Hi PlatformIO-Experts,
I have a project for a bluepill board based on libopencm3. My project was building fine with the previous release of ststm32/libopencm3 used in PlatformIO.
After updating my PlatformIO packages today, I received a bunch of build errors. A first batch of errors related to the updated APIs of libopencm3 was easy to fix. However, I am now stuck on the following linker errors:
Linking .pio\build\bluepill\firmware.elf
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-sbrkr.o): In function `_sbrk_r':
sbrkr.c:(.text._sbrk_r+0xc): undefined reference to `_sbrk'
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-closer.o): In function `_close_r':
closer.c:(.text._close_r+0xc): undefined reference to `_close'
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-lseekr.o): In function `_lseek_r':
lseekr.c:(.text._lseek_r+0x12): undefined reference to `_lseek'
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-readr.o): In function `_read_r':
readr.c:(.text._read_r+0x12): undefined reference to `_read'
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-fstatr.o): In function `_fstat_r':
fstatr.c:(.text._fstat_r+0x10): undefined reference to `_fstat'
c:/users/damian/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/7.2.1/../../../../arm-none-eabi/lib/thumb/v7-m\libc.a(lib_a-isattyr.o): In function `_isatty_r':
isattyr.c:(.text._isatty_r+0xc): undefined reference to `_isatty'
*** [.pio\build\bluepill\firmware.elf] Error 1
I can reliably “fix” these errors by explicitly reverting to platform = ststm32@~6.1.1 in my platformio.ini. Similarly, I can reliably reproduce the error by switching to the latest ststm32 platform version.
I have tried to find a solution using google. However, the only information I found pointed towards the use of newlib. Looking through the PlatformIO documentation, I can see a use of newlib only with STM32Duino - which I am not using in the given environment.
In case source code is relevant, you can find my project at https://github.com/deltaphi/c6021light/tree/master/c6021light. For more details, Commit 9266ccc9 is fixed to use ststm32@~6.1.1. Commit e16df5f3 is updated for ststm32@7.0.0 and can be used to reproduce the issue.
I would like to use the newer release of libopencm3 for my project, as it contains a number of fixes for problems I had to work around in the past. How can I fix these linker errors?
Regards
Damian
