Sprintf not working on bluepill
Hello!
Could someone please help me with sprintf on bluepill?
If i compile with mapel core sprintf works but not with st-core.
Searching on the internet suggests to put “-u _printf_float” into linker flags but it did not compile…
Robert
Here’s my configuration:
main.cpp:
char displayString[10];
void setup()
void loop()
    sprintf(displayString, "%f", 123.4);
    Serial.print(displayString);
    delay(200);
platformio.ini:
[env]
platform = ststm32
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-D USBD_VID=0x0483
-D USB_MANUFACTURER=“Unknown”
-D USB_PRODUCT="“BLUEPILL_F103C8"”
-D HAL_PCD_MODULE_ENABLED
board_build.core = st
[env:bluepill]
board = genericSTM32F103CB
Exactly, this must be a linker flag, i.e. -Wl, prefixed. Have you tried adding
-Wl,--undefined,_printf_float
as a new line to the build_flags in the platformio.ini?
Thank you very much!
I made a mistake with -Wl,-u _printf_float.
Why is that not the default in platformio?
Robert
The default in STM32Duino is also no floating-point printf. It also has to be specially activated. Flash space is precious on these smaller devices. Thus PlatformIO does the same and has maximum compatibility with its behavior.
