### Board
ESP32 S3
### Device Description
Sensor - IIS3DWB
Flash
### Hard…ware Configuration
NONE
### Version
v2.0.9
### IDE Name
Arduino
### Operating System
Windows 11
### Flash frequency
80M
### PSRAM enabled
no
### Upload speed
921600
### Description
When i use mobile APP transfer data to ESP32 S3 by BLE.
but after several times, esp32 will reset.
### Sketch
```cpp
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
#include <nvs.h>
#include <nvs_flash.h>
#include "Sensor.h"
#include "BleTask.h"
#include "SensorPreferences.h"
#include "LedBlinker.h"
#include "BoardConfig.h"
#include <WiFi.h>
#include <ArduinoJson.h>
BLEServer *pServer = NULL;
static BLECharacteristic * pTxCharacteristic = NULL;
static bool deviceConnected = false;
static bool oldDeviceConnected = false;
static uint8_t txValue = 0;
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
/** SSIDs of local WiFi networks */
static String ssidPrim = "";
static String ssidSec = "";
/** Password for local WiFi network */
static String pwPrim = "";
static String pwSec = "";
static int rtcYear;
static int rtcMonth;
static int rtcDay;
static int rtcHour;
static int rtcMinute;
static int rtcSecond;
static String mqttServer = "";
static String mqttUserName = "";
static String mqttPw = "";
static String SensorId = "";
static String GValue = "";
static String DeviceId = "";
static int rtcStartYear;
static int rtcStartMonth;
static int rtcStartDay;
static int rtcEndYear;
static int rtcEndMonth;
static int rtcEndDay;
static int RecordTime;
static int SleepTime;
static String SetOnOff = "";
static String DateMon = "";
static String DateTue = "";
static String DateWed = "";
static String DateThu = "";
static String DateFri = "";
static String DateSat = "";
static String DateSun = "";
int SetWifiFlag = 0;
int SetRtcFlag = 0;
int SetMqttServerFlag = 0;
int ScheduleFlag = 0;
int GoingScheduleFlag = 0;
int SetSensorIdFlag = 0;
static DynamicJsonDocument jsonBuffer(1024); //512
static StaticJsonDocument<256> jsonResult;
//ESP32Time rtc(3600);
extern unsigned long BleStartTime;
extern unsigned long BleEndTime;
extern unsigned long AbsBleTime;
extern int BleConnect;
extern int BleDisConnect;
extern int SensorValue;
void ParseReceivedData(String receivedData);
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
BleConnect = 1;
BleDisConnect = 0;
Serial.println("Ble Connect");
led_quick_blink();
void onDisconnect(BLEServer* pServer) {
BleDisConnect = 1;
BleConnect = 0;
Serial.println("Ble DisConnect");
led_on();
class MyCallbacks: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string rxValue = pCharacteristic->getValue();
if (rxValue.length() > 0) {
// Serial.println("*********");
// Serial.print("Received Value: ");
// for (int i = 0; i < rxValue.length(); i++)
// Serial.print(rxValue[i]);
ParseReceivedData(rxValue.c_str());
// Serial.println();
void BleUartTaskStep() {
if (deviceConnected) {
pTxCharacteristic->setValue(&txValue, 1);
pTxCharacteristic->notify();
txValue++;
delay(10); // bluetooth stack will go into congestion, if too many packets are sent
// disconnecting
if (!deviceConnected && oldDeviceConnected) {
delay(500); // give the bluetooth stack the chance to get things ready
//BLEDevice::startAdvertising();
pServer->startAdvertising(); // restart advertising
Serial.println("start advertising");
//SF_PRINTLN("[BleUart] Ble Start Advertising");
//BleAdvertiseFlag =1;
oldDeviceConnected = deviceConnected;
// connecting
if (deviceConnected && !oldDeviceConnected) {
// do stuff here on connecting
void BleStart()
BleUartSetup();
Serial.println("Ble Mode");
BleStartTime = millis();
led_on();
void BleStop()
BLEDevice::deinit(false);
void BleUartSetup() {
//Serial.begin(115200);
//Serial.println("[BleUart] MethodCall BleUartSetup");
SF_PRINTLN("[BleUart] MethodCall BleUartSetup");
Preferences preferences;
preferences.begin(PrefNamespace, false);
String DeviceId = preferences.getString(PrefDeviceIdWrite, "");
preferences.end();
Serial.println(DeviceId);
String ShowData = DeviceId + "_" + "AISSENS100AW";
// Create the BLE Device
//BLEDevice::init("UART Service");
BLEDevice::init(ShowData.c_str());
//BLEDevice::setMTU(mtu);
// BLEAdvertisementData advertisementData;
// char manData[] = {0x00,0xff,0x28,0x50};
// advertisementData.setManufacturerData(std::string(manData, sizeof manData));
// BLEAdvertisementData advdata = BLEAdvertisementData();
// String servicedata = "Hello";
// advdata.setManufacturerData(servicedata.c_str());
// Create the BLE Server
BLEServer *pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pTxCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_TX,
BLECharacteristic::PROPERTY_NOTIFY
pTxCharacteristic->addDescriptor(new BLE2902());
BLECharacteristic * pRxCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_RX,
BLECharacteristic::PROPERTY_WRITE
pRxCharacteristic->setCallbacks(new MyCallbacks());
// Start the service
pService->start();
// Start advertising
// pServer->getAdvertising()->start(); // for backward compability
BLEAdvertising *pAdvertising = BLEDevice::getAdvertising();
pAdvertising->addServiceUUID(SERVICE_UUID);
pAdvertising->setScanResponse(true);
pAdvertising->setMinPreferred(0x06); // functions that help with iPhone connections issue
pAdvertising->setMinPreferred(0x12);
//Serial.printf("[BleUart] UART Service started(BLE address: %s), waiting a client connection to notify ...\n", BLEDevice::getAddress().toString().c_str());
void ParseReceivedData(String receivedData) {
receivedData.trim();
Serial.println("Received message " + receivedData + " over Bluetooth");
/** Json object for incoming data */
auto error = deserializeJson(jsonBuffer, receivedData);
if (!error) {
if (jsonBuffer.containsKey("SsidPrim")) {
ssidPrim = jsonBuffer[PrefSsidPrim].as<String>();
pwPrim = jsonBuffer[PrefPwPrim].as<String>();
if (jsonBuffer.containsKey(PrefSsidPrim)) {
preferences.putString(PrefSsidPrim, ssidPrim);
if (jsonBuffer.containsKey(PrefPwPrim)) {
preferences.putString(PrefPwPrim, pwPrim);
preferences.end();
WirelessMode = WIFI_MODE;
SetWifiFlag = 1;
String result;
jsonResult.clear();
jsonResult["Version_Info"] = "Ver0.0";
jsonResult["Command_Id"] = "SET_WIFI_CONNECT";
jsonResult["Error_Code"] = "Success";
if ((WiFi.status() != WL_CONNECTED))
jsonResult[PrefWifiStatus] = "DisConnect";
else
jsonResult[PrefWifiStatus] = "Connect";
serializeJson(jsonResult, result);
result += "\n";
pTxCharacteristic->setValue(result.c_str());
} else {
String result;
jsonResult.clear();
jsonResult[PrefBluetoothMac] = mac2String(BluetoothMac);
jsonResult[PrefStatus] = PrefStatusError;
jsonResult[PrefMessage] = "error input";
result += "\n";
// if (deviceConnected) {
// String result;
// jsonResult.clear();
// jsonResult[PrefBluetoothMac] = mac2String(BluetoothMac);
// jsonResult[PrefStatus] = PrefStatusSuccess;
// jsonResult[PrefFirmwareVersion] = "0.0";
// jsonResult[PrefConfigurationVersion] = "0.0";
// Preferences preferences;
// preferences.begin(PrefNamespace, false);
// SensorId = preferences.getString(PrefSensorId,"");
// if (SensorId == NULL)
// jsonResult[PrefSensorId] = "Please Enter Sensor Id";
// } else {
// jsonResult[PrefSensorId] = SensorId;
// jsonResult[PrefBrand] = "ASUS";
// jsonResult[PrefModel] = "AISSENS100AW";
// jsonResult[PrefBandwidth] = "abc";
// jsonResult[PrefSamplingRate] = "4K";
// GValue = preferences.getString(PrefGValue,"");
// jsonResult[PrefGValue] = "8G";
// } else {
// jsonResult[PrefGValue] = GValue;
// preferences.end();
// jsonResult[PrefMessage] = "update success";
// serializeJson(jsonResult, result);
// result += "\n";
// pTxCharacteristic->setValue(result.c_str());
// pTxCharacteristic->notify();
// } else {
// String result;
// jsonResult[PrefStatus] = PrefStatusError;
// jsonResult[PrefMessage] = "error input";
// result += "\n";
// WirelessMode = WIFI_MODE;
// SetWifiFlag = 1;
else if (jsonBuffer.containsKey("Year"))
rtcYear = jsonBuffer[PrefYear].as<int>();
rtcMonth = jsonBuffer[PrefMonth].as<int>();
rtcDay = jsonBuffer[PrefDay].as<int>();
rtcHour = jsonBuffer[PrefHour].as<int>();
rtcMinute = jsonBuffer[PrefMinute].as<int>();
rtcSecond = jsonBuffer[PrefSecond].as<int>();
if (jsonBuffer.containsKey(PrefYear)) {
preferences.putInt(PrefYear, rtcYear);
if (jsonBuffer.containsKey(PrefMonth)) {
preferences.putInt(PrefMonth, rtcMonth);
if (jsonBuffer.containsKey(PrefDay)) {
preferences.putInt(PrefDay, rtcDay);
if (jsonBuffer.containsKey(PrefHour)) {
preferences.putInt(PrefHour, rtcHour);
if (jsonBuffer.containsKey(PrefMinute)) {
preferences.putInt(PrefMinute, rtcMinute);
if (jsonBuffer.containsKey(PrefSecond)) {
preferences.putInt(PrefSecond, rtcSecond);
preferences.end();
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "SET_RTC";
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
SetRtcFlag =1;
else if (jsonBuffer.containsKey("MqttServer"))
mqttServer = jsonBuffer[PrefMqttServer].as<String>();
mqttPw = jsonBuffer[PrefMqttPw].as<String>();
if (jsonBuffer.containsKey(PrefMqttServer)) {
preferences.putString(PrefMqttServer, mqttServer);
if (jsonBuffer.containsKey(PrefMqttPw)) {
preferences.putString(PrefMqttPw, mqttPw);
preferences.end();
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "SET_MQTT_SETTING";
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
SetMqttServerFlag = 1;
else if (jsonBuffer.containsKey("MqttUserName"))
mqttUserName = jsonBuffer[PrefMqttUserName].as<String>();
if (jsonBuffer.containsKey(PrefMqttUserName)) {
preferences.putString(PrefMqttUserName, mqttUserName);
preferences.end();
String result;
jsonResult.clear();
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
} else if (jsonBuffer.containsKey("StartYear")) {
rtcStartYear = jsonBuffer[PrefStartYear].as<int>();
rtcStartMonth = jsonBuffer[PrefStartMonth].as<int>();
rtcStartDay = jsonBuffer[PrefStartDay].as<int>();
rtcEndYear = jsonBuffer[PrefEndYear].as<int>();
rtcEndMonth = jsonBuffer[PrefEndMonth].as<int>();
rtcEndDay = jsonBuffer[PrefEndDay].as<int>();
RecordTime = jsonBuffer[PrefRecordTime].as<int>();
SleepTime = jsonBuffer[PrefSleepTime].as<int>();
SetOnOff = jsonBuffer[PrefSleepTime].as<String>();
if (jsonBuffer.containsKey(PrefStartYear)) {
preferences.putInt(PrefStartYear, rtcStartYear);
if (jsonBuffer.containsKey(PrefStartMonth)) {
preferences.putInt(PrefStartMonth, rtcStartMonth);
if (jsonBuffer.containsKey(PrefStartDay)) {
preferences.putInt(PrefStartDay, rtcStartDay);
if (jsonBuffer.containsKey(PrefEndYear)) {
preferences.putInt(PrefEndYear, rtcEndYear);
if (jsonBuffer.containsKey(PrefEndMonth)) {
preferences.putInt(PrefEndMonth, rtcEndMonth);
if (jsonBuffer.containsKey(PrefEndDay)) {
preferences.putInt(PrefEndDay, rtcEndDay);
if (jsonBuffer.containsKey(PrefRecordTime)) {
preferences.putInt(PrefRecordTime, RecordTime);
if (jsonBuffer.containsKey(PrefSleepTime)) {
preferences.putInt(PrefSleepTime, SleepTime);
if (jsonBuffer.containsKey(PrefSet)) {
preferences.putString(PrefSet, SetOnOff);
preferences.end();
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "Cmd_schedule_connect";
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
if (SetOnOff == "On")
ScheduleFlag = 1;
GoingScheduleFlag = 1;
} else if (jsonBuffer.containsKey("Status")) {
String result;
jsonResult.clear();
else
String ssidPrim = preferences.getString(PrefSsidPrim, ""); //SSID
preferences.end();
String LocalIp = WiFi.localIP().toString();//IP
jsonResult[PrefSsidPrim] = ssidPrim;
jsonResult[PrefLocalIp] = LocalIp;
SensorValue = analogRead(SensorPin);
if(SensorValue <4095 && SensorValue >= 3276)
jsonResult[PrefBatteryStatus] = "4";
else if(SensorValue < 3276 && SensorValue >= 2457)
jsonResult[PrefBatteryStatus] = "3";
else if(SensorValue < 2457 && SensorValue >= 1638)
jsonResult[PrefBatteryStatus] = "2";
else if(SensorValue < 1638 && SensorValue >= 819)
jsonResult[PrefBatteryStatus] = "1";
else if(SensorValue < 819)
jsonResult[PrefBatteryStatus] = "0";
int a = WiFi.RSSI();
int rssi;
if(a<0 && a>-50)
rssi = 4;
else if(a<-50 && a>-60)
rssi = 3;
else if(a<-60 && a>-70)
rssi = 2;
else if(a<-70)
rssi = 1;
jsonResult["SignalStrength"] = rssi;
result += "\n";
String result;
jsonResult.clear();
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
} else if (jsonBuffer.containsKey("SensorId")) {
SensorId = jsonBuffer[PrefSensorId].as<String>();
if (jsonBuffer.containsKey(PrefSensorId)) {
preferences.putString(PrefSensorId, SensorId);
preferences.end();
SetSensorIdFlag = 1;
} else if (jsonBuffer.containsKey("GValue")) {
GValue = jsonBuffer[PrefGValue].as<String>();
if (jsonBuffer.containsKey(PrefGValue)) {
preferences.putString(PrefGValue, GValue);
preferences.end();
} else if (jsonBuffer.containsKey("Mon")) {
DateMon = jsonBuffer[PrefDateMon].as<String>();
DateTue = jsonBuffer[PrefDateTue].as<String>();
DateWed = jsonBuffer[PrefDateWed].as<String>();
DateThu = jsonBuffer[PrefDateThu].as<String>();
DateFri = jsonBuffer[PrefDateFri].as<String>();
DateSat = jsonBuffer[PrefDateSat].as<String>();
DateSun = jsonBuffer[PrefDateSun].as<String>();
if (jsonBuffer.containsKey(PrefDateMon)) {
preferences.putString(PrefDateMon, DateMon);
if (jsonBuffer.containsKey(PrefDateTue)) {
preferences.putString(PrefDateTue, DateTue);
if (jsonBuffer.containsKey(PrefDateWed)) {
preferences.putString(PrefDateWed, DateWed);
if (jsonBuffer.containsKey(PrefDateThu)) {
preferences.putString(PrefDateThu, DateThu);
if (jsonBuffer.containsKey(PrefDateFri)) {
preferences.putString(PrefDateFri, DateFri);
if (jsonBuffer.containsKey(PrefDateSat)) {
preferences.putString(PrefDateSat, DateSat);
if (jsonBuffer.containsKey(PrefDateSun)) {
preferences.putString(PrefDateSun, DateSun);
preferences.end();
} else if (jsonBuffer.containsKey("DeviceIdWrite")) {
DeviceId = jsonBuffer[PrefDeviceIdWrite].as<String>();
if (jsonBuffer.containsKey(PrefDeviceIdWrite)) {
preferences.putString(PrefDeviceIdWrite, DeviceId);
preferences.end();
String result;
jsonResult.clear();
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
} else if (jsonBuffer.containsKey("DeviceIdRead")) {
preferences.end();
String result;
jsonResult.clear();
jsonResult[PrefDeviceIdRead] = DeviceId;
result += "\n";
} else {
String result;
jsonResult.clear();
result += "\n";
} else if (jsonBuffer.containsKey("PageWifiInfoA")) {
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "GET_WIFI_PROVISION";
preferences.end();
jsonResult["SensorId"] = DeviceId;
jsonResult["ModelName"] = "AISSENS100AW";
preferences.end();
jsonResult["Ssid"] = ssidPrim;
jsonResult["WifiStatus"] = "DisConnect";
else
jsonResult["WifiStatus"] = "Connect";
int rssi;
if(a<0 && a>-50)
rssi = 4;
rssi = 3;
rssi = 2;
else if(a<-70)
rssi = 1;
result += "\n";
} else if (jsonBuffer.containsKey("PageWifiInfoB")) {
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "Cmd_wifi_devie_infomation_connect";
preferences.end();
jsonResult["Brand"] = "ASUS";
jsonResult["Bandwidth"] = "1K";
jsonResult["SamplingRate"] = "4K";
jsonResult["GValue"] = "8G";
} else {
jsonResult["GValue"] = GValue;
preferences.end();
jsonResult["FirmwareVersion"] = "0.0";
jsonResult["ConfigurationVersion"] = "0.0";
preferences.end();
else
int rssi;
if(a<0 && a>-50)
rssi = 4;
rssi = 3;
rssi = 2;
else if(a<-70)
rssi = 1;
String mqttServer = preferences.getString(PrefMqttServer, "");
preferences.end();
jsonResult["MqttAddress"] = mqttServer;
String mqttPw = preferences.getString(PrefMqttPw, "");
preferences.end();
jsonResult["MqttPassword"] = mqttPw;
rtcStartYear = preferences.getInt(PrefStartYear);
rtcStartMonth = preferences.getInt(PrefStartMonth);
rtcStartDay = preferences.getInt(PrefStartDay);
rtcEndYear = preferences.getInt(PrefEndYear);
rtcEndMonth = preferences.getInt(PrefEndMonth);
rtcEndDay = preferences.getInt(PrefEndDay);
RecordTime = preferences.getInt(PrefRecordTime);
SleepTime = preferences.getInt(PrefSleepTime);
SetOnOff = preferences.getString(PrefSet, "");
DateMon = preferences.getString(PrefDateMon, "");
DateTue = preferences.getString(PrefDateTue, "");
DateWed= preferences.getString(PrefDateWed, "");
DateThu = preferences.getString(PrefDateThu, "");
DateFri = preferences.getString(PrefDateFri, "");
DateSat = preferences.getString(PrefDateSat, "");
DateSun = preferences.getString(PrefDateSun, "");
preferences.end();
jsonResult["StartYear"] = rtcStartYear;
jsonResult["StartMonth"] = rtcStartMonth;
jsonResult["StartDay"] = rtcStartDay;
jsonResult["EndYear"] = rtcEndYear;
jsonResult["EndMonth"] = rtcEndMonth;
jsonResult["EndDay"] = rtcEndDay;
jsonResult["SamplingTime"] = RecordTime;
jsonResult["IntervalFrequency"] = SleepTime;
jsonResult["On/Off"] = SetOnOff;
jsonResult["Mon"] = DateMon;
jsonResult["Tue"] = DateTue;
jsonResult["Wed"] = DateWed;
jsonResult["Thu"] = DateThu;
jsonResult["Fri"] = DateFri;
jsonResult["Sat"] = DateSat;
jsonResult["Sun"] = DateSun;
result += "\n";
} else if (jsonBuffer.containsKey("WifiList")) {
String result;
jsonResult.clear();
jsonResult["Command_Id"] = "Cmd_wifi_list_connect";
int n = WiFi.scanNetworks();
if (n == 0) {
jsonResult["List"] = "no networks found";
}else {
for (int i = 0; i < n; ++i) {
jsonResult["List"] = WiFi.SSID(i);
jsonResult["WifiSignal"] = WiFi.RSSI(i);
result += "\n";
} else {
Serial.println("Received invalid JSON");
### Debug Message
```plain
Received message {"SsidPrim":"ASUS-38", "PwPrim":"12345678"} over Bluetooth
Backtrace: 0xfffffffe:0x80381fb8 |<-CORRUPTED
ELF file SHA256: ecc258b6f93a6885
Rebooting...
x⸮⸮ESP-ROM:esp32s3-20210327
### Other Steps to Reproduce
_No response_
### I have checked existing issues, online documentation and the Troubleshooting Guide
- [X] I confirm I have checked existing issues, online documentation and Troubleshooting guide.
