I’m working with a Adafruit Feather HUZZAH ESP8266 and would like to transfer my web app to the ESP8266 with STIFFS, but when I want to make a:
File root = STIFFS.open("/");
I have the following errors (I’m using VSCode):
no instance of overloaded function “fs::FS::open” matches the argument list – argument types are: (const char [2]) – object type is: fs::FS:
conversion from ‘fs::Dir’ to non-scalar type ‘fs::File’ requested
I include: include <ESPAsyncWebServer.h>, <SPIFFSEditor.h> (because if I included just SPIFFS.h, I had an error) and <FS.h>
I don’t why it doesn’t work.
Thanks
This makes sense since /
is the root directory so the return value should be a directory?
Anyways can you share your exact platformio.ini
and code for reproduction?
Yes:
[env:huzzah]
platform = espressif8266
board = huzzah
ESP Async WebServer
ESPAsyncTCP
But do you think my include are correct?
And your main code? EIther here enclosed with tripple backticks blocks or pastebin does fine
Also your IDE is VSCode right?
#include <ESPAsyncWebServer.h>
#include <SPIFFSEditor.h>
#include <FS.h>
const char *ssid = "ION-303";
const char *password = "censoredpassword";
const int led = 0;
AsyncWebServer server(80);
//----------------------------------------------------Serial
while(!Serial){}
Serial.println("\n");
//----------------------------------------------------GPIO
pinMode(led, OUTPUT);
digitalWrite(led, LOW);
//----------------------------------------------------SPIFFS
if(!SPIFFS.begin())
Serial.println("Erreur SPIFFS...");
return;
File root = SPIFFS.open("/");
File file = root.openNextFile();
while(file)
Serial.print("File: ");
Serial.println(file.name());
file.close();
//----------------------------------------------------WIFI
WiFi.begin(ssid, password);
Serial.print("Tentative de connexion...");
while(WiFi.status() != WL_CONNECTED)
Serial.print(".");
delay(100);
Serial.println("Connexion etablie!");
Serial.print("Adresse IP: ");
//----------------------------------------------------SERVER
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request)
request->send(SPIFFS, "/index.html", "text/html");
server.on("/w3.css", HTTP_GET, [](AsyncWebServerRequest *request)
request->send(SPIFFS, "/w3.css", "text/css");
server.on("/script.js", HTTP_GET, [](AsyncWebServerRequest *request)
request->send(SPIFFS, "/script.js", "text/javascript");
server.on("/on", HTTP_GET, [](AsyncWebServerRequest *request)
digitalWrite(led, HIGH);
request->send(200);
server.on("/off", HTTP_GET, [](AsyncWebServerRequest *request)
request->send(200);
server.begin();
Serial.println("Serveur actif!");
Yes I’m using VSCode
Thanks
Yes the calling code is wrong. As you can see with the SPIFFS
class which derives from FS
(filesystem):
uint32_t _type;
bool _autoFormat;
class SPIFFSConfig : public FSConfig
public:
static constexpr uint32_t FSId = 0x53504946;
SPIFFSConfig(bool autoFormat = true) : FSConfig(FSId, autoFormat) { }
// Inherit _type and _autoFormat
// nothing yet, enableTime TBD when SPIFFS has metadate
class FS
public:
FS(FSImplPtr impl) : _impl(impl) { _timeCallback = _defaultTimeCB; }
This file has been truncated. show original
There is either uses File open(const char* path, const char* mode);
or Dir openDir(const char* path);
. But you’re using it here as File root = SPIFFS.open("/");
for which there is no overload. What you wanted to do is probably like in this unit test
File root = FSTYPE.open("/", "r");
// LittleFS and SDFS are not guaranteed to put the names in order of creation, so
// manually look for them...
File f[4];
f[0] = root.openNextFile();
f[1] = root.openNextFile();
f[2] = root.openNextFile();
f[3] = root.openNextFile();
File file1 = FindFileByName(f, 4, "file1");
File file2 = FindFileByName(f, 4, "file2");
File dir1 = FindFileByName(f, 4, "dir1");
File dir1_file3 = dir1.openNextFile();
File dir2 = FindFileByName(f, 4, "dir2");
File dir2_dir3 = dir2.openNextFile();
File dir2_dir3_file4 = dir2_dir3.openNextFile();
(or also here )
But then you need to write File root = SPIFFS.open("/", "r");
It’s working, thank you very much for your help!
