I am trying to bring all my C++ code into this decade by using stdlib and STL. I have so far not found a way to get a rich offering of STL features for both ESP32 and AVR processors on Platformio. Perhaps I am just missing the right library. Here is an example of some simple iostreams and iomanip code that works fine with cout but some of which works and some that does not work with Serial2 (for example).
Is there a library that meets my needs or a perhaps a workaround?
#include <stdlib.h> // makes no difference
#include <Streaming.h>
#include <iostream>
using std::cout;
using std::right;
#include <iomanip>
using std::setw;
void setup()
Serial2.begin(9600);
Serial << "hello world" << endl; // works
Serial2 << "hello world 2" << endl; // works
cout << right << "hello world" << endl; // works
Serial2 << right << "hello world" << endl; // DOES NOT COMPILE
// no matching function for call to 'print(std::ios_base& (*&)(std::ios_base&))'
// invalid conversion from 'std::ios_base& (*)(std::ios_base&)' to 'unsigned char' [-fpermissive]
cout << setw(16) << "hello world" << endl; // works
Serial2 << setw(16) << "hello world" << endl; // DOES NOT COMPILE
// no matching function for call to 'Print::print(std::_Setw&)'
cout << setw(16) << right << "hello world" << endl; // works
void loop() {}
