-dirty (2025-02-07-10:08)
Licensed under GNU GPL v2
For bug reports, read
OpenOCD: Bug Reporting
Info : auto-selecting first available session transport “dapdirect_swd”. To override use ‘transport select ’.
Info : STLINK V4J5B1S0 (API v3) VID:PID 0483:3757
Info : Target voltage: 3.293187
Info : Unable to match requested speed 300 kHz, using 200 kHz
Info : clock speed 200 kHz
Info : stlink_dap_op_connect(connect)
Info : SWD DPIDR 0x0bc11477
Info : [stm32l0.cpu] Cortex-M0+ r0p1 processor detected
Info : [stm32l0.cpu] target has 4 breakpoints, 2 watchpoints
Info : [stm32l0.cpu] Examination succeed
Info : [stm32l0.cpu] starting gdb server on 3333
But i still can’t upload under platformio :
RAM: [= ] 14.2% (used 1164 bytes from 8192 bytes)
Flash: [==== ] 42.0% (used 13748 bytes from 32768 bytes)
Configuring upload protocol…
AVAILABLE: blackmagic, cmsis-dap, jlink, mbed, stlink
Uploading .pio\build\nucleo_l031k6\firmware.elf
debug_level: 1
Debug adapter doesn’t support ‘hla_swd’ transport
*** [upload] Error 1
So, i tried to change the debug_server under platformio.ini :
[env:nucleo_l031k6]
platform = ststm32
board = nucleo_l031k6
check_skip_packages = yes
debug_tool = custom
debug_server =
${platformio.packages_dir}/tool-openocd/bin/openocd
-s ${platformio.packages_dir}/tool-openocd/scripts
-c “transport select dapdirect_swd”
-f target\stm32l0x.cfg
-c “reset_config none”
But it change nothing, i still get an error. I don’t understand where the “hla_swd” parameter is set, i try to search all the find and change the .platformio\packages\framework-arduinoststm32\debugger\select_hla.cfg to blank but sill get the error.
Any idea about that ?
Thanks in advance,
with -v option :
openocd -d2 -s C:\Users\Froggy.platformio\packages\tool-openocd/openocd/scripts -f interface/stlink.cfg -c “transport select hla_swd” -f target/stm32l0.cfg -c “program {.pio\build\nucleo_l031k6\firmware.elf} verify reset; shutdown;”
debug_level: 2
File a bug report in https://github.com/platformio/platform-ststm32/issues if uploading to a STM32L0 is not working by default for your new STLink.
The hla_swd is added in
So you may just comment out lines 199 and 200 in your local C:\Users\Froggy\.platformio\platforms\ststm32\platform.py file to test that out.
Thanks for your help,
I finally find a way to, and it can help me for specific PWR from STLINK-V3PWR :
I add :
extra_scripts = upload_target.py
upload_protocol = custom
To plaformio.ini
and create upload_target.py at the root of the project :
Import(‘env’)
environ = env[‘ENV’]
env.Replace(UPLOADCMD=‘openocd -d2 -s C:\Users\Froggy\.platformio\packages\tool-openocd\openocd\scripts -f interface\stlink.cfg -f target\stm32l0.cfg -c “program {.pio/build/nucleo_l031k6/firmware.elf} verify reset; shutdown;”’)
So i get :
AVAILABLE: blackmagic, cmsis-dap, custom, jlink, mbed, stlink
CURRENT: upload_protocol = custom
openocd -d2 -s C:\Users\Froggy.platformio\packages\tool-openocd\openocd\scripts -f interface\stlink.cfg -f target\stm32l0.cfg -c “program {.pio/build/nucleo_l031k6/firmware.elf} verify reset; shutdown;”
debug_level: 2
[stm32l0.cpu] halted due to breakpoint, current mode: Thread
xPSR: 0xf1000000 pc: 0x1ff00220 msp: 0x20000ca0
STM32L0: Enabling HSI16
** Programming Started **
Info : Device: STM32L0xx (Cat. 2)
Info : STM32L flash size is 32kb, base address is 0x8000000
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
I actually don’t try the program because it don’t do anything visible without an oscilloscope, but if it upload, it should work :smiley:
Now, need to add some power_on in the script, because the STLINK-V3PWR don’t poweron on startup by itself. And using the stm32cubemonitor is little bit borring. There is some command thrue COM5 to send.
Debug seems to work too, so here is the full plaformio.ini :
; Redirecting...
[env:nucleo_l031k6]
platform = ststm32
;upload_protocol = stlink
debug_tool = custom
debug_server =
c:\Users\Froggy.platformio\packages\tool-openocd\bin\openocd.exe
-s c:\Users\Froggy.platformio\packages\tool-openocd\scripts
-f \interface\stlink.cfg
-f \target\stm32l0.cfg
And the final upload_target.py with autopower on : Import(‘env’)
import serial
import time
stlink_v3pwr = serial.Serial(port=‘COM5’, baudrate=19200)
stlink_v3pwr.write(b’pwr on\r’)
stlink_v3pwr.close()
time.sleep(1)
