Hi, I’m using Core 6.0.0a1·Home 3.4.1. Every time I am debugging my ST Nucleo F091RC and I try to restart, I get the following error:
*** [.pio\build\debug\firmware.elf] C:\Users\username\Documents\PlatformIO\Projects\Embedded Drivers\.pio\build\debug\firmware.elf: The process cannot access the file
because it is being used by another process
The full log:
> Executing task in folder Embedded Drivers: C:\Users\username\.platformio\penv\Scripts\platformio.exe debug <
Processing debug (platform: ststm32; board: nucleo_f091rc; framework: cmsis)
--------------------------------------------------------------------------------------------------------------------------------------------------------------------CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/nucleo_f091rc.html
PLATFORM: ST STM32 (15.3.0) > ST Nucleo F091RC
HARDWARE: STM32F091RCT6 48MHz, 32KB RAM, 256KB Flash
- framework-cmsis @ 2.50501.200527 (5.5.1)
- framework-cmsis-stm32f0 @ 2.3.4
- tool-ldscripts-ststm32 @ 0.2.0
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 3 compatible libraries
|-- GPIO_Driver(License: Unknown, Path: C:\Users\username\Documents\PlatformIO\Projects\Embedded Drivers\lib\GPIO_Driver)
|-- NOR_Flash_Driver(License: Unknown, Path: C:\Users\username\Documents\PlatformIO\Projects\Embedded Drivers\lib\NOR_Flash_Driver)
| |-- SPI_Driver(License: Unknown, Path: C:\Users\username\Documents\PlatformIO\Projects\Embedded Drivers\lib\SPI_Driver)
Building in debug mode
==================================================================== [FAILED] Took 1.12 seconds ====================================================================
Environment Status Duration
debug FAILED 00:00:01.122
============================================================== 1 failed, 0 succeeded in 00:00:01.122 ==============================================================
The terminal process "C:\Users\username\.platformio\penv\Scripts\platformio.exe 'debug'" terminated with exit code: 1.
I’m not sure where to even start with this error. Any help would be appreciated. Thanks!
