Hello everyone,
I just tried using Platformio with the Code::Blocks IDE following the steps in the documentation. I set up a small example Project for the STM32F103C8T6 aka. “BluePill” board using only CMSIS as framework and STLINK as upload protocol. I have the BluePill board connected to an STLINK via SWD. When I build and upload my code (a simple LED blinker), the Platformio script says everything was successfull:
Processing bluepill_f103c8 (board: bluepill_f103c8; framework: cmsis; platform: ststm32)
Verbose mode can be enabled via
-v, --verbose
option
CONFIGURATION: Redirecting...
PLATFORM: ST STM32 > BluePill F103C8
HARDWARE: STM32F103C8T6 72MHz 20KB RAM (64KB Flash)
DEBUG: CURRENT(stlink) EXTERNAL(blackmagic, jlink, stlink)
Library Dependency Finder → httpx://bit.ly/configure-pio-ldf
Collected 0 compatible libraries
Scanning dependencies…
Checking size .pioenvs/bluepill_f103c8/firmware.elf
Memory Usage → Redirecting...
DATA: [ ] 0.0% (used 8 bytes from 20480 bytes)
PROGRAM: [ ] 1.0% (used 626 bytes from 65536 bytes)
Configuring upload protocol…
AVAILABLE: blackmagic, dfu, jlink, mbed, stlink
Uploading .pioenvs/bluepill_f103c8/firmware.elf
GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00392-gbe9ef0b0 (2018-01-12-14:56)
Licensed under GNU GPL v2
For bug reports, read
httpx://openocd.org/doc/doxygen/bugs.html
hla_swd
adapter speed: 1000 kHz
adapter_nsrst_delay: 100
none separate
none separate
Info : Unable to match requested speed 1000 kHz, using 950 kHz
Info : clock speed 950 kHz
Info : STLINK v2 JTAG v21 API v2 SWIM v5 VID 0x0483 PID 0x374B
Info : using stlink api v2
Info : Target voltage: 3.211002
Info : stm32f1x.cpu: hardware has 6 breakpoints, 4 watchpoints
xPSR: 0x01000000 pc: 0x08000228 msp: 0x20005000
** Programming Started **
auto erase enabled
Info : device id = 0x20036410
Info : flash size = 128kbytes
target halted due to breakpoint, current mode: Thread
xPSR: 0x61000000 pc: 0x2000003a msp: 0x20005000
wrote 1024 bytes from file .pioenvs/bluepill_f103c8/firmware.elf in 0.420990s (2.375 KiB/s)
** Programming Finished **
** Verify Started **
xPSR: 0x61000000 pc: 0x2000002e msp: 0x20005000
verified 626 bytes in 0.368001s (1.661 KiB/s)
** Verified OK **
** Resetting Target **
shutdown command invoked
========================= [SUCCESS] Took 1.91 seconds =========================Process returned 0 (0x0) execution time : 2.150 s
Press ENTER to continue.
But in reality the upload apparently didn’t work, because the LED doesn’t blink. I tried manually resetting the µC, but it didn’t help.
My example program works fine when I upload it via the SW4STM32 IDE (which I was using before trying out Platformio).
I also noticed that in the project’s /.pioenvs/ directory, there is only an firmware.elf binary but no .bin binary, but I dont know if that is the problem…
Does someone have an idea where the problem could be?
